26700-410
26700-410
    AVENTOOLS(艾文)
    MONITOR LCD MOUNT
26700-410 数据手册
LCD Monitor Mount, 512 Series, Post Height 17-in The 512 Series LCD Monitor Mount simplifies multitasking and improves LCD MONITOR MOUNT 512 SERIES productivity by expanding desktop workspace and providing high ergonomic comfort. The articulating arms provide 360-degree rotation allowing you to adjust the monitor to where it is most comfortable. Made POST HEIGHT MAXIMUM MONITOR SIZE | WEIGHT VESA STANDARDS from high-grade steel and aluminum, this monitor mount meets VESA standards and accommodates monitors with 100x100mm mounting patterns and widescreen displays up to 27”. The heavy-duty “C” clamp 17-inches (432mm) WEIGHT 27-inches (685mm) | 22 lbs (10kg) 100x100mm mounting pattern 7 lbs (3.5kg) PACKAGE DIMENSIONS PACKAGE CONTENTS 31 x 23 x 8 inches (78x58.5x21cm) 1 ea. monitor mount (26700-410) mounts to desktop providing excellent stability. Features Part # • Simplifies multitasking and improves productivity with expanded 26700-410 Description LCD Monitor Mount, 512 Series, Post Height 17-in workspace and high ergonomic comfort • Meets VESA standards: fits monitors with 100x100mm mounting patterns • Arms have 360 degree swivel and rotation and -15 to +15 degree tilt adjustment • Easy integration with integrated cable management system • Made of high grade steel and aluminum • Holds Widescreen Display up to 27” • Heavy duty “C” clamp mounts to desktop providing excellent stability sales@aveninc.com aveninc.com 734.973.0099
26700-410
物料型号为26700-410,是一款512系列的LCD显示器支架,立柱高度为17英寸。
该支架的主要特点包括:
- 提供扩展的工作空间和高人体工学舒适度,简化多任务处理并提高生产力。
- 符合VESA标准,适配100x100mm的安装模式。
- 支架臂可360度旋转和-15至+15度倾斜调整。
- 集成线缆管理系统,便于线缆整理。
- 由高等级钢和铝制成,承重高达22磅(约10公斤)。
- 支持最大27英寸(685mm)的宽屏显示器。
- 重约7磅(3.5公斤)。
- 包装尺寸为31x23x8英寸(78x58.5x21cm)。
- 包装内容为1个显示器支架(型号26700-410)。
该支架适用于需要提升桌面空间和改善人体工学舒适度的场合,如办公室、工作室等。
其“C”型夹设计提供了优秀的稳定性,适用于多种桌面厚度。
26700-410 价格&库存
很抱歉,暂时无法提供与“26700-410”相匹配的价格&库存,您可以联系我们找货
