26700-211
26700-211
    AVENTOOLS(艾文)
    MIGHTY SCOPE REPLACEMENT STAND
26700-211 数据手册
30fps Up to Frame/ second 1.3m Mega pixels Designed for use with shiny surfaces, such as solder joints, reflective metal parts, etc. 10X ~ 200X Optical zoom range Mighty Scope 1.3M w/Polerizer Inspect, analyze & measure with ease on your PC Compact and handy. Capture images and videos. The Mighty Scope produces crisp and bright images and videos. Magnification is easily controlled by moving closer to the object for higher magnification and away from the object for lower magnification. It can be used mounted on the stand (included) or handheld. The Mighty Scope has a large focus control knob for easy focusing, built-in LED brightness control wheel for instant control of lighting, and a built-in image capture button. The included software DIGITAL MIGHTY SCOPE 1.3M W/POLARIZER IMAGE SENSOR EFFECTIVE PIXELS 1.3M SIGNAL OUTPUT USB 2.0 VIDEO FORMAT AVI FRAMES PER SECOND 10x to 50x, 200x GAIN CONTROL Automatic SNAP SHOT MODE Useful in applications such as PCB inspection, printing, machining, textile, jewelry, skin care etc. Optional stands available. Automatic POWER SOURCE 5VDC through USB port O/S Windows XP, Vista & 7 Mac OSX 10.6 or above LED LIGHT TYPE WORKING DISTANCE DIMENSIONS Features WEIGHT • Easy to use 6-LED compact & handy digital microscope with a USB interface • High resolution magnification at your fingertips PACKAGE CONTENTS • Detailed examination of any area you choose • Active Pixel Technology produces sharp images and accurate color reproduction • LED’s can be turned on or off with brightness control wheel on the body • Magnification range: 10 to 50x, 200x • Microtouch Shutter trigger allows for quick image capture Hardware & Software controls WHITE BALANCE POWER CONSUMPTION The built-in polarizer makes this Mighty Scope reduce glare or hot spots and enhance contrast. 640 x 480: 30fps 1280 x 1024 : 15fps MAGNIFICATION is feature packed. It can capture, manipulate, annotate and measure allowing you to instantly communicate your findings with your coworkers. 1/4” Color CMOS 260mA (AVG) 6 Brightness controllable LEDs At 10x, 112mm | At 20x, 42mm At 30x, 19mm | At 40x, 8.5mm Length: 111mm | Diameter: 34.5mm Cable length: 1.8M (6ft) Metal Stand: Base: 200mm x 200mm Pole Height: 300mm 113g | 0.25lb Mighty Scope 1.3M Image capture software Metal Stand | Manual Part # Description 26700-200-PLR Digital Mighty Scope 1.3M w/Polarizer 26700-211 Replacement Stand • Built in Polarizer to help reduce glare or hot spots and enhance contrast • Includes measurement software and adjustable metal stand with angle and tilt adjustment sales@aveninc.com aveninc.com 734.973.0099
26700-211 价格&库存
很抱歉,暂时无法提供与“26700-211”相匹配的价格&库存,您可以联系我们找货
