26509-STN
26509-STN
    AVENTOOLS(艾文)
    FLOOR STAND HEAVY DUTY
26509-STN 数据手册
Floor Stand Heavy Duty w/Casters Simple and eco-friendly mobile design FLOOR STAND HEAVY DUTY WITH CASTORS Heavy duty weighted stand with 5 full swivel castors for easy mobility. Ideal for use with magnifying lamps that needs to be moved frequently, such as in beauty saloons, home, medical applications. Pole height is 780mm (30in) and crossbars are 216mm (8.5” long). Will accommodate magnifying lamps with post diameter of maximum 11.5mm. Will accept Aven magnifiers 26501-SIV, 26501-LED, 26502-LED, 26505-SIV and 26505-LED. Assembly required. BASE DIMENSION POST HEIGHT POST INNER DIAMETER WEIGHT PACKAGE CONTENTS Features 5 cross bars each 216mm in length mounted to a center plate 178mm (7in) in diameter. 780mm (30in) 11.5mm 15lb Base with weight, 5 cross bars and 5 castors with hardware for assembly • 5 full swivel castors for easy mobility • Designed for durability • Easy to clean, no maintenance required sales@aveninc.com aveninc.com Part # Description 26509-STN Floor Stand Heavy Duty with Castors 734.973.0099
26509-STN 价格&库存
很抱歉,暂时无法提供与“26509-STN”相匹配的价格&库存,您可以联系我们找货
