Note: 0.5x Auxiliary Lens cannot be used on this SPZH
series body with stand P, PF, T and TL
SPZH-135 Stereo Zoom Microscope with DBL Arm Boom, EARM, LED FOI illumination
21x to 135x makes this system ideal for high magnification applications
Ball bearing arm movement for ease of positioning
The ideal scope for a wide range of investigative/inspection applications, Aven’s dynamic
new microscope SPZH-135 extends the boundaries of stereo zoom microscopy, employing
standard 15X eyepieces to achieve 21x to 135x continuous zoom magnification all the
while providing a constant working distance of 3.3” (84mm). The versatility of the SPZH135 can be realized by adding an optional 0.5x auxiliary lens for an extended working
distance of 5.31” (135mm) while still providing high magnification in the range of 10.5x
to 67.5x. Replacing the standard 15X eyepieces with our DHW20X eyepieces enhances
the magnification range of this dynamic new microscope further – 28X to 180X. Having
eyepieces set at a 45 degree angle, the adjustable interpupillary distance between
eyepieces of 1.96” (50mm) to 2.91” (74mm) means they can be set to the comfort level
of any user. Mounted on a double arm boom stand with E-ARM focus mount and having
illumination provided by a High Output LED fiber optic illuminator and ring light makes this
system ideal for virtually any investigative or inspection application.
Aven microscopes reflect the clear differences of Japanese-engineered instruments designed
and manufactured to industry-leading standards. High-grade optical glass and a straight
light path provide maximum clarity and undistorted viewing.
SPZH-135 STEREO ZOOM MICROSCOPE WITH DBL
ARM BOOM, EARM, LED FOI ILLUMINATION
BODY
EYEPIECE
sales@aveninc.com
15x Wide Field inclined at 45 Degree
MAGNIFICATION
WORKING DISTANCE
21x to 135x, Max 180x with 20x eyepieces
84mm (3.3”)
INTERPUPILLARY DISTANCE
50mm(1.96”) to 74mm (2.91”)
DIOPTER ADJUSTMENT
+5.6D-7.2D on both eyepieces
OPTICAL SYSTEM
STAND TYPE
Greenough
Double Arm w/ball bearing glides
BASE DIMENSIONS/WEIGHT
POLE/TRACK HEIGHT
HORIZONTAL ARM
Features
• Total Magnification of 21X to 135X at 3.3” (84mm) working distance, Max 180X with
20X eyepieces
• Standard High Eye Point wide field 15x eyepieces at 45 degrees for comfortable
viewing even for operators with eyeglasses
• Diopter adjustment on both eyepiece tubes
• Adjustable Interpupillary Distance of 1.96” (50mm) to 2.91” (74MM) accommodates
any operator
• Mounted in an E-ARM focus mount attached to a Double Arm boom stand w/ball
bearing glides
• High Output LED fiber optic illuminator and ring light provide clear illumination for
imaging
• Optional equipment 0.5X Auxiliary lens and 20X eyepieces available
Binocular
285mm x 260mm x 18mm/11.25”x10.25”x .71”
17.35 kg/38lbs
380mm/14.96”
384mm/15.1”
FOCUS MOUNT
E-ARM - Course and fine focus
ILLUMINATION
LED FOI w/FO ring light
ACCESSORIES INCLUDED
Dust Cover (Rubber Eye Guards),Tension Control Pin
OPTIONAL ACCESSORIES
20x Eyepieces, Protective Lens Cover
0.5X Auxiliary lens
WEIGHT
55 lbs
PACKAGE CONTENTS
SPZH-135 Body; Dble Arm Boom 26800B-534;
E-ARM Focus Mount 26800B-518; LED Fiber Optic
Illuminator 26200A-300; Fiber Optic Ring light
26200A-402; Ring light adapter 26800B-460
Part #
Description
26800B-352
SPZH-135 Stereo Zoom Microscope w/ DBL
aveninc.com
734.973.0099
很抱歉,暂时无法提供与“26800B-352”相匹配的价格&库存,您可以联系我们找货
