26800B-354
26800B-354
    AVENTOOLS(艾文)
    TRINOCULAR MICROSCOPE ON STD FOI
26800B-354 数据手册
SPZHT-135 Stereo Zoom Trinocular Microscope on Stand LW w/ FOI LW Articulating arm extends both working distance and area of view SPZHT-135 STEREO ZOOM TRINOCULAR MICROSCOPE ON STAND LW W/ FOI Click stop zoom adjustment for accurate, repeatable measurements The ideal scope for a wide range of investigative/inspection applications, Aven’s dynamic new microscope SPZHT-135 Trinocular microscope extends the boundaries of stereo zoom microscopy, employing standard 15X eyepieces to achieve 21x to 135x continuous zoom magnification all the while providing a constant working distance of 3.3” (84mm). Replacing the standard 15X eyepieces with our DHW20X eyepieces enhances the magnification range of this dynamic new microscope further – 28X to 180X. Having eyepieces set at a 45 degree angle, the adjustable interpupillary distance between eyepieces of 1.96” (50mm) to 2.91” (74mm) means they can be set to the comfort level of any user. Click stop zoom adjustments assure accurate, repeatable measurements. 1080P HD camera delivers unsurpassed imagery to any HDMI monitor or camera SD capture card because the high output Fiber Optic illuminator delivers clean, shadow fee illumination. System is mounted on our light weight articulating arm that extends both area of view and working distance for improved productivity that makes this system ideal for high magnification inspection applications, especially of small parts. Aven microscopes reflect the clear differences of Japanese-engineered instruments designed and manufactured to industry-leading standards. High-grade optical glass and a straight light path provide maximum clarity and undistorted viewing. BODY EYEPIECE 15x Wide Field inclined at 45 Degree SCOPE MAGNIFICATION | SCREEN MAGNIFICATION WORKING DISTANCE 84mm (3.3”) 50mm(1.96”) to 74mm (2.91”) DIOPTER ADJUSTMENT +5.6D-7.2D on both eyepieces TRINOCULAR PORT OPTICAL SYSTEM STAND TYPE One touch easy adjust fine focus Greenough Light Weight Articulating BASE DIMENSIONS 220 x 284mm/8.66” x 11.18” POLE/TRACK HEIGHT 315mm/12.5” ARTICULATING ARM 630mm/24.8” overall FOCUS MOUNT Course and fine focus CAMERA • Total Magnification of 21X to 135X at 3.3” (84mm) working distance, Max 180X with 20X eyepieces • Click stop zoom adjustments for accurate, repeatable measurement • 1080P HD camera for unsurpassed imagery • One touch fine focus trinocular camera port adjustment for quick, easy camera focus and parfocaling the scope • LW articulation arm to extend area of view and working distance • Standard High Eye Point wide field 15x eyepieces at 45 degrees for comfortable viewing even for operators with eyeglasses • Diopter adjustment on both eyepiece tubes • Adjustable Interpupillary Distance of 1.96” (50mm) to 2.91” (74MM) accommodates any operator • High output Fiber Optic illumination for shadow free observation and capture • Multi coated optical components, free from chromatic and spherical aberration • Coarse and fine focusing, ideal for fine detail work • 22” HDMI monitor for increased, improved throughput 21x to 135x, Max 180x with 20x eyepieces | 76x to 494x INTERPUPILLARY DISTANCE Features sales@aveninc.com Trinocular 1080p HDMI/1/3”CMOS/w/USB capture ILLUMINATION LED Fiber Optic w/ 2.31” ID FO ring light 22” HDMI MONITOR Screen mag range 4:3 aspect Low 1.4X = 76X High 9X =494X ACCESSORIES INCLUDED Dust Cover (Rubber Eye Guards),Tension Control Pin OPTIONAL ACCESSORIES 20x Eyepieces, Protective Lens Cover 0.5X Auxiliary lens WEIGHT 15lbs PACKAGE CONTENTS SPZHT-135 Body; E-ARM Focus Mount 26800B518; LW Articulating Arm 26800B-555; 1080P HD Camera 26100-253HD; FO Illuminator 26200A300; FO Ring light 26200A-402; Ring light adapter 26800B-460; 22” HDMI monitor 26700-406 Part # Description 26800B-354 SPZHT-135 Stereo Zoom Trinocular Microscope on Stand LW w/ FOI aveninc.com 734.973.0099
26800B-354 价格&库存
很抱歉,暂时无法提供与“26800B-354”相匹配的价格&库存,您可以联系我们找货
