26800B-353
26800B-353
    AVENTOOLS(艾文)
    TRINOCULAR MCSP ON STAND PLED
26800B-353 数据手册
SPZHT-135 Stereo Zoom Trinocular Microscope on Stand PLED 21x to 135x makes this system ideal for high magnification applications SPZHT-135 STEREO ZOOM TRINOCULAR MICROSCOPE ON STAND PLED Click stop zoom adjustment for accurate, repeatable measurements The ideal scope for a wide range of investigative/inspection applications, Aven’s dynamic new microscope SPZHT-135 Trinocular microscope extends the boundaries of stereo zoom microscopy, employing standard 15X eyepieces to achieve 21x to 135x continuous zoom magnification all the while providing a constant working distance of 3.3” (84mm). Replacing the standard 15X eyepieces with our DHW20X eyepieces enhances the magnification range of this dynamic new microscope further – 28X to 180X. Having eyepieces set at a 45 degree angle, the adjustable interpupillary distance between eyepieces of 1.96” (50mm) to 2.91” (74mm) means they can be set to the comfort level of any user. Click stop zoom adjustments assure accurate, repeatable measurements. One touch fine focus trinocular camera port tuning for quick, easy camera focus and parfocaling the scope. 1080P HD camera delivers unsurpassed imagery to a rugged 8” LCD monitor or USD flash drive. A compact, rugged 8” LCD monitor helps to reduce eye fatigue and strain. System is mounted on our PLED stand with built in LED illumination, dimmer control, coarse and fine focus and a compact 220 x 284mm base that makes this system ideal for high magnification inspection applications, especially of small parts. Aven microscopes reflect the clear differences of Japanese-engineered instruments designed and manufactured to industry-leading standards. High-grade optical glass and a straight light path provide maximum clarity and undistorted viewing. BODY sales@aveninc.com 15x Wide Field inclined at 45 Degree SCOPE MAGNIFICATION | SCREEN MAGNIFICATION WORKING DISTANCE 21x to 135x, Max 180x with 20x eyepieces | 27x to 179x 84mm (3.3”) INTERPUPILLARY DISTANCE 50mm(1.96”) to 74mm (2.91”) DIOPTER ADJUSTMENT +5.6D-7.2D on both eyepieces TRINOCULAR PORT OPTICAL SYSTEM STAND TYPE One touch easy adjust fine focus Greenough Pole BASE DIMENSIONS POLE/TRACK HEIGHT FOCUS MOUNT/ ILLUMINATION 220 x 284mm/8.66” x 11.18” 250mm/9.84” Course and fine focus w/integral LED ring light/ dimmable CAMERA Features • Total Magnification of 21X to 135X at 3.3” (84mm) working distance, Max 180X with 20X eyepieces • Click stop zoom adjustments for accurate, repeatable measurement • 1080P HD camera for unsurpassed imagery • Rugged 8” LCD monitor affords clear, sharp, representations • Standard High Eye Point wide field 15x eyepieces at 45 degrees for comfortable viewing even for operators with eyeglasses • Diopter adjustment on both eyepiece tubes • Adjustable Interpupillary Distance of 1.96” (50mm) to 2.91” (74MM) accommodates any operator • Built in LED illumination with dimmer control • Multi coated optical components, free from chromatic and spherical aberration • Coarse and fine focusing, ideal for fine detail work Trinocular EYEPIECE 1080p HDMI/1/3”CMOS/w/SD capture MONITOR 8” LCD HD/VGA reproduction ACCESSORIES INCLUDED Dust Cover (Rubber Eye Guards),Tension Control Pin OPTIONAL ACCESSORIES 20x Eyepieces, Protective Lens Cover 0.5X Auxiliary lens WEIGHT 15lbs PACKAGE CONTENTS SPZHT-135 Body Stand PLED 26800B-512 1080P HD Camera 26100-253HD 8” LCD Monitor 26700-405 Part # Description 26800B-353 SPZHT-135 Stereo Zoom Trinocular Microscope on Stand PLED aveninc.com 734.973.0099
26800B-353 价格&库存
很抱歉,暂时无法提供与“26800B-353”相匹配的价格&库存,您可以联系我们找货
