26505-MX5
26505-MX5
    AVENTOOLS(艾文)
    LAMPMAGNIFIER2.25XLED
26505-MX5 数据手册
Mighty Vue Slim 5 Diopter LED Magnifying Lamp with brightness control Covered Spring Arm Protective Cover • 4.5”x6” crystal-clear 5-Diopter glass lens • 2.25x Magnification • Distortion-free viewing • 60 super-bright ultra-efficient SMD LED lights • LED lifespan: 20,000 hours • Illumination: Max 800lm 4.5” x 6” 5 Diopter Glass Lens Brightness Controls • Adjustable tension knob • Set lamp position and tighten • Stays in place in any position MIGHTY VUE SLIM 5 DIOPTER LED MAGNIFYING LAMP Aven’s Mighty Vue Slim LED Magnifying Lamp features 60 super-bright ultra-efficient LED lights. Comes equipped with a rectangular 4.5 x 6 inch crystal-clear glass lens to provide 360° distortion-free viewing. The sleek lamp head is mounted to a 34 inch spring-balanced arm with an adjustment knob. Set your position and lock it in. ITEM NUMBER 26505-MX5 LUMEN Max: 800lm LENS ILLUMINATION POWER ADAPTER POWER CONSUMPTION ARM PACKAGE CONTENTS Email | sales@aveninc.com aveninc.com 4.5” x 6” 5-Diopter (2.25x magnification) 60 SMD LEDs INPUT: 100-240V AC 50~60Hz OUTPUT: 20V 600mA 1~9W 34”, Covered Spring Arm, Heavy-Duty Table Clamp, Power Adapter Mighty Vue MX5 Lamp, Heavy-Duty Table Clamp, Power Adapter Phone | 734.973.0099 OptiVue 5 Diopter LED Magnification Desk Lamp Protective Lens Cover LED Illumination • 36 SMD LED lights • Super bright illumination • Low power consumption 4” 5-Diopter Replaceable Lens Crystal Clear Lens • 4 inch round glass lens • 5 Diopter (2.25x magnification) • Removable for easy replacement Flexible Gooseneck Arm Compact and Convenient • Flexible Gooseneck Arm • 11” Reach Span • Stays In Place In Any Position Aven’s OptiVue 5D Magnification Desk Lamp is a compact and convenient inspection lighting solution for your work bench. Featuring a sturdy flexible arm, 360° rotatable lamp head, 5 diopter 4” lens, protective lens cover, and a built-in handle for easy positioning. Weighted Base Item Number 26507-XL5 Lens Size 4 inch diameter 4 inch, 5 diopter glass lens for crystal-clear viewing Optical Power 5 Diopter (2.25x magnification) • 360 swivel lamp head. Inspect from any angle. Illumination 36 SMD LED lights • On/Off switch Power Consumption 6W • 36 energy-efficient SMD LED lights AC/DC Adapter Input: 100-240V AC 50~60Hz Lumen 570lm • Built-in handle for easy positioning Dimensions • Low power consumption: 6W Base: 7” diameter - Total Extended Height: 20.5” - Reach: 11” • Includes power adapter Weight 3.3 LBS • Email | sales@aveninc.com aveninc.com Output: 20V 300mA Phone | 734.973.0099
26505-MX5 价格&库存
很抱歉,暂时无法提供与“26505-MX5”相匹配的价格&库存,您可以联系我们找货
