26531-LED
26531-LED
    AVENTOOLS(艾文)
    LAMP FLEXIBLE 100V 240V LED
26531-LED 数据手册
Machine Tool LED Task Light Compact w/ 18” Flexible Arm Compact metal lamp head for unobstructed view of work areafor ideal illumination This compact LED machine tool task light has a small compact head to fit in tight MACHINE TOOL LED TASK LIGHT COMPACT WITH 18” FLEXIBLE ARM LED COLOR LIGHTING CONTROL On/Off LED COLOR TEMPERATURE 4000K areas and is ideal for medium duty applications. The LED element offer significant increase in intensity over that of a standard 20 watt halogen bulb, while using close to LED LIFE 70% less energy. The head also stays cool to touch and the LEDs have a minimum of Comes with an 5 foot (152cm) power cord. INPUT VOLTAGE • Compact lamp shade with black exterior • 10 high intensity energy saving LEDs 12V 100-240V LENGTH OF GOOSENECK 18” (464mm) DIAMETER OF LAMPSHADE 2.25” (57mm) ADAPTER 24V, 0.5A WEIGHT 1.4lbs (635g) • Cool operating temperature sales@aveninc.com 6.5W OUTPUT VOLTAGE Features • Exceptionally long LED element life (minimum 20,000 hours) Minimum 20,000 hours LED OUTPUT 20,000 hours of high-output life. The 18” (457mm) flexible arm holds firmly for precise positioning. It also has a permanent steel bracket for horizontal or vertical mounting. 10 high intensity white SMD LEDs PACKAGE CONTENTS Machine Tool LED Task Light with Power Adapter Part # Description Price 26531-LED Machine Tool LED Task Light Compact with 18” Flexible Arm $83.00 aveninc.com 734.973.0099
26531-LED 价格&库存
很抱歉,暂时无法提供与“26531-LED”相匹配的价格&库存,您可以联系我们找货
