Machine Tool LED Task Light w/ Magnetic Base & 18” Flexible Arm
Magnetic base allows versatile mounting options
for ideal illumination
This LED machine tool task light is ideal for lathes, grinders, presses, assembly,
inspection, and many other uses in the shop. It has a durable metal shade with a black
finish. The LED element offer significant increase in intensity over that of a standard 20
MACHINE TOOL LED TASK LIGHT WITH
MAGNETIC BASE & 18” FLEXIBLE ARM
LED COLOR
On/Off
LED COLOR
TEMPERATURE
4000K
watt halogen bulb, while using close to 70% less energy. The metal shade also stays
LED LIFE
cool to touch and the LEDs have a minimum of 20,000 hours of high-output life. The
18” (457mm) flexible arm holds firmly for precise positioning and the magnetic base
allows you to securely mount the task light to most metal surfaces. Comes with an 5 foot
24 high intensity white SMD LEDs
LIGHTING CONTROL
Minimum 20,000 hours
LED OUTPUT
6.5W
OUTPUT VOLTAGE
INPUT VOLTAGE
12V
100-240V
(152cm) power cord.
LENGTH OF
GOOSENECK
18” (464mm)
Features
DIAMETER OF
LAMPSHADE
4”(102mm)
ADAPTER
24V, 0.5A
WEIGHT
2.2 lbs (998g)
• Durable metal shade with black finish
• 24 high intensity energy saving LEDs
• Cool operating temperature
PACKAGE CONTENTS
Machine Tool LED Task Light with Power Adapter
• Exceptionally long LED element life (minimum 20,000 hours)
• Strong magnetic base
• Flexible Arm for precise positioning
sales@aveninc.com
Part #
Description
Price
26530-LED
$76.80
aveninc.com
734.973.0099
很抱歉,暂时无法提供与“26530-LED”相匹配的价格&库存,您可以联系我们找货
