SIRRUS LED Task Light w/ High Intensity Fixed Focus, 500mm Flex Arm and Clamp
Dramatically Reduces Power Consumption
and Improves Lighting Quality
SIRRUS LED TASK LIGHT W/ HIGH INTENSITY
FIXED FOCUS, 500MM(19.5”) FLEX ARM &
MOUNTING CLAMP
Our new Sirrus LED Task Light is designed to provide high efficiency & powerful lighting.
It features low power consumption with extra long service life. The Sirrus LED Task Light
LED COLOR
High intensity white LEDs
LIGHTING CONTROL
integrates many outstanding features making it popular for many locations such as
LED LIFE
On/Off
Minimum 20,000 hours
machines, assembly stations, office & inspection locations and precision working. The
LED OUTPUT
3W
soft, even area illumination is ideal for close-up applications that require more than a
OUTPUT VOLTAGE
24V
focused beam. Output ranges from 4100 lux at 1 foot distance to 1070 lux at 2 feet.
INPUT VOLTAGE
The protective switch cover prevents permeation by dust, water, lubricants, coolants, and
other liquids. Includes metal clamp excellent for workbench mounting.
LENGTH OF
GOOSENECK ARM
WEIGHT
Features
19.5” (500mm)
5lbs (2.25kg)
PACKAGE CONTENTS
• 500mm(19.5”) industrial grade flexible gooseneck coated arm
100-277V
1 ea. Sirrus Task Light LED High Intensity Fixed Focus
with 500mm Flex Arm & Mounting Clamp
• Arm stays set in any position to provide direct light where needed
• High intensity energy saving LEDs
Part #
• Cool operating temperature
26527
• Exceptionally long LED element life (minimum 20,000 hours)
• Ideal for assembly, workshop or office applications
26520-MB
Description
500mm(19.5”) Flex Arm & Mounting Clamp
Sirrus Magnetic Base optional for 26526, 26527 and 26528
• Mounting Clamp allows for easy attachment to desk and bench tops
sales@aveninc.com
aveninc.com
734.973.0099
很抱歉,暂时无法提供与“26527”相匹配的价格&库存,您可以联系我们找货
