Machine Tool LED Task Light Domed w/ 23” Flexible Arm
Provides illumination over a large surface area
Our domed machine tool task light is ideal for lathes, grinders, presses, assembly,
MACHINE TOOL LED TASK LIGHT DOMED W/
23” FLEXIBLE ARM
inspection, and many other uses in the shop. The LED element offer significant increase
LED COLOR
in intensity over that of a standard halogen bulb, while using close to 70% less energy.
LIGHTING CONTROL
On/Off
LED COLOR
TEMPERATURE
4000K
The head also stays cool to touch and the LEDs have a minimum of 20,000 hours of
high-output life. The 23” (584mm) flexible arm holds firmly for precise positioning. It also
LED LIFE
has a permanent steel bracket for horizontal or vertical mounting. Comes with an 5 foot
(152cm) power cord.
Features
Minimum 20,000 hours
LED OUTPUT
7.7W
OUTPUT VOLTAGE
INPUT VOLTAGE
• Domed metal shade with black finish
• 36 high intensity energy saving LEDs
• Cool operating temperature
12V
100-240V
LENGTH OF
GOOSENECK
23” (584mm)
DIAMETER OF
LAMPSHADE
6.6” (167mm)
ADAPTER
24V, 0.5A
WEIGHT
3lbs (.4kg)
• Exceptionally long LED element life (minimum 20,000 hours)
• Flexible arm for precise positioning
36 high intensity white SMD LEDs
PACKAGE CONTENTS
Machine Tool LED Task Light with Power Adapter
• Provides illumination over a large surface area
sales@aveninc.com
Part #
Description
Price
26533-LED
with 23” Flexible Arm
$92.00
aveninc.com
734.973.0099
很抱歉,暂时无法提供与“26533-LED”相匹配的价格&库存,您可以联系我们找货
