26501-LED-STN
26501-LED-STN
    AVENTOOLS(艾文)
    LAMP MAG 5 DIOPTER 115V 45 LEDS
26501-LED-STN 数据手册
ProVue Magnifying Lamp LED w/Rolling Stand Elegant and eco-friendly mobile design The Aven ProVue LED Magnifying Lamp, combined with a heavy-duty floor stand with weighted base and five swivel casters, provides full mobility for applications in beauty salons, the medical field and even at home. The 30-inch pole height is perfect for standing or seated inspection. The magnifier, which features 45 SMD LED lights and a 5-inch crystal clear 5-diopter (2.25x) glass lens, provides 360° distortion free viewing. PROVUE MAGNIFYING LAMP LED W/ ROLLING STAND MAGNIFICATION LENS DIAMETER COLOR LIGHTING adjustment knobs and stays set securely in any position. LED LIFE BASE DIMENSIONS • 45 SMD energy efficient LEDs provide shadow-free illumination • 5” 2.25x (5 diopter) crystal clear glass lens for 360° distortion-free viewing POST HEIGHT POST INNER DIAMETER • 45” spring balanced arm stays set in any position WEIGHT • 5 full swivel castors for easy mobility • Designed for durability sales@aveninc.com aveninc.com 5in ADJUSTABLE ARM LENGTH The white metal housing is mounted to a 45-inch spring balanced arm with tension Features 2.25X (5-Diopter) 45in White 45 SMD LEDs Minimum 20,000 hours 5 cross bars each 216mm in length mounted to a center plate 178mm (7in) in diameter. 780mm (30in) 11.5mm 21.5lb Part # Description 26501-LED-STN ProVue Magnifying Lamp LED w/Rolling Stand 734.973.0099
26501-LED-STN 价格&库存
很抱歉,暂时无法提供与“26501-LED-STN”相匹配的价格&库存,您可以联系我们找货
