26505-LED-STN
26505-LED-STN
    AVENTOOLS(艾文)
    LAMP MAG 3 DIOPTER 115V 36 LEDS
26505-LED-STN 数据手册
Mighty Vue Magnifying Lamp LED w/Rolling Stand Elegant and eco-friendly mobile design Enhanced lens size and heavy-duty portable floor stand combine to make the Aven MightyVue LED Magnifying Lamp a convenience in beauty solons, medical offices and hobby applications. The large 7x6-inch crystal clear 3-diopter (1.75x) lens is illuminated by 36 high-powered white LEDs and provides 360° distortion-free viewing. The housing is mounted to an internal spring-balanced arm with a 32-inch reach that stays set MIGHTY VUE MAGNIFYING LAMP LED W/ROLLING STAND MAGNIFICATION LENS DIAMETER COLOR LIGHTING support mobility. LED LIFE BASE DIMENSIONS • Large 7” x 6” 1.75x (3 diopter) lens • 36 high-powered energy efficient SMD LEDs provide shadow-free illumination • 32” spring balanced arm stays put in any position 7 x 6in ADJUSTABLE ARM LENGTH securely in any position. The weighted base and five swivel casters provide balance and Features 1.75X (3-Diopter) POST HEIGHT POST INNER DIAMETER WEIGHT • 5 full swivel castors for easy mobility 32” (812mm) White 36 SMD LEDs (18 per side) Minimum 20,000 hours 5 cross bars each 216mm in length mounted to a center plate 178mm (7in) in diameter. 780mm (30in) 11.5mm 25lb • Designed for durability sales@aveninc.com aveninc.com Part # Description 26505-LED-STN Mighty Vue Magnifying Lamp LED w/Rolling Stand 734.973.0099
26505-LED-STN 价格&库存
很抱歉,暂时无法提供与“26505-LED-STN”相匹配的价格&库存,您可以联系我们找货
