26532-LED
26532-LED
    AVENTOOLS(艾文)
    LAMP FLEXIBLE 100V 240V 36 LEDS
26532-LED 数据手册
Machine Tool LED Task Light Domed w/ 36” Flexible Arm Provides illumination over a large surface area Our domed machine tool task light is ideal for lathes, grinders, presses, assembly, MACHINE TOOL LED TASK LIGHT DOMED W/ 36” FLEXIBLE ARM inspection, and many other uses in the shop. The LED element offer significant increase LED COLOR in intensity over that of a standard halogen bulb, while using close to 70% less energy. LIGHTING CONTROL On/Off LED COLOR TEMPERATURE 4000K The head also stays cool to touch and the LEDs have a minimum of 20,000 hours of high-output life. The 36” (898mm) flexible arm holds firmly for precise positioning. It also LED LIFE has a permanent steel bracket for horizontal or vertical mounting. Comes with an 5 foot (152cm) power cord. Features Minimum 20,000 hours LED OUTPUT 7.7W OUTPUT VOLTAGE INPUT VOLTAGE • Domed metal shade with black finish • 36 high intensity energy saving LEDs • Cool operating temperature 12V 100-240V LENGTH OF GOOSENECK 36” (898mm) DIAMETER OF LAMPSHADE 6.6” (167mm) ADAPTER 24V, 0.5A WEIGHT 3lbs (.4kg) • Exceptionally long LED element life (minimum 20,000 hours) • Flexible arm for precise positioning 36 high intensity white SMD LEDs PACKAGE CONTENTS Machine Tool LED Task Light with Power Adapter • Provides illumination over a large surface area sales@aveninc.com Part # Description Price 26532-LED Machine Tool LED Task Light Domed with 36” Flexible Arm $99.00 aveninc.com 734.973.0099
26532-LED 价格&库存
很抱歉,暂时无法提供与“26532-LED”相匹配的价格&库存,您可以联系我们找货
