26100-245
26100-245
    AVENTOOLS(艾文)
    MIGHTY CAM W/EZMEASURE SOFTWARE
26100-245 数据手册
Mighty Cam CCD USB Camera See the CCD Difference The Mighty Cam CCD is designed for challenging lighting and color conditions. The CCD sensor provides precise color reproduction and highly detailed images for your demanding applications. When compared to standard camera sensors, the Mighty Cam CCD provides images with higher detail and accurate color. The Mighty Cam CCD is capable of high resolution images with low noise and can precisely capture moving objects. If precise color replication is critical, the exceptional quality of the Mighty Cam CCD sensor will meet the requirements of the most demanding applications. Includes ezMeasure Software for image/video capture, measuments, annotation, analyzation and more. 1/2” CCD Sensor MIGHTY CAM CCD CAMERA IMAGE SENSOR OUTPUT 1/2” 1.4MP Color CCD USB 2.0 PIXEL SIZE Mighty Cam CCD 4.65 x 4.65μm FRAME RATE/RESOLUTION WHITE BALANCE SCAN TYPE 20FPS 30FPS 45FPS 36FPS (1360 (1920 (1024 (1280 x x x x 1024) 1080) 768) 960) CMOS Sensor Comparison image created with the included ezMeasure Software Automatic/Manual Progressive Scan LENS MOUNT C Mount SYSTEMS Windows 7 & 8 OUTER DIMENSIONS WEIGHT 52mm x 52mm x 39.7mm (2.4” x 2.4” x 1.5” inches) 121g (.35lbs) PHOTO FORMAT SHUTTER Supports TWAIN and DirectShow Interfaces JPEG/BMP/PNG/RAW Global COLOR RGB PACKAGE CONTENTS Camera USB Cable Lens Cap Cover eZMeasure Software Part # Description Sensor 26100-245 Mighty Cam CCD CCD Email | sales@aveninc.com aveninc.com Phone | 734.973.0099 ezMeasure Software Analysis Made “EZ” ezMeasure Software is your digital analization solution. Capture high quality images, record video for playback, calibrate for accurate measurements, annotate and record data. It’s all “EZ” with ezMeasure Measure, Annotate and Analyze Utilize ezMeasure’s features to callibrate, make accurate measurements, annotate your data and create reports Capture High Quality Images Create enhanced still photos or record a live video stream for play back. Measurement Tools • Set the image pixels to real units eg. mm or inches. • Record and save multiple calibration settings. • Measure the distances between different points Email | sales@aveninc.com aveninc.com Phone | 734.973.0099
26100-245 价格&库存
很抱歉,暂时无法提供与“26100-245”相匹配的价格&库存,您可以联系我们找货
