REV.
DESCRIPTION
F Added Note 4
G Updated Note 4 with Table 3
H Remove PPS and GF30 Material
J Removed Material Code
DATE
APPROVED
06/19/09
07/27/10
11/02/11
05/28/16
T. Y.
T. Y.
T. Y.
J. C.
0.25 [6.4mm]
0.17 [4.3mm]
0.078 [2.0mm]
B
DIA
0.28 [7.2mm]
0.20 [5.1mm]
B
0.010 [0.3mm]
0.145 [3.7mm]
0.125 [3.2mm]
0.045 [1.1mm]
R.005 [R0.1mm]
0.050 [1.3mm]
SECTION B-B
0.025 [0.6mm]
0.080 [2.0mm]
REF.
0.050 [1.3mm]
REF.
PART NO.
Holder Faces
0.185 [4.7mm]
Ø.032+.003
-.002
TYP.
0.172 [4.4mm] Holder Pitch
DIA
H-100C
.132 (3.4mm)
H-100C-1
.150 (3.8mm)
H-101C
.132 (3.4mm)
H-101C-1
.150 (3.8mm)
H-102C
.132 (3.4mm)
H-102C-1
.150 (3.8mm)
H-103C
.132 (3.4mm)
H-103C-1
.150 (3.8mm)
0.100 [2.5mm] LED Lead
Recommended Mounting Holes
H-100C
H-101C
H-102C
H-103C
STANDARD TOLERANCE
( UNLESS OTHERWISE SPECIFIED )
DECIMALS
.X
.XX
.XXX
2. MATERIAL 1: NYLON 6/6, 94V-0, BLACK.
1. GENERAL SPECIFICATIONS: BIVAR MOLDED COMPONENT SPECIFICATION BV00-E101.
± .1
± .01
± .005
DESIGNED:
M. Chen
CHECKED:
D. Green
ANGULAR
X°
± 1°
4 THOMAS, IRVINE, CA. 92618
TEL: (949) 951-8808
TITLE:
DATE:
01/21/03
DATE:
01/21/03
FAX: (949) 951-3974
T-1 (3mm) LED HOLDER, 90° MOUNT,
INTERLOCKING VARIABLE DIAMETER
PART NO:
REVISION:
H-10XC-X
CAGE CODE : 32559
J
SHEET # 1 OF 1
CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING.
很抱歉,暂时无法提供与“H-101C”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+9.428621+1.22040
- 10+3.7627210+0.48703
- 100+3.40478100+0.44070
- 1000+3.020651000+0.39098
- 国内价格
- 1+9.36680
- 10+3.73714
- 100+3.38259
- 1000+3.00049
- 国内价格 香港价格
- 89+9.8603089+1.27628
- 115+7.34761115+0.95105
- 250+5.65168250+0.73153
- 国内价格 香港价格
- 18+2.3733818+0.30720
- 100+2.05396100+0.26586
- 国内价格 香港价格
- 1+3.529681+0.45687
- 10+2.3961310+0.31015
- 100+1.69894100+0.21991
- 500+1.38240500+0.17894
- 1000+1.278181000+0.16545
- 2000+1.189392000+0.15395
- 5000+1.092075000+0.14136
- 10000+1.0312710000+0.13349
- 25000+0.9648425000+0.12489
