H-278C-2
H-278C-2
    BIVAR
    Molded
H-278C-2 数据手册
REV. D E F G H 0.433 [11.0mm] 0.100 [2.5mm] DESCRIPTION Engineering Update w/o Changes Add [ -2 ] version to the series -1 version Obsolete Updated (0.50") Height Dimension Removed Material Code DATE APPROVED 02/27/04 04/13/06 10/04/07 03/04/08 05/28/16 M. C. M. C. M. C. M. C. J. C. 0.240 [6.1mm] 0.165 [4.2mm] TYP. 0.030 [0.8mm] SQ. TYP. 0.50 [12.7mm] 0.380 [9.7mm] DIA TYP. 0.35 [8.8mm] 0.130 [3.3mm] 0.210 [5.3mm] 0.300 [7.6mm] Holder Faces Ø.032+.003 -.002 0.220 [5.6mm] TYP. 0.090 [2.3mm] 0.245 [6.2mm] Holder Pitch 0.100 [2.5mm] LED Lead Recommended Mounting Holes H-275C PART NO. H-276C H-277C H-278C DIA H-275C SERIES H-276C SERIES H-277C SERIES H-278C SERIES H-275C-2 H-276C-2 H-277C-2 H-278C-2 .206 [5.23mm] STANDARD TOLERANCE ® ( UNLESS OTHERWISE SPECIFIED ) DECIMALS .X .XX .XXX 2. MATERIAL: NYLON 6/6, 94V-0, BLACK. ± .1 ± .01 ± .005 DESIGNED: M. Chen 1. GENERAL SPECIFICATIONS: BIVAR MOLDED COMPONENT SPECIFICATION BV00-E101. CHECKED: D. Green ANGULAR X° ± 1° 4 THOMAS, IRVINE, CA. 92618 TEL: (949) 951-8808 FAX: (949) 951-3974 TITLE: BI-LEVEL T-1¾ (5mm) LED HOLDER INTERLOCKING VARIABLE INSIDE DIAMETER DATE: 03/31/03 DATE: 03/31/03 PART NO: REVISION: H-27XC-X CAGE CODE : 32559 H SHEET # 1 OF 1 CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING.
H-278C-2 价格&库存
很抱歉,暂时无法提供与“H-278C-2”相匹配的价格&库存,您可以联系我们找货
