455-320
455-320
    BIVAR
    Molded
455-320 数据手册
REV. E H 0.100 [2.5mm] TYP. F F Ø.250 [Ø6.4mm] Ø.045 [Ø1.1mm] TYP. 0.134 [3.4mm] TYP. 450 SERIES H PART NO. 450-050 .050 (1.3) 450-060 .060 (1.5) 450-070 .070 (1.8) 450-080 .080 (2.0) 450-090 .090 (2.3) 450-100 .100 (2.5) 450-110 .110 (2.8) 450-120 .120 (3.0) 450-130 .130 (3.3) 450-140 .140 (3.6) .150 (3.8) 450-150 450-160 .160 (4.1) 450-170 .170 (4.3) 450-180 .180 (4.6) 450-190 .190 (4.8) 450-200 .200 (5.1) T F .010 (.25) .015 (.38) .020 (.51) .025 (.64) .030 (.76) .035 (.89) .040 (1.0) .045 (1.1) .030(.76) .050 (1.3) .055 (1.4) .060 (1.5) .065 (1.7) .070 (1.8) .075 (1.9) .080 (2.0) .085 (2.2) Ø.055 [Ø1.4mm] THRU with Lead-In, both ends 455 SERIES H T PART NO. .200 (5.1) 455-200 .210 (5.3) 455-210 .220 (5.6) 455-220 .230 (5.8) 455-230 455-240 .240 (6.1) 455-250 .250 (6.4) .260 (6.6) 455-260 .270 (6.9) 455-270 .150(3.8) 455-280 .280 (7.1) 455-290 .290 (7.4) 455-300 .300 (7.6) 455-310 .310 (7.9) 455-320 .320 (8.1) 455-330 .330 (8.4) 455-340 .340 (8.6) 455-350 .350 (8.9) F .025 (.64) .030 (.76) .035 (.89) .040 (1.0) .045 (1.1) .050 (1.3) .055 (1.4) .060 (1.5) .065 (1.7) .070 (1.8) .075 (1.9) .080 (2.0) .085 (2.2) .090 (2.3) .095 (2.4) .100 (2.5) 02/23/04 457 SERIES PART NO. H T 457-510 .510 (13.0) 457-530 .530 (13.5) 457-550 .550 (14.0) 457-570 .570 (14.5) 457-590 .590 (15.0) .490 (12.4) 457-610 .610 (15.5) 457-630 .630 (16.0) 457-650 .650 (16.5) 457-670 .670 (17.0) 457-690 .690 (17.5) REF. T DATE DESCRIPTION Engineering Update w/o Changes 456 SERIES H T F PART NO. .350 (8.9) .025 (.64) 456-350 456-360 .360 (9.1) .030 (.76) 456-370 .370 (9.4) .035 (.89) 456-380 .380 (9.7) .040 (1.0) 456-390 .390 (9.9) .045 (1.1) 456-400 .400 (10.2) .050 (1.3) 456-410 .410 (10.4) .055 (1.4) 456-420 .420 (10.7) .060 (1.5) .300(7.6) 456-430 .430 (10.9) .065 (1.7) 456-440 .440 (11.2) .070 (1.8) 456-450 .075 (1.9) .450 (11.4) 456-460 .080 (2.0) .460 (11.7) 456-470 .470 (11.9) .085 (2.2) 456-480 .480 (12.2) .090 (2.3) 456-490 .095 (2.4) .490 (12.4) 456-500 .100 (2.5) .500 (12.7) 458 SERIES PART NO. H T 458-700 .700 (17.8) 458-720 .720 (18.3) 458-740 .740 (18.8) 458-760 .760 (19.3) 458-780 .780 (19.8) .680 (17.3) 458-800 .800 (20.3) 458-820 .820 (20.8) 458-840 .840 (21.3) 458-860 .860 (21.8) 458-880 .880 (22.4) F .010 (.25) .020 (.51) .030 (.76) .040 (1.0) .050 (1.3) .060 (1.5) .070 (1.8) .080 (2.0) .090 (2.3) .100 (2.5) 459 SERIES H T PART NO. .900 (22.9) 459-900 .920 (23.4) 459-920 .940 (23.9) 459-940 459-960 .960 (24.4) 459-980 .980 (24.9) .880 (22.4) 459-1000 1.000 (25.4) 459-1020 1.020 (25.9) 459-1040 1.040 (26.4) 459-1060 1.060 (26.9) 459-1080 1.080 (27.4) F .010 (.25) .020 (.51) .030 (.76) .040 (1.0) .050 (1.3) .060 (1.5) .070 (1.8) .080 (2.0) .090 (2.3) .100 (2.5) STANDARD TOLERANCE DECIMALS 2. MATERIAL: NYLON 6/6, 94V-2, WHITE. BIVAR MATERIAL CODE 04-WE. BASF ULTRAMID NYLON 6/6 A3K WHITE. 1. GENERAL SPECIFICATIONS: BIVAR MOLDED COMPONENT SPECIFICATION BV00-E101. ± .1 ± .01 ± .005 DESIGNED: Michael Chen CHECKED: D. Green ANGULAR X° ± 1° DATE: 02/28/03 DATE: 02/28/03 M. C. F .010 (.25) .020 (.51) .030 (.76) .040 (1.0) .050 (1.3) .060 (1.5) .070 (1.8) .080 (2.0) .090 (2.3) .100 (2.5)  ( UNLESS OTHERWISE SPECIFIED ) .X .XX .XXX APPROVED 4 THOMAS, IRVINE, CA. 92618 TEL: (949) 951-8808 FAX: (949) 951-3974 TITLE: T-1(3mm) & T-1 3/4(5mm) MOLDED LED MOUNT REVISION: PART NO: 45X-XXX CAGE CODE : 32559 E SHEET # 1 OF 1 CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING.
455-320 价格&库存
很抱歉,暂时无法提供与“455-320”相匹配的价格&库存,您可以联系我们找货
  • 100+2.60160100+0.33674
  • 500+2.33970500+0.30284
  • 1000+2.095251000+0.27120
  • 10000+1.8158910000+0.23504
  • 100+2.66151
  • 500+2.39320
  • 1000+2.14286
  • 10000+1.85779
