REV.
DESCRIPTION
B Engineering Update w/o Changes
C Added 03-NL-BK Material Code
D Updated Model
E Removed Material Code
PART NO.
H
F
460-060
.060 (1.5)
.010 (.25)
460-070
.070 (1.8)
.015 (.38)
460-080
.080 (2.0)
.020 (.51)
460-090
.090 (2.3)
.025 (.64)
460-100
.100 (2.5)
.030 (.76)
460-110
.110 (2.8)
.035 (.89)
460-120
.120 (3.0)
.040 (1.0)
460-130
.130 (3.3)
.045 (1.1)
460-140
.140 (3.6)
.050 (1.3)
460-150
.150 (3.8)
.055 (1.4)
460-160
.160 (4.1)
.060 (1.5)
460-170
.170 (4.3)
.065 (1.7)
460-180
.180 (4.6)
.070 (1.8)
460-190
.190 (4.8)
.075 (1.9)
460-200
.200 (5.1)
.080 (2.0)
460-210
.210 (5.3)
.085 (2.2)
PART NO.
461-360
H
.360 (9.1)
F
.380 (9.7)
.020 (.51)
461-400
.400 (10.2)
.030 (.76)
461-420
.420 (10.7)
.040 (1.0)
461-440
.440 (11.2)
.050 (1.3)
461-460
.460 (11.7)
.060 (1.5)
461-480
.480 (12.2)
.070 (1.8)
461-500
.500 (12.7)
.080 (2.0)
461-520
.520 (13.2)
.090 (2.3)
461-540
.540 (13.7)
.100 (2.5)
PART NO.
H
F
APPROVED
M. C.
M. C.
M. C.
J. C.
T
0.110 [2.8mm]
0.100 [2.5mm] TYP.
0.030 [0.8mm]
0.200 [5.1mm]
H
TYP.
F
REF.
T
F
.040 (1.0)
0.180 [4.6mm]
SQ.
0.125 [3.2mm]
T
POLARITY KEY
.010 (.25)
461-380
DATE
02/23/04
08/27/07
07/23/08
05/21/16
0.06 [1.6mm]
Ø.046 [Ø1.2mm]
TYP.
.340 (8.6)
T
PART NO.
H
F
0.050 [1.3mm]
.200 (5.1)
.025 (.64)
0.100 [2.5mm]
465-210
.210 (5.3)
.030 (.76)
TYP.
465-220
.220 (5.6)
.035 (.89)
465-230
.230 (5.8)
.040 (1.0)
465-240
.240 (6.1)
.045 (1.1)
462-560
.560 (14.2)
.010 (.25)
465-250
.250 (6.4)
.050 (1.3)
462-580
.580 (14.7)
.020 (.51)
465-260
.260 (6.6)
.055 (1.4)
462-600
.600 (15.2)
.030 (.76)
465-270
.270 (6.9)
.060 (1.5)
462-620
.620 (15.7)
.040 (1.0)
465-280
.280 (7.1)
.065 (1.7)
462-640
.640 (16.3)
.050 (1.3)
465-290
.290 (7.4)
.070 (1.8)
462-660
.660 (16.8)
.060 (1.5)
465-300
.300 (7.6)
.075 (1.9)
462-680
.680 (17.3)
.070 (1.8)
465-310
.310 (7.9)
.080 (2.0)
462-700
.700 (17.8)
.080 (2.0)
465-320
.320 (8.1)
.085 (2.2)
462-720
.720 (18.3)
.090 (2.3)
465-330
.330 (8.4)
.090 (2.3)
462-730
.730 (18.5)
.095 (2.4)
465-340
.340 (8.6)
.095 (2.4)
462-740
.740 (18.8)
.100 (2.5)
465-350
.350 (8.9)
.100 (2.5)
.540 (13.7)
T
465-200
TYP.
Ø.032+.003
-.002 TYP.
Recommended Mounting Holes
.150 (3.8)
STANDARD TOLERANCE
( UNLESS OTHERWISE SPECIFIED )
DECIMALS
.X
.XX
.XXX
2. MATERIAL: NYLON 6/6, 94V-2, NATURAL.
± .1
± .01
± .005
DESIGNED:
D. Green
1. GENERAL SPECIFICATIONS: BIVAR MOLDED COMPONENT SPECIFICATION BV00-E101.
CHECKED:
M. Chen
ANGULAR
X°
± 1°
4 THOMAS, IRVINE, CA. 92618
TEL: (949) 951-8808
TITLE:
DATE:
08/07/03
DATE:
08/07/03
PART NO:
FAX: (949) 951-3974
T-1 (3mm) & T-1 3/4 (5mm)
INDIVIDUAL LED MOUNTS
REVISION:
46X-XXX
CAGE CODE : 32559
E
SHEET # 1 OF 1
CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING.
很抱歉,暂时无法提供与“465-210”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 100+2.68891100+0.34804
- 500+2.42700500+0.31414
- 1000+2.156361000+0.27911
- 10000+1.8857310000+0.24408
- 国内价格
- 100+2.74656
- 500+2.47825
- 1000+2.20156
- 10000+1.92606
