REV.
E
F
H
0.100 [2.5mm]
TYP.
F
T
DESCRIPTION
Engineering Update w/o Changes
Removed Material Code
457 SERIES
H
T
PART NO.
457-510 .510 (13.0)
457-530 .530 (13.5)
457-550 .550 (14.0)
457-570 .570 (14.5)
457-590 .590 (15.0)
.490 (12.4)
457-610 .610 (15.5)
457-630 .630 (16.0)
457-650 .650 (16.5)
457-670 .670 (17.0)
457-690 .690 (17.5)
REF.
F
Ø.250 [Ø6.4mm]
Ø.045 [Ø1.1mm]
TYP.
0.134 [3.4mm]
TYP.
450 SERIES
H
PART NO.
450-050 .050 (1.3)
450-060 .060 (1.5)
450-070 .070 (1.8)
450-080 .080 (2.0)
450-090 .090 (2.3)
450-100 .100 (2.5)
450-110 .110 (2.8)
450-120 .120 (3.0)
450-130 .130 (3.3)
450-140 .140 (3.6)
450-150 .150 (3.8)
450-160 .160 (4.1)
450-170 .170 (4.3)
450-180 .180 (4.6)
450-190 .190 (4.8)
450-200 .200 (5.1)
Ø.055 [Ø1.4mm] THRU
with Lead-In, both ends
T
F
.010 (.25)
.015 (.38)
.020 (.51)
.025 (.64)
.030 (.76)
.035 (.89)
.040 (1.0)
.045 (1.1)
.030(.76)
.050 (1.3)
.055 (1.4)
.060 (1.5)
.065 (1.7)
.070 (1.8)
.075 (1.9)
.080 (2.0)
.085 (2.2)
455 SERIES
H
T
PART NO.
455-200 .200 (5.1)
455-210 .210 (5.3)
455-220 .220 (5.6)
455-230 .230 (5.8)
455-240 .240 (6.1)
455-250 .250 (6.4)
455-260 .260 (6.6)
455-270 .270 (6.9)
.150(3.8)
455-280 .280 (7.1)
455-290 .290 (7.4)
455-300 .300 (7.6)
455-310 .310 (7.9)
455-320 .320 (8.1)
455-330 .330 (8.4)
455-340 .340 (8.6)
455-350 .350 (8.9)
F
.025 (.64)
.030 (.76)
.035 (.89)
.040 (1.0)
.045 (1.1)
.050 (1.3)
.055 (1.4)
.060 (1.5)
.065 (1.7)
.070 (1.8)
.075 (1.9)
.080 (2.0)
.085 (2.2)
.090 (2.3)
.095 (2.4)
.100 (2.5)
456 SERIES
T
F
H
PART NO.
456-350 .350 (8.9)
.025 (.64)
456-360 .360 (9.1)
.030 (.76)
456-370 .370 (9.4)
.035 (.89)
456-380 .380 (9.7)
.040 (1.0)
456-390 .390 (9.9)
.045 (1.1)
456-400 .400 (10.2)
.050 (1.3)
456-410 .410 (10.4)
.055 (1.4)
456-420 .420 (10.7)
.060 (1.5)
.300(7.6)
456-430 .430 (10.9)
.065 (1.7)
456-440 .440 (11.2)
.070 (1.8)
456-450 .450 (11.4)
.075 (1.9)
456-460 .460 (11.7)
.080 (2.0)
456-470 .470 (11.9)
.085 (2.2)
456-480 .480 (12.2)
.090 (2.3)
456-490 .490 (12.4)
.095 (2.4)
456-500 .500 (12.7)
.100 (2.5)
DATE
APPROVED
02/23/04
05/21/16
M. C.
J. C.
F
.010 (.25)
.020 (.51)
.030 (.76)
.040 (1.0)
.050 (1.3)
.060 (1.5)
.070 (1.8)
.080 (2.0)
.090 (2.3)
.100 (2.5)
458 SERIES
F
H
T
PART NO.
458-700 .700 (17.8)
.010 (.25)
458-720 .720 (18.3)
.020 (.51)
458-740 .740 (18.8)
.030 (.76)
458-760 .760 (19.3)
.040 (1.0)
458-780 .780 (19.8)
.050 (1.3)
.680 (17.3)
458-800 .800 (20.3)
.060 (1.5)
458-820 .820 (20.8)
.070 (1.8)
458-840 .840 (21.3)
.080 (2.0)
458-860 .860 (21.8)
.090 (2.3)
458-880 .880 (22.4)
.100 (2.5)
459 SERIES
H
T
PART NO.
.900 (22.9)
459-900
459-920
.920 (23.4)
459-940
.940 (23.9)
.960 (24.4)
459-960
459-980
.980 (24.9)
.880 (22.4)
459-1000 1.000 (25.4)
459-1020 1.020 (25.9)
459-1040 1.040 (26.4)
459-1060 1.060 (26.9)
459-1080 1.080 (27.4)
F
.010 (.25)
.020 (.51)
.030 (.76)
.040 (1.0)
.050 (1.3)
.060 (1.5)
.070 (1.8)
.080 (2.0)
.090 (2.3)
.100 (2.5)
STANDARD TOLERANCE
( UNLESS OTHERWISE SPECIFIED )
DECIMALS
.X
.XX
.XXX
2. MATERIAL: NYLON 6/6, 94V-2, WHITE.
DESIGNED:
1. GENERAL SPECIFICATIONS: BIVAR MOLDED COMPONENT SPECIFICATION BV00-E101.
CHECKED:
± .1
± .01
± .005
M. Chen
D. Green
ANGULAR
X°
± 1°
4 THOMAS, IRVINE, CA. 92618
TEL: (949) 951-8808
TITLE:
DATE:
02/28/03
DATE:
02/28/03
PART NO:
FAX: (949) 951-3974
T-1 (3mm) & T-1 3/4 (5mm)
MOLDED LED MOUNT
REVISION:
45X-XXX
CAGE CODE : 32559
F
SHEET # 1 OF 1
CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING.
很抱歉,暂时无法提供与“456-370”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 100+2.54194100+0.32949
