461-440
461-440
    BIVAR
    Molded
461-440 数据手册
REV. DESCRIPTION B Engineering Update w/o Changes C Added 03-NL-BK Material Code D Updated Model E Removed Material Code PART NO. H F 460-060 .060 (1.5) .010 (.25) 460-070 .070 (1.8) .015 (.38) 460-080 .080 (2.0) .020 (.51) 460-090 .090 (2.3) .025 (.64) 460-100 .100 (2.5) .030 (.76) 460-110 .110 (2.8) .035 (.89) 460-120 .120 (3.0) .040 (1.0) 460-130 .130 (3.3) .045 (1.1) 460-140 .140 (3.6) .050 (1.3) 460-150 .150 (3.8) .055 (1.4) 460-160 .160 (4.1) .060 (1.5) 460-170 .170 (4.3) .065 (1.7) 460-180 .180 (4.6) .070 (1.8) 460-190 .190 (4.8) .075 (1.9) 460-200 .200 (5.1) .080 (2.0) 460-210 .210 (5.3) .085 (2.2) PART NO. 461-360 H .360 (9.1) F .380 (9.7) .020 (.51) 461-400 .400 (10.2) .030 (.76) 461-420 .420 (10.7) .040 (1.0) 461-440 .440 (11.2) .050 (1.3) 461-460 .460 (11.7) .060 (1.5) 461-480 .480 (12.2) .070 (1.8) 461-500 .500 (12.7) .080 (2.0) 461-520 .520 (13.2) .090 (2.3) 461-540 .540 (13.7) .100 (2.5) PART NO. H F APPROVED M. C. M. C. M. C. J. C. T 0.110 [2.8mm] 0.100 [2.5mm] TYP. 0.030 [0.8mm] 0.200 [5.1mm] H TYP. F REF. T F .040 (1.0) 0.180 [4.6mm] SQ. 0.125 [3.2mm] T POLARITY KEY .010 (.25) 461-380 DATE 02/23/04 08/27/07 07/23/08 05/21/16 0.06 [1.6mm] Ø.046 [Ø1.2mm] TYP. .340 (8.6) T PART NO. H F 0.050 [1.3mm] .200 (5.1) .025 (.64) 0.100 [2.5mm] 465-210 .210 (5.3) .030 (.76) TYP. 465-220 .220 (5.6) .035 (.89) 465-230 .230 (5.8) .040 (1.0) 465-240 .240 (6.1) .045 (1.1) 462-560 .560 (14.2) .010 (.25) 465-250 .250 (6.4) .050 (1.3) 462-580 .580 (14.7) .020 (.51) 465-260 .260 (6.6) .055 (1.4) 462-600 .600 (15.2) .030 (.76) 465-270 .270 (6.9) .060 (1.5) 462-620 .620 (15.7) .040 (1.0) 465-280 .280 (7.1) .065 (1.7) 462-640 .640 (16.3) .050 (1.3) 465-290 .290 (7.4) .070 (1.8) 462-660 .660 (16.8) .060 (1.5) 465-300 .300 (7.6) .075 (1.9) 462-680 .680 (17.3) .070 (1.8) 465-310 .310 (7.9) .080 (2.0) 462-700 .700 (17.8) .080 (2.0) 465-320 .320 (8.1) .085 (2.2) 462-720 .720 (18.3) .090 (2.3) 465-330 .330 (8.4) .090 (2.3) 462-730 .730 (18.5) .095 (2.4) 465-340 .340 (8.6) .095 (2.4) 462-740 .740 (18.8) .100 (2.5) 465-350 .350 (8.9) .100 (2.5) .540 (13.7) T 465-200 TYP. Ø.032+.003 -.002 TYP. Recommended Mounting Holes .150 (3.8) STANDARD TOLERANCE ® ( UNLESS OTHERWISE SPECIFIED ) DECIMALS .X .XX .XXX 2. MATERIAL: NYLON 6/6, 94V-2, NATURAL. ± .1 ± .01 ± .005 DESIGNED: D. Green 1. GENERAL SPECIFICATIONS: BIVAR MOLDED COMPONENT SPECIFICATION BV00-E101. CHECKED: M. Chen ANGULAR X° ± 1° 4 THOMAS, IRVINE, CA. 92618 TEL: (949) 951-8808 TITLE: DATE: 08/07/03 DATE: 08/07/03 PART NO: FAX: (949) 951-3974 T-1 (3mm) & T-1 3/4 (5mm) INDIVIDUAL LED MOUNTS REVISION: 46X-XXX CAGE CODE : 32559 E SHEET # 1 OF 1 CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING.
461-440 价格&库存
很抱歉,暂时无法提供与“461-440”相匹配的价格&库存,您可以联系我们找货
  • 100+2.73697
  • 500+2.46986
  • 1000+2.19437
  • 10000+1.91888
  • 100+2.67667100+0.34804
  • 500+2.41595500+0.31414
  • 1000+2.146551000+0.27911
  • 10000+1.8771410000+0.24408
