H-178C
H-178C
    BIVAR
    LED HOLDER RA 5MM 2LD NYL BK
H-178C 数据手册
REV. 0.350 [8.9mm] 0.190 [4.8mm] DIA DESCRIPTION D E F G H Engineering Update w / PPA Version Added Engineering Update w / -2 Version Added Updated Part No. Table Obsolete H-17XC-1 Holder Removed Material Code DATE APPROVED 04/18/05 08/16/05 04/11/06 09/27/07 05/28/16 M. C. M. C. M. C. M. C. J. C. 0.130 [3.3mm] 0.100 [2.5mm] 0.030 [0.8mm] SQ. TYP. 0.240 [6.1mm] 0.120 [3.0mm] 0.050 [1.3mm] 0.250 [6.4mm] Holder Faces 0.200 [5.1mm] Ø.032+.003 -.002 TYP. 0.254 [6.5mm] Holder Pitch 0.100 [2.5mm] LED Lead H-175C H-176C H-177C H-178C Recommended Mounting Holes PART NO. DIA H-175C SERIES H-176C SERIES H-177C SERIES H-178C SERIES H-175C H-176C H-177C H-178C .197 [5.0mm] H-175C-2 H-176C-2 H-177C-2 H-178C-2 .206 [5.2mm]+/-0.002" STANDARD TOLERANCE ® ( UNLESS OTHERWISE SPECIFIED ) DECIMALS .X .XX .XXX 2. MATERIAL: NYLON 6/6, 94V-0, BLACK. DESIGNED: 1. GENERAL SPECIFICATIONS: BIVAR MOLDED COMPONENT SPECIFICATION BV00-E101. CHECKED: ± .1 ± .01 ± .005 D. Green M. Chen ANGULAR X° ± 1° DATE: 04/18/03 DATE: 04/18/03 4 THOMAS, IRVINE, CA. 92618 TEL: (949) 951-8808 FAX: (949) 951-3974 TITLE: T-1¾ (5mm) LED HOLDER INTERLOCKING VARIABLE DIAMETER REVISION: PART NO: H-17XC-X CAGE CODE : 32559 H SHEET # 1 OF 1 CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING.
H-178C 价格&库存
很抱歉,暂时无法提供与“H-178C”相匹配的价格&库存,您可以联系我们找货
H-178C
    • 1+7.200001+0.93338
    • 10+2.8765110+0.37290
    • 100+2.59758100+0.33674
    • 1000+2.309931000+0.29945
