H-101C-1
H-101C-1
    BIVAR
H-101C-1 数据手册
REV. DESCRIPTION F Added Note 4 G Updated Note 4 with Table 3 H Remove PPS and GF30 Material J Removed Material Code DATE APPROVED 06/19/09 07/27/10 11/02/11 05/28/16 T. Y. T. Y. T. Y. J. C. 0.25 [6.4mm] 0.17 [4.3mm] 0.078 [2.0mm] B DIA 0.28 [7.2mm] 0.20 [5.1mm] B 0.010 [0.3mm] 0.145 [3.7mm] 0.125 [3.2mm] 0.045 [1.1mm] R.005 [R0.1mm] 0.050 [1.3mm] SECTION B-B 0.025 [0.6mm] 0.080 [2.0mm] REF. 0.050 [1.3mm] REF. PART NO. Holder Faces 0.185 [4.7mm] Ø.032+.003 -.002 TYP. 0.172 [4.4mm] Holder Pitch DIA H-100C .132 (3.4mm) H-100C-1 .150 (3.8mm) H-101C .132 (3.4mm) H-101C-1 .150 (3.8mm) H-102C .132 (3.4mm) H-102C-1 .150 (3.8mm) H-103C .132 (3.4mm) H-103C-1 .150 (3.8mm) 0.100 [2.5mm] LED Lead Recommended Mounting Holes H-100C H-101C H-102C H-103C STANDARD TOLERANCE ® ( UNLESS OTHERWISE SPECIFIED ) DECIMALS .X .XX .XXX 2. MATERIAL 1: NYLON 6/6, 94V-0, BLACK. 1. GENERAL SPECIFICATIONS: BIVAR MOLDED COMPONENT SPECIFICATION BV00-E101. ± .1 ± .01 ± .005 DESIGNED: M. Chen CHECKED: D. Green ANGULAR X° ± 1° 4 THOMAS, IRVINE, CA. 92618 TEL: (949) 951-8808 TITLE: DATE: 01/21/03 DATE: 01/21/03 FAX: (949) 951-3974 T-1 (3mm) LED HOLDER, 90° MOUNT, INTERLOCKING VARIABLE DIAMETER PART NO: REVISION: H-10XC-X CAGE CODE : 32559 J SHEET # 1 OF 1 CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING.
H-101C-1 价格&库存
很抱歉,暂时无法提供与“H-101C-1”相匹配的价格&库存,您可以联系我们找货
