REV.
DESCRIPTION
F Added Note 4
G Updated Note 4 with Table 3
H Remove PPS and GF30 Material
J Removed Material Code
DATE
APPROVED
06/19/09
07/27/10
11/02/11
05/28/16
T. Y.
T. Y.
T. Y.
J. C.
0.25 [6.4mm]
0.17 [4.3mm]
0.078 [2.0mm]
B
DIA
0.28 [7.2mm]
0.20 [5.1mm]
B
0.010 [0.3mm]
0.145 [3.7mm]
0.125 [3.2mm]
0.045 [1.1mm]
R.005 [R0.1mm]
0.050 [1.3mm]
SECTION B-B
0.025 [0.6mm]
0.080 [2.0mm]
REF.
0.050 [1.3mm]
REF.
PART NO.
Holder Faces
0.185 [4.7mm]
Ø.032+.003
-.002
TYP.
0.172 [4.4mm] Holder Pitch
DIA
H-100C
.132 (3.4mm)
H-100C-1
.150 (3.8mm)
H-101C
.132 (3.4mm)
H-101C-1
.150 (3.8mm)
H-102C
.132 (3.4mm)
H-102C-1
.150 (3.8mm)
H-103C
.132 (3.4mm)
H-103C-1
.150 (3.8mm)
0.100 [2.5mm] LED Lead
Recommended Mounting Holes
H-100C
H-101C
H-102C
H-103C
STANDARD TOLERANCE
( UNLESS OTHERWISE SPECIFIED )
DECIMALS
.X
.XX
.XXX
2. MATERIAL 1: NYLON 6/6, 94V-0, BLACK.
1. GENERAL SPECIFICATIONS: BIVAR MOLDED COMPONENT SPECIFICATION BV00-E101.
± .1
± .01
± .005
DESIGNED:
M. Chen
CHECKED:
D. Green
ANGULAR
X°
± 1°
4 THOMAS, IRVINE, CA. 92618
TEL: (949) 951-8808
TITLE:
DATE:
01/21/03
DATE:
01/21/03
FAX: (949) 951-3974
T-1 (3mm) LED HOLDER, 90° MOUNT,
INTERLOCKING VARIABLE DIAMETER
PART NO:
REVISION:
H-10XC-X
CAGE CODE : 32559
J
SHEET # 1 OF 1
CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING.
很抱歉,暂时无法提供与“H-100C”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 100+3.37378100+0.43669
- 国内价格
- 1+9.63031
- 10+3.84254
- 100+3.47721
- 1000+3.08433
- 国内价格 香港价格
- 1+9.428621+1.22040
- 10+3.7627210+0.48703
- 100+3.40478100+0.44070
- 1000+3.020651000+0.39098
