H-131C-1-120
H-131C-1-120
    BIVAR
H-131C-1-120 数据手册
REV. B C D 0.240 [6.1mm] DIA DESCRIPTION Engineering Update w/o Changes Removed Part Numbers Removed Material Code DATE APPROVED 02/26/04 05/08/15 05/28/16 M. C. J. C. J. C. 0.200 [5.1mm] 0.170 [4.3mm] 0.085 [2.2mm] 0.100 [2.5mm] 0.025 [0.6mm] SQ. TYP. L Cathode I.D. Mark 1 (H-13XC-1-XXX) 2 (H-13XC-2-XXX) C/L 0.130 [3.3mm] Holder Faces 0.210 [5.3mm] Ø.032+.003 -.002 TYP. 0.172 [4.4mm] Holder Pitch 0.100 [2.5mm] LED Lead H-130C H-131C H-132C H-133C Recommended Mounting Holes PART NO. ID MARK DIA H-133C-1-120 1 .128 [3.3mm] - H-133C-2-120 2 .150 [3.8mm] H-131C-1-140 H-132C-1-140 H-133C-1-140 1 .128 [3.3mm] - H-131C-2-140 - - 2 .150 [3.8mm] H-130C-1-160 H-131C-1-160 - - 1 .128 [3.3mm] - H-131C-2-160 - - 2 .150 [3.8mm] H-130C-1-180 H-131C-1-180 H-132C-1-180 H-133C-1-180 1 .128 [3.3mm] - H-131C-2-180 - - 2 .150 [3.8mm] H-130C SERIES H-131C SERIES H-132C SERIES H-130C-1-120 H-131C-1-120 H-132C-1-120 H-130C-2-120 H-131C-2-120 H-130C-1-140 H-133C SERIES C/L L .120 [3.0mm] .250 [6.4mm] .140 [3.6mm] .270 [6.9mm] .160 [4.1mm] .290 [7.4mm] .180 [4.6mm] .310 [7.9mm] STANDARD TOLERANCE ® ( UNLESS OTHERWISE SPECIFIED ) DECIMALS .X .XX .XXX 2. MATERIAL: NYLON 6/6, 94V-0, BLACK. DESIGNED: 1. GENERAL SPECIFICATIONS: BIVAR MOLDED COMPONENT SPECIFICATION BV00-E101. CHECKED: ± .1 ± .01 ± .005 M. Chen D. Green ANGULAR X° ± 1° 4 THOMAS, IRVINE, CA. 92618 TEL: (949) 951-8808 FAX: (949) 951-3974 TITLE: T-1 (3mm) LED HOLDER INTERLOCKING VARIABLE CENTERLINE DATE: 01/21/03 DATE: 01/21/03 PART NO: REVISION: H-13XC-X-XXX CAGE CODE : 32559 D SHEET # 1 OF 1 CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING.
H-131C-1-120 价格&库存
很抱歉,暂时无法提供与“H-131C-1-120”相匹配的价格&库存,您可以联系我们找货
H-131C-1-120
  • 1+6.755601+0.87220
  • 10+4.6834010+0.60470
  • 100+3.40180100+0.43920
  • 500+2.83880500+0.36650
  • 1000+2.491401000+0.32170
  • 2500+2.335702500+0.30160
  • 5000+2.180005000+0.28150
  • 10000+2.0602010000+0.26600
  • 25000+1.9285025000+0.24900
库存:106
H-131C-1-120
    • 1+3.84480
    • 200+1.53360
    • 500+1.49040
    • 1000+1.45800
    H-131C-1-120
    • 147+4.34818147+0.56175
    • 500+4.21651500+0.54474
    • 1000+4.092161000+0.52868
    库存:2538
    H-131C-1-120
    • 1+7.357921+0.95059
