H-203C
H-203C
    BIVAR
H-203C 数据手册
REV. B C 0.100 [2.5mm] TYP. DESCRIPTION Engineering Update w/o Changes Removed Material Code 0.320 [8.1mm] DATE APPROVED 02/27/04 05/28/16 M. C. J. C. 0.180 [4.6mm] 0.100 [2.5mm] 0.023 [0.6mm] SQ. TYP. DIA TYP. 0.300 [7.6mm] 0.100 [2.5mm] 0.380 [9.7mm] Cathode I.D. Mark 0.120 [3.0mm] 0.185 [4.7mm] 0.285 [7.2mm] Holder Faces 0.195 [5.0mm] Ø.032+.003 -.002 TYP. 0.100 [2.5mm] 0.182 [4.6mm]Holder Pitch 0.100 [2.5mm] LED Lead Recommended Mounting Holes H-200C PART NO. H-200C SERIES H-201C SERIES H-202C SERIES H-203C SERIES H-201C H-202C H-203C DIA H-200C H-201C H-202C H-203C .128 [3.3mm] H-200C-1 H-201C-1 H-202C-1 H-203C-1 .150 [3.8mm] STANDARD TOLERANCE ® ( UNLESS OTHERWISE SPECIFIED ) DECIMALS .X .XX .XXX 2. MATERIAL: NYLON 6/6, 94V-0, BLACK. DESIGNED: 1. GENERAL SPECIFICATIONS: BIVAR MOLDED COMPONENT SPECIFICATION BV00-E101. CHECKED: ± .1 ± .01 ± .005 D. Green M. Chen ANGULAR X° ± 1° 4 THOMAS, IRVINE, CA. 92618 TEL: (949) 951-8808 FAX: (949) 951-3974 TITLE: BI-LEVEL T-1 (3mm) LED HOLDER INTERLOCKING VARIABLE DIAMETER DATE: 03/13/03 DATE: 03/13/03 PART NO: REVISION: H-20XC-X CAGE CODE : 32559 C SHEET # 1 OF 1 CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING.
H-203C 价格&库存
很抱歉,暂时无法提供与“H-203C”相匹配的价格&库存,您可以联系我们找货
H-203C
