H-180C-LP
H-180C-LP
    BIVAR
    Molded
H-180C-LP 数据手册
REV. B C DESCRIPTION Engineering Update w/o Changes Removed Material Code DATE APPROVED 02/26/04 05/28/16 M. C. J. C. 0.364 [9.3mm] 0.283 [7.2mm] 0.079 [2.0mm] 0.236 [6.0mm] SQ. 0.035 [0.9mm] TYP. 0.079 [2.0mm] 0.118 [3.0mm] 0.050 [1.3mm] 0.181 [4.6mm] 0.335 [8.5mm] 0.335 [8.5mm] Holder Faces 0.100 [2.5mm] Ø.032+.003 -.002 TYP. 0.100 [2.5mm] TYP. Ø.059+.003 -.002 0.200 [5.1mm] 0.050 [1.3mm] 0.138 [3.5mm] Recommended Mounting Holes Ø.055 [Ø1.4mm] STANDARD TOLERANCE ® ( UNLESS OTHERWISE SPECIFIED ) DECIMALS .X .XX .XXX 2. MATERIAL: NYLON 6/6, 94V-0, BLACK. ± .1 ± .01 ± .005 DESIGNED: S. Irving 1. GENERAL SPECIFICATIONS: BIVAR MOLDED COMPONENT SPECIFICATION BV00-E101. CHECKED: M. Chen ANGULAR X° ± 1° 4 THOMAS, IRVINE, CA. 92618 TEL: (949) 951-8808 FAX: (949) 951-3974 TITLE: T-1 (3mm) TRI-LEAD LED HOLDER DATE: 06/24/02 DATE: 06/26/02 PART NO: REVISION: H-180C-LP CAGE CODE : 32559 C SHEET # 1 OF 1 CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING.
H-180C-LP 价格&库存
很抱歉,暂时无法提供与“H-180C-LP”相匹配的价格&库存,您可以联系我们找货
