H-485C
H-485C
    BIVAR
    Molded
H-485C 数据手册
REV. B C 0.200 [5.1mm] 0.100 [2.5mm] DATE APPROVED 02/27/04 05/28/16 M. C. J. C. DESCRIPTION Engineering Update w/o Changes Removed Material Code & P/N Correction 0.535 [13.6mm] 0.075 [1.9mm] 0.373 [9.5mm] 0.445 [11.3mm] 0.273 [6.9mm] 0.173 [4.4mm] 0.073 [1.8mm] 0.190 [4.8mm] 0.150 [3.8mm] Ø.032+.003 -.002 TYP. Holder Faces 0.290 [7.4mm] 0.390 [9.9mm] 0.490 [12.4mm] 0.100 [2.5mm] 0.100 [2.5mm] 0.200 [5.1mm] 0.100 [2.5mm] 0.200 [5.1mm] 0.300 [7.6mm] Recommended Mounting Holes STANDARD TOLERANCE ® ( UNLESS OTHERWISE SPECIFIED ) DECIMALS .X .XX .XXX 2. MATERIAL: NYLON 6/6, 94V-0, BLACK. ± .1 ± .01 ± .005 DESIGNED: S. Irving 1. GENERAL SPECIFICATIONS: BIVAR MOLDED COMPONENT SPECIFICATION BV00-E101. CHECKED: M. Chen ANGULAR X° ± 1° 4 THOMAS, IRVINE, CA. 92618 TEL: (949) 951-8808 FAX: (949) 951-3974 TITLE: QUAD-LEVEL 2mm LED HOLDER DATE: 05/03/99 DATE: 12/10/03 PART NO: REVISION: H-485C CAGE CODE : 32559 C SHEET # 1 OF 1 CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING.
H-485C 价格&库存
很抱歉,暂时无法提供与“H-485C”相匹配的价格&库存,您可以联系我们找货
H-485C
H-485C
H-485C
    • 100+5.82969
    • 500+5.24157
    • 1000+4.66184
    • 10000+4.08330
