H-311C
H-311C
    BIVAR
H-311C 数据手册
REV. B C D DESCRIPTION Engineering Update w/o Changes Typo Correction Removed Material Code TYP. APPROVED M. C. M. C. J. C. 0.170 [4.3mm] 0.450 [11.4mm] 0.100 [2.5mm] DATE 02/27/04 12/07/04 05/28/16 0.122 [3.1mm] 0.025 [0.6mm] SQ. TYP. TYP. Ø.128 [Ø3.3mm] TYP. 0.500 [12.7mm] 0.600 [15.2mm] 0.300 [7.6mm] Cathode I.D. Mark 1 (H-30XC-1-XXX) 2 (H-30XC-2-XXX) 0.100 [2.5mm] 0.175 [4.4mm] 0.275 [7.0mm] 0.375 [9.5mm] 0.130 [3.3mm] Holder Faces 0.185 [4.7mm] Ø.032+.003 -.002 TYP. 0.100 [2.5mm] 0.200 [5.1mm] 0.174 [4.4mm] Holder Pitch 0.100 [2.5mm] LED Lead Recommended Mounting Holes H-310C H-311C H-312C H-313C STANDARD TOLERANCE ® ( UNLESS OTHERWISE SPECIFIED ) DECIMALS .X .XX .XXX 2. MATERIAL: NYLON 6/6, 94V-0, BLACK. ± .1 ± .01 ± .005 DESIGNED: D. Green 1. GENERAL SPECIFICATIONS: BIVAR MOLDED COMPONENT SPECIFICATION BV00-E101. CHECKED: M. Chen ANGULAR X° ± 1° 4 THOMAS, IRVINE, CA. 92618 TEL: (949) 951-8808 TITLE: DATE: 04/10/03 DATE: 04/10/03 FAX: (949) 951-3974 TRI-LEVEL T-1 (3mm) LED HOLDER INTERLOCKING PART NO: REVISION: H-31XC CAGE CODE : 32559 D SHEET # 1 OF 1 CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING.
H-311C 价格&库存
很抱歉,暂时无法提供与“H-311C”相匹配的价格&库存,您可以联系我们找货
