510422
510422
    INDUSTRIALFIBER
    LEDMNTVERTT1-3/42.2MMLP
510422 数据手册
© COPYRIGHT 2012 BY INDUSTRIAL FIBER OPTICS, INC. ALL RIGHTS RESERVED. REVISIONS REV DESCRIPTION A Initial release ECO DATE DWN APVD 1/3/2012 BB AR 3 2.0 .08 " 1.0 .04 " STRIP LENGTH 1 n3.0 n5.0 n7.8 n.20 " n.12 " n.31 " 1.2 MAX .04 " MAX 8.9 .35 " 8.6 .34 " n2.2 4.8 .19 " n.09 " 2 n8.0 CLEARANCE n5.4 n.21 " 5.9 .23 " n.31 " 16.0 .63 " NOTES: 1. RoHS COMPLIANT 2. UL94 HB FLAMMABILITY RATING 3. -40_C TO 85_C OPERATING TEMPERATURE 4. SUITABLE FOR 2.2mm OR 3mm JACKETED LIGHT PIPE WITH A FIBER DIAMETER UP TO 1.5mm 5. DO NOT WAVE SOLDER WITH THIS DEVICE 6. FOR BEST RESULTS USE ONLY NARROW VIEWING ANGLE NON-DIFFUSED LEDS WITH OUTPUT POWER GREATER THAN 100mcd 7. NOT RECOMMENDED FOR DATA COMMUNICATIONS 51 0322 FOR 2.2mm JACKETED FIBER UNLESS OTHERWISE SPECIFIED DIMENSIONS MILLIMETERS [IN.] TOLERANCES 0 PLC: ± 1 1 PLC: ± .25 2 PLC: ± .127 3 PLC: ± .025 4 PLC: ± .013 ANGLE: ± 1/2° METRIC SURFACE 3.2 TEXTURE: REMOVE BURRS AND SHARP EDGES FLATNESS .005mm PER mm ALL DIMENSIONS AFTER FINISH PRODUCT MATERIAL Industrial Fiber Optics DATE CHECKED BY DATE TEMPE, AZ 85281 Black Nylon 6/6 NAME FINISH DRAWN BY 51 0323 FOR 3.0mm JACKETED FIBER T1-3/4 LED Cap B. Bidwell 1/3/2012 A. Reyes 1/3/2012 SIZE A SCALE 2:1 PART NUMBER REV 51 0322 DO NOT SCALE DRAWING A Sheet 1 of 1
510422 价格&库存
很抱歉,暂时无法提供与“510422”相匹配的价格&库存,您可以联系我们找货
