REV.
ITEM
Q'TY
1
1
H-178C-3
T-1¾ (5mm) Single-Level Tri-Lead LED Holder, 90° Mount
2
1
5BC-3-XXXX-F
T-1¾ (5mm) Bi-Color/Tri-Color Flanged LED, See Page 2
PART DESCRIPTION
PART NUMBER
1
B
C
D
E
DESCRIPTION
Corrected Typo H178CBC-3-B from
"Yellow/HE Red" to "Green/HE Red"
LED Protrusion Tolerance Update
Obsolete H178CBC-3-B & H178CBC-3-Y/G-B
Engineering Update w/o Changes
2
R.150 [R3.8mm]
0.290 [7.4mm]
APPROVED
09/17/04
M. C.
04/27/05
09/24/08
06/20/16
M. C.
M. C.
J. C.
0.248±0.015
0.374 [9.5mm]
0.280 [7.1mm]
0.300 [7.6mm]
Holder Face
DATE
Ø.197 [Ø5.0mm]
Ø.032+.003
TYP. -.002
0.300 [7.6mm]
0.150 [3.8mm]
0.100 [2.5mm]
LED Lead
0.156 [4.0mm]
(1) (2) (3)
Recommended Mounting Holes
0.290 [7.4mm]
0.020 [0.5mm]
0.100 [2.5mm]
TYP.
SQ. TYP.
Fig. 1
Fig. 2
(2) Common Cathode
(2) Common Anode
(1) Anode
(3) Anode
(1) Cathode
(3) Cathode
Red
Yellow
Red
Green
Green
Yellow
Red
Yellow
Red
Green
Green
Yellow
ABSOLUTE MAXIMUM RATINGS (Ta=25° C)
REVERSE VOLTAGE
REVERSE CURRENT
OPERATING TEMPERATURE RANGE
STANDARD TOLERANCE
DECIMALS
.X
.XX
.XXX
± .1
± .02
± .010
DESIGNED:
STORAGE TEMPERATURE
LEAD SOLDERING TEMPERATURE(1/16" FROM BODY)
( UNLESS OTHERWISE SPECIFIED )
T. Yin
CHECKED:
D. Green
ANGULAR
X°
± 1°
DATE:
03/05/04
DATE:
03/05/04
4 THOMAS, IRVINE, CA. 92618
TEL: (949) 951-8808
FAX: (949) 951-3974
TITLE: T-1¾ (5MM) BI-COLOR 3 LEAD
90° SINGLE-LEVEL LED ASSY
REVISION:
PART NO:
H178CBC-3-XXXX
CAGE CODE : 32559
E
SHEET # 1 OF 2
CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING.
REV.
DATE
DESCRIPTION
APPROVED
SEE SHEET #1
LED Assy. No.
Peak Wave
Length
λp(nm )
Em itted
Color
H178CBC-3
(Fig. 1)
625
HE RED
568
GREEN
H178CBC-3-Y/G
(Fig. 1)
590
YELLOW
568
GREEN
H178CBC-3-CA
(Fig. 2)
625
HE RED
568
GREEN
H178CBC-3-Y/G-CA
(Fig. 2)
590
YELLOW
568
GREEN
Lens
Appearance
WHITE DIFFUSED
WHITE DIFFUSED
WHITE DIFFUSED
WHITE DIFFUSED
Abs. Max.
Rating
Electro-Optical
Data @ 20m A
Iv
Vf
(m cd)
(V)
If
(m A)
TYP
MAX
TYP
30
2.0
2.8
35
30
2.1
2.8
35
30
2.0
2.8
30
30
2.1
2.8
35
30
2.0
2.8
4
30
2.1
2.8
6
30
2.0
2.8
4
30
2.1
2.8
6
View ing
Angle
2 ½
(Deg)
LED P/N
40
5BC-3-F
40
5BC-3-Y/G-F
40
5BC-3-CA-F
40
5BC-3-Y/G-CA-F
STANDARD TOLERANCE
±10% ALL VALUES
ANGULAR
TEL: (949) 951-8808
DESIGNED:
T. Yin
CHECKED:
D. Green
DATE:
03/05/04
DATE:
03/05/04
FAX: (949) 951-3974
REVISION:
PART NO:
H178CBC-3-XXXX
CAGE CODE : 32559
E
SHEET # 2 OF 2
很抱歉,暂时无法提供与“H178CBC-3”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+10.468221+1.35600
- 5+8.810755+1.14130
- 25+7.2056325+0.93338
- 100+5.67029100+0.73450
- 500+5.60050500+0.72546
- 1000+5.495821000+0.71190
- 2000+5.356242000+0.69382
- 国内价格 香港价格
- 14+58.0476614+7.51921
- 25+44.6508125+5.78384
- 50+33.3518250+4.32023
- 100+18.79520100+2.43464
- 250+18.28047250+2.36796
- 500+17.79331500+2.30486
