HT5-GRN-T
HT5-GRN-T
    BIVAR
    发光二极管/LED 翠绿色 25mcd
HT5-GRN-T 数据手册
ITEM Q'TY REV. PART DESCRIPTION PART NUMBER 1 1 HT5 T1 3/4 (5mm) High Temperature Single Level Holder, 90° Mount 2 1 BDL-XXXX T1 3/4 (5mm) N-Flange LED, See Page 2 0.250 [6.4mm] Ø0.197 [Ø5.0mm] LED 0.205 [5.2mm] 1 2 B C DESCRIPTION Engineering Release Engineering Update w/o Changes DATE APPROVED 04/19/11 06/25/16 T. Y. J. C. 0.350 [8.9mm] 0.190 [4.8mm] 0.260 [6.6mm] 0.050 [1.3mm] 0.005 [0.1mm] 0.135 [3.4mm] 1 2 POLARITY ID 0.100 [2.5mm] 0.040 [1.0mm] 2X Red Cathode 2 0.230 [5.8mm] 2 2 1 (0.041 [1.0mm]) 1 1 Green Cathode Single Color HT5-BC-T Recommended Soldering Pattern ABSOLUTE MAXIMUM RATINGS (Ta=25° C) REVERSE VOLTAGE REVERSE CURRENT OPERATING TEMPERATURE RANGE STANDARD TOLERANCE ® ( UNLESS OTHERWISE SPECIFIED ) DECIMALS .X .XX .XXX STORAGE TEMPERATURE DESIGNED: LEAD SOLDERING TEMPERATURE(1/16" FROM BODY) CHECKED: ± .1 ± .02 ± .010 R. Paje T. Yin ANGULAR X° ± 1° 4 THOMAS, IRVINE, CA. 92618 TEL: (949) 951-8808 TITLE: DATE: 04/26/10 DATE: 04/26/10 FAX: (949) 951-3974 T1 3/4 (5mm) SMT 90° SURFACE MOUNT LED, TAPE AND REEL PART NO: REVISION: HT5-XXX-T CAGE CODE : 32559 C SHEET # 1 OF 3 CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING. REV. DATE DESCRIPTION APPROVED SEE SHEET #1 AVAILABLE CONFIGURATIONS Assy P/N Em itted Color Peak Wave Length λp(nm ) Lens Appearance Absolute Max. Ratings Pd (m W) If (m A) Peak If (m A) MAX TYP View ing Angle 2 θ½ (Deg) Vf (V) TYP Iv (m cd) LED P/N STANDARD SINGLE COLOR LED ASSEMBLIES (20m A) 150 25 70 4.0 4.5 15 45 BDL-1363 80 30 150 2.1 2.8 25 45 BDL-1360 625 80 30 150 2.0 2.8 25 45 BDL-1361 590 85 30 150 2.0 2.8 25 45 BDL-1362 45 BDL-1359 HT5-BLU-T BLUE 430 HT5-GRN-T GREEN 568 HT5-RED-T HE RED HT5-YEL-T YELLOW DIFFUSED STANDARD BI-COLOR LED ASSEMBLIES (20m A) HT5-BC-T RED 625 GREEN 568 WHITE DIFFUSED 80 30 150 2.0 2.8 6 80 30 150 2.1 2.8 8 CONVECTIVE REFLOW SOLDERING PROFILE 300 MAX LEAD FREE SOLDERING TEMP, 255°C - 5 SEC 250 MAX LEADED SOLDERING TEMP, 220°C - 5 SEC 200 T (°C) 150 140°C to 170°C 20 - 70 SECONDS ABOVE LIQUIDOUS 100 50 STANDARD TOLERANCE ® ( UNLESS OTHERWISE SPECIFIED ) PREHEAT PREFLOW PREFLOW COOLDOWN DECIMALS ANGULAR 4 THOMAS, IRVINE, CA. 92618 TEL: (949) 951-8808 0 TITLE: 0 25 50 75 100 125 150 175 200 225 250 275 300 325 350 375 400 t (sec.) DESIGNED: R. Paje CHECKED: T. Yin DATE: 04/26/10 DATE: 04/26/10 FAX: (949) 951-3974 T1 3/4 (5mm) SMT 90° SURFACE MOUNT LED, TAPE AND REEL PART NO: REVISION: HT5-XXX-T CAGE CODE : 32559 C SHEET # 2 OF 3 CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING. REV. DATE DESCRIPTION APPROVED SEE SHEET #1 0.157 [4.0mm] TYP. 0.236 [6.0mm] TYP. Ø0.059 [Ø1.5mm] TYP. 0.106 [2.7mm] 0.069 [1.8mm] 0.100 [2.5mm] 0.424 [10.8mm] 0.680 [17.3mm] 0.945 [24.0mm] 0.600 [15.2mm] 2 1 2 Ø0.060 [Ø1.5mm] TYP. 2 SINGLE 1 COLOR 0.018 [0.45mm] 0.280 [7.1mm] 1 HT5-BC-T 0.280 [7.1mm] TYP. 0.472 [12.0mm] TYP. 0.365 [9.3mm] TYP. STANDARD TOLERANCE ® ( UNLESS OTHERWISE SPECIFIED ) FEED DIRECTION NOTES: 2. UNLESS OTHERWISE SPECIFIED, PACKAGING TO COMPLY WITH EIA-481-D. 1. 750 pcs PER REEL DECIMALS .X .XX .XXX ± .1 ± .02 ± .010 DESIGNED: R. Paje CHECKED: T. Yin ANGULAR X° ± 1° 4 THOMAS, IRVINE, CA. 92618 TEL: (949) 951-8808 TITLE: DATE: 04/26/10 DATE: 04/26/10 FAX: (949) 951-3974 T1 3/4 (5mm) SMT 90° SURFACE MOUNT LED, TAPE AND REEL PART NO: REVISION: HT5-XXX-T CAGE CODE : 32559 C SHEET # 3 OF 3 CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING.
HT5-GRN-T 价格&库存
很抱歉,暂时无法提供与“HT5-GRN-T”相匹配的价格&库存,您可以联系我们找货
