H178CRD
H178CRD
    BIVAR
    插件
    发光二极管/LED 红色 插件 2mcd
H178CRD 数据手册
PART NUMBER REV. PART DESCRIPTION ITEM Q'TY 1 1 H-178C-2 T-1¾ (5mm) LED Holder, 90° Mount 2 1 5XX T-1¾ (5mm) Non-Flange LED, See Page 2 1 D E F G H DESCRIPTION Updated LED Protrusion from .215 to .200 Corrected Typo Updated Specs, Page 2 Added 5UUYC LED Engineering Update w/o Changes DATE APPROVED 01/09/07 02/13/07 02/10/09 03/25/10 06/20/16 M. C. M. C. T. Y. T. Y. J. C. 2 0.200 [5.1mm] 0.350 [8.9mm] 0.250 [6.4mm] Ø.206 [Ø5.2mm] H-178C-2 0.190 [4.8mm] Ø.197 [Ø5.0mm] LED 0.240 [6.1mm] 0.120 [3.0mm] 0.157 [4.0mm] 0.100 [2.5mm] 0.200 [5.1mm] 0.020 [0.5mm] SQ. TYP. Holder Faces 0.200 [5.1mm] Ø.032+.003 -.002 TYP. 0.100 [2.5mm] LED Lead Recommended Mounting Holes ABSOLUTE MAXIMUM RATINGS (Ta=25° C) REVERSE VOLTAGE REVERSE CURRENT OPERATING TEMPERATURE RANGE STORAGE TEMPERATURE LEAD SOLDERING TEMPERATURE(1/16" FROM BODY) STANDARD TOLERANCE ® ( UNLESS OTHERWISE SPECIFIED ) DECIMALS .X .XX .XXX ± .1 ± .02 ± .010 DESIGNED: T. Yin CHECKED: D. Green ANGULAR X° ± 1° 4 THOMAS, IRVINE, CA. 92618 TEL: (949) 951-8808 FAX: (949) 951-3974 TITLE: DATE: 03/05/04 DATE: 03/05/04 T-1¾ (5MM) 90° SINGLE-LEVEL LED ASSY REVISION: PART NO: H178CXX CAGE CODE : 32559 H SHEET # 1 OF 2 CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING. REV. DATE DESCRIPTION APPROVED SEE SHEET #1 Electro-Optical Data LED Assy. No. Peak Wave Length λp(nm ) Em itted Color Lens Appearance If (m A) TYP STANDARD Iv (m cd) Vf (V) TYP MAX TYP View ing Angle 2 ½ (Deg) LED P/N Data @ 20m A H178CBWD 430 BLUE DIFFUSED 20 4.0 4.5 15 45 5BWD H178CGD 568 GREEN DIFFUSED 20 2.1 2.8 25 45 5GD H178CSGD 568 GREEN DIFFUSED 20 2.1 2.8 30 45 5SGD H178CSUGC 570 GREEN WATER CLEAR 20 2.1 2.4 400 35 5SUGC H178CYD 590 YELLOW DIFFUSED 20 2.0 2.8 25 45 5YD H178CSYD 590 YELLOW DIFFUSED 20 2.0 2.4 300 45 5SYD H178CUUYC 590 YELLOW WATER CLEAR 20 2.0 2.4 500 35 5UUYC H178CAD 605 AMBER DIFFUSED 20 2.0 2.8 25 45 5AD H178CHD 625 HE RED DIFFUSED 20 2.0 2.8 25 45 5HD H178CRD 700 RED DIFFUSED 20 2.1 2.8 2 45 5RD H178CSRD 645 RED DIFFUSED 20 1.7 2.4 40 45 5SRD LOW CURRENT Data @ 2m A H178CGDL 568 GREEN DIFFUSED 2 2.1 2.6 5 45 5GDL H178CYDL 590 YELLOW DIFFUSED 2 2.0 2.6 4 45 5YDL H178CHDL 625 HE RED DIFFUSED 2 2.0 2.6 5 45 5HDL 5 VOLT Data @ 5V H178CGD5V 568 GREEN DIFFUSED 10 - 5.0 25 45 5GD5V H178CYD5V 590 YELLOW DIFFUSED 10 - 5.0 20 45 5YD5V H178CHD5V 625 HE RED DIFFUSED 10 - 5.0 50 45 5HD5V STANDARD TOLERANCE ® ( UNLESS OTHERWISE SPECIFIED ) ±10% ALL VALUES ANGULAR 4 THOMAS, IRVINE, CA. 92618 TEL: (949) 951-8808 FAX: (949) 951-3974 TITLE: DESIGNED: T. Yin CHECKED: D. Green DATE: 03/05/04 DATE: 03/05/04 T-1¾ (5MM) 90° SINGLE-LEVEL LED ASSY REVISION: PART NO: H178CXX CAGE CODE : 32559 H SHEET # 2 OF 2 CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING.
H178CRD 价格&库存
很抱歉,暂时无法提供与“H178CRD”相匹配的价格&库存,您可以联系我们找货
