FLPV6.0-SBC
FLPV6.0-SBC
    BIVAR
    插件
    发光二极管/LED 红色,翠绿色 插件 50mcd,100mcd
FLPV6.0-SBC 数据手册
PART NUMBER REV. ITEM Q'TY PART DESCRIPTION 1 1 FLPV-XX Flexible Light Pipe Adapter,Vertical, w/LED, See page 2 & 3. 2 1 LC-XX.X Flexible Light Pipe Lens Cap Assembly NOTE: FLPV-XX ADAPTER SHIPPED NON-ASSEMBLED G H J K L M N DESCRIPTION Updated FLPC Hidden View Updated White Assy P/N Updated Table For Length "L" Replace 3UWC-0.6K-F With 3UWC1.035C-F Updated LED Optical Characteristics Updated LED Tables Updated LED Tables DATE APPROVED 08/27/08 12/03/10 11/14/12 04/08/13 09/15/15 08/15/18 11/13/18 M. C. T. Y. T. Y. T. Y. J. C. M. C. M. C. 0.320 [8.1mm] L SEE TABLE 1 0.025 [0.6mm] 0.240 [6.1mm] 0.210 [5.3mm] 0.495 [12.6mm] 0.145 [3.7mm] TABLE 1 2 " L "* 1 0.100 [2.5mm] Tolerance 1.0" ~ 16.0" 16.1" ~ 40.0" 40.1" ~ 80.0" 80.1" ~ 3,940.0" * Available in 0.1" increments only SINGLE COLOR LED SHORT LEAD CATHODE +.003 -.002 BI-COLOR LED'S +.003 -.002 Recommended Mounting Holes SHORT LEAD CATHODE RED YELLOW LED PART NO. 3xBCC-F 3BC-Y/G-F LONG LEAD CATHODE GREEN GREEN 0.100 [2.5mm] RECOMMENDED FOOTPRINT STANDARD TOLERANCE (UNLESS OTHERWISE SPECIFIED) DECIMALS ANGULAR 4 THOMAS, IRVINE, CA. 92618 TEL: (949) 951-8808 REVERSE VOLTAGE REVERSE CURRENT OPERATING TEMPERATURE RANGE DESIGNED: D. GREEN REVISED: STORAGE TEMPERATURE LEAD SOLDERING TEMPERATURE(1/16" FROM BODY) K. BARON CHECKED: TD. NGUYEN DATE: FLPVX.X-XX 06/09/03 DATE: 11/13/18 N CAGE CODE: 11/13/18 DATE: FAX: (949) 951-3974 TITLE: FLEXIBLE LIGHT-PIPE ASSY VERTICAL, 3mm LENS CAP W/LED REVISION: PART NO: 32559 SCALE: NONE SHEET # 1 OF CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING 3 REV. DESCRIPTION DATE APPROVED See Sheet 1 VISIT WWW.BIVAR.COM FOR CURRENT LED DATASHEETS LED DETAILS ON DATASHEETS TAKE PRECEDENCE OVER DETAILS SHOWN HERE FLEXIBLE LIGHT PIPE SERIES Emitted Colors "L" LENGTH, inches available in 0.1" increments only e.g. 6.0, 11.5 REVISION: PART NO: FLPVX.X-XX SCALE: N SHEET # 2 OF 3 CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING VISIT WWW.BIVAR.COM FOR CURRENT LED DATASHEETS LED DETAILS ON DATASHEETS TAKE PRECEDENCE OVER DETAILS SHOWN HERE FLEXIBLE LIGHT PIPE SERIES Emitted Colors "L" LENGTH, inches available in 0.1" increments only e.g. 6.0, 11.5 REVISION: PART NO: FLPVX.X-XX SCALE: N SHEET # 3 OF 3 CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING
FLPV6.0-SBC 价格&库存
很抱歉,暂时无法提供与“FLPV6.0-SBC”相匹配的价格&库存,您可以联系我们找货
