H101CBC
H101CBC
    BIVAR
    插件
    发光二极管/LED 红色,翠绿色 插件 30mcd,30mcd
H101CBC 数据手册
REV. ITEM Q'TY 1 1 H-101C T-1 (3mm) LED Holder, 90° Mount 2 1 3BC-XX T-1 (3mm) N-Flange Bi-Color LED, See Page 2 PART NUMBER PART DESCRIPTION DESCRIPTION A Engineering Update w/o Changes B Engineering Update w/o Changes 1 2 DATE APPROVED 03/05/04 06/20/16 M. C. J. C. 0.091 [2.3mm] 0.250 [6.4mm] 0.170 [4.3mm] Ø.118 [Ø3.0mm] 0.285 [7.2mm] 0.200 [5.1mm] Cathode I.D. Mark 0.100 [2.5mm] GREEN CATHODE 0.157 [4.0mm] 0.020 [0.5mm] SQ. TYP. RED,YELLOW CATHODE 0.185 [4.7mm] 0.185 [4.7mm] Holder Face 0.100 [2.5mm] LED Lead Ø.032+.003 -.002 TYP. Recommended Mounting Holes ABSOLUTE MAXIMUM RATINGS (Ta=25° C) REVERSE VOLTAGE REVERSE CURRENT OPERATING TEMPERATURE RANGE STANDARD TOLERANCE DECIMALS .X .XX .XXX ± .1 ± .02 ± .010 DESIGNED: STORAGE TEMPERATURE LEAD SOLDERING TEMPERATURE(1/16" FROM BODY) ® ( UNLESS OTHERWISE SPECIFIED ) S. Irving CHECKED: A. Vilgiate ANGULAR X° ± 1° 4 THOMAS, IRVINE, CA. 92618 TEL: (949) 951-8808 FAX: (949) 951-3974 T-1 (3MM) BI-COLOR 90° SINGLE-LEVEL LED ASSY REVISION: PART NO: TITLE: DATE: 03/05/04 DATE: 03/05/04 H101CBC-XX CAGE CODE : 32559 B SHEET # 1 OF 2 CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING. REV. DATE DESCRIPTION APPROVED SEE SHEET #1 LED Assy. No. H101CBC H101CBC-Y/G Peak Wave Length λ p(nm) 635 568 585 568 Emitted Color HE RED GREEN YELLOW GREEN Lens Appearance Abs. Max. Rating If (mA) 30 WHITE DIFFUSED 30 30 WHITE DIFFUSED 30 Electro-Optical Data @ 20ma Vf (V) Typ. 2.0 2.2 2.1 2.2 Max. 2.6 2.6 2.6 2.6 Iv (mcd) Typ. 30.0 30.0 15.0 30.0 Viewing Angle 2 ½ (Deg) LED P/N 45 3BC 45 3BC-Y/G STANDARD TOLERANCE ® ( UNLESS OTHERWISE SPECIFIED ) ±10% ALL VALUES ANGULAR 4 THOMAS, IRVINE, CA. 92618 TEL: (949) 951-8808 FAX: (949) 951-3974 TITLE: DESIGNED: T. Yin CHECKED: D. Green DATE: 03/05/04 DATE: 03/05/04 T-1 (3MM) BI-COLOR 90° SINGLE-LEVEL LED ASSY REVISION: PART NO: H101CBC-XX CAGE CODE : 32559 B SHEET # 2 OF 2 CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING.
H101CBC 价格&库存
很抱歉,暂时无法提供与“H101CBC”相匹配的价格&库存,您可以联系我们找货
H101CBC
  • 1+9.75967
  • 10+7.14727
  • 40+5.90276
  • 100+5.24756
  • 125+5.10263
  • 300+4.60913
  • 500+4.35879
  • 1000+4.06773
  • 2000+3.91321
库存:190
H101CBC
  • 1+10.495451+1.36391
  • 10+7.6868110+0.99892
  • 40+6.3477140+0.82490
  • 100+5.64337100+0.73337
  • 125+5.48685125+0.71303
  • 300+4.95643300+0.64410
  • 500+4.68687500+0.60907
  • 1000+4.373831000+0.56839
  • 2000+4.208622000+0.54692
库存:190
