ELM75MM3RD
ELM75MM3RD
    BIVAR
    发光二极管/LED 红色 2mcd
ELM75MM3RD 数据手册
PART NUMBER ITEM Q'TY 1 1 3XX-F T-1 (3mm) Flanged LED, See Page 2 2 1 ELM 7-XXX Extruded, Self-Retaining LED Spacer REV. PART DESCRIPTION B C D E F G H 1 SHORT LEAD Flat Edge Cathode ID REVERSE CURRENT OPERATING TEMPERATURE RANGE M. C. M. C. M. C. T. Y. T. Y. T. Y. J. C. 0.100 [2.5mm] 0.100 [2.5mm] 0.120 [3.0mm] Spacer Dia. 0.020 [0.5mm] SQ. Recommended Mounting Holes MIN. ABSOLUTE MAXIMUM RATINGS (Ta=25° C) REVERSE VOLTAGE APPROVED Ø.032+.003 TYP.-.002 L Ø.150 [Ø3.8mm] Flange Dia. LED Dia. DATE 04/05/06 08/22/06 09/03/08 06/07/11 11/21/11 09/24/13 05/25/16 2 0.207 [5.3mm] Ø.118 [Ø3.0mm] DESCRIPTION Changed "L" Dimemsion Update LED, EMN-ELMXXXX3XX Removed Tolerance Note. Added Tape & Reel Options. Tape & Reel Design Update. Corrected P/N Typo in BOM. Engineering Update w/o Changes STANDARD TOLERANCE ® ( UNLESS OTHERWISE SPECIFIED ) DECIMALS .X .XX .XXX STORAGE TEMPERATURE DESIGNED: LEAD SOLDERING TEMPERATURE(1/16" FROM BODY) CHECKED: ± .1 ± .02 ± .010 D. Green T. Yin ANGULAR X° ± 1° 4 THOMAS, IRVINE, CA. 92618 TEL: (949) 951-8808 FAX: (949) 951-3974 TITLE: EXTRUDED VERTICAL T-1 (3mm) LED STANDARD PROFILE SPACER ASSY DATE: 12/23/04 DATE: 12/23/04 PART NO: REVISION: ELM7XXX3XX CAGE CODE : 32559 H SHEET # 1 OF 3 CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING. REV. DATE DESCRIPTION APPROVED SEE SHEET #1. LED Assy. No. STANDARD ELM7XXX3BWD ELM7XXX3GD ELM7XXX3YD ELM7XXX3HD ELM7XXX3RD ELM7XXX3SRD LOW CURRENT ELM7XXX3GDL ELM7XXX3YDL ELM7XXX3HDL 5 VOLT ELM7XXX3GD5V ELM7XXX3YD5V ELM7XXX3HD5V Electro-Optical Data Peak Wave Length λ p(nm ) Em itted Color Lens Appearance 430 565 585 635 655 660 BLUE GREEN YELLOW HE RED RED SUPER RED DIFFUSED DIFFUSED DIFFUSED DIFFUSED DIFFUSED DIFFUSED 565 585 635 GREEN YELLOW HE RED DIFFUSED DIFFUSED DIFFUSED 565 585 635 GREEN YELLOW HE RED DIFFUSED DIFFUSED DIFFUSED View ing Angle Vf 2 ½ If Iv (V) (m A) (m cd) (Deg) TYP TYP MAX TYP Data @ 20m A 20 4.0 4.5 20.0 45 20 2.2 2.6 30.0 45 20 2.1 2.6 20.0 45 20 2.0 2.6 30.0 45 20 1.7 2.0 6.0 45 20 1.7 2.6 90.0 45 Data @ 2m A 5 1.9 2.2 6.0 45 5 1.9 2.2 4.0 45 5 1.8 2.2 6.0 45 Data @ 5V 8 5.0 30.0 45 8 5.0 20.0 45 8 5.0 30.0 45 LED P/N 3BWD-F 3GD-F 3YD-F 3HD-F 3RD-F 3SRD-F 3GDL-F 3YDL-F 3HDL-F 3GD5V-F 3YD5V-F 3HD5V-F STANDARD TOLERANCE ® ( UNLESS OTHERWISE SPECIFIED ) ±10% ALL VALUES ANGULAR 4 THOMAS, IRVINE, CA. 92618 TEL: (949) 951-8808 FAX: (949) 951-3974 TITLE: EXTRUDED VERTICAL T-1 (3mm) LED STANDARD PROFILE SPACER ASSY DESIGNED: D. Green CHECKED: T. Yin DATE: 12/23/04 DATE: 12/23/04 PART NO: REVISION: ELM7XXX3XX CAGE CODE : 32559 H SHEET # 2 OF 3 CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING. REV. DATE DESCRIPTION APPROVED SEE SHEET #1 0.250 [6.4mm] TYP. 0.500 [12.7mm] TYP. 0.709 [18.0mm] CARBOARD REEL (.020" THICK) 0.650 + XXX* XXX* = ELM SPACER HEIGHT 0.650 [16.5mm] 0.511 [13.0mm] MASKING TAPE Ø.158 [Ø4.0mm] TYP. 0.100 [2.5mm] TYP. 0.500 [12.7mm] TYP. LONG LEAD ANODE TYP. 0.058 [1.5mm] MAX. DIRECTION OF FEED LABEL 16.5 [420mm] REF. 14" X 2" REEL 13.5 [345mm] REF. 2.5 [63.5mm] REF. STANDARD PACKAGING TRAY TAPE & REEL 1,000 pcs / reel AMMO PACK 2,000 pcs / box STANDARD TOLERANCE ® ( UNLESS OTHERWISE SPECIFIED ) DECIMALS NOTE: 1. STANDARD PART NUMBERS ARE PACKAGED IN LOOSE PIECES USING PACKAGING TRAYS 2. ADD "T" SUFFIX TO PART NUMBER FOR TAPE AND REEL PACKAGING OPTION (1,000 PCS/REEL) 3. ADD "A" SUFFIX TO PART NUMBER FOR AMMO PACK OPTION (2,000 PCS/BOX) 4. TAPE AND REEL PACKAGING COMPLY TO EIA-468-C .X .XX .XXX ± .1 ± .02 ± .010 DESIGNED: D. Green CHECKED: T. Yin ANGULAR X° ± 1° 4 THOMAS, IRVINE, CA. 92618 TEL: (949) 951-8808 FAX: (949) 951-3974 TITLE: EXTRUDED VERTICAL T-1 (3mm) LED STANDARD PROFILE SPACER ASSY DATE: 12/23/04 DATE: 12/23/04 PART NO: REVISION: ELM7XXX3XX CAGE CODE : 32559 H SHEET # 3 OF 3 CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING.
ELM75MM3RD 价格&库存
很抱歉,暂时无法提供与“ELM75MM3RD”相匹配的价格&库存,您可以联系我们找货
ELM75MM3RD
    • 1+5.24880
    • 200+2.09520
    • 500+2.03040
    • 1000+1.99800
