ELM22003RD
ELM22003RD
    BIVAR
    发光二极管/LED 红色 2mcd
ELM22003RD 数据手册
REV. DESCRIPTION D E F G H J K L M LED Specs and Dimensions Update Added Tape & Reel Options Tape & Reel Design Update LED Offering List Update Corrected LED Typo Corrected P/N Typo in BOM Updated LED Optical Characteristics Updated per EOL Notice ECO-1074 Corrected Standard Tolerance APPROVED T. Y. T. Y. T. Y. T. Y. T. Y. T. Y. J. C. A. V. A. V. 1.00 [25.4mm] REF. 0.210 [5.3mm] FLAT EDGE ID L Spacer Dia. 2. SHORT LEAD 2 2 1 1 Single Color Bi-Color 2 1 0.100 [2.5mm] LED Flange Dia. 1. LONG LEAD LED Dia. DATE 07/22/10 06/06/11 11/21/11 07/27/12 08/09/13 09/19/13 09/12/15 06/29/20 09/22/20 0.031 [0.8mm] 0.020 [0.5mm] SQ. MIN. BI-COLOR POLARITY (1) Cathode (2) Cathode LED P/N 3BC-F Green Red 3BC-Y/G-F Green Yellow +.003 TYP.-.002 0.100 [2.5mm] Recommended Mounting Holes CUSTOMER USE DRAWING STANDARD TOLERANCE (UNLESS OTHERWISE SPECIFIED) ABSOLUTE MAXIMUM RATINGS (Ta=25 C) DECIMALS ANGULAR 4 THOMAS, IRVINE, CA. 92618 TEL: (949) 951-8808 REVERSE VOLTAGE EXTRUDED VERTICAL T-1 (3mm) LED STANDARD PROFILE SPACER ASSY REVERSE CURRENT DESIGNED: OPERATING TEMPERATURE RANGE FAX: (949) 951-3974 TITLE: Minh Doan STORAGE TEMPERATURE REVISED: LEAD SOLDERING TEMPERATURE(1/16" FROM BODY) CHECKED: V. Chavez A. Valdez DATE: 07/27/12 DATE: 09/21/20 DATE: 09/21/20 PART NO: SHEET SIZE SCALE: REVISION: ELM2XXX3XX A N/A M CAGE CODE: 32559 SHEET # 1 OF CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING 4 REV. DESCRIPTION DATE APPROVED SEE SHEET #1. CUSTOMER USE DRAWING CAGE CODE 32559 SHEET SIZE A REVISION: DRAWING NO: ELM2XXX3XX SCALE: M SHEET # 2 OF 4 CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING REV. DESCRIPTION DATE APPROVED SEE SHEET #1. CUSTOMER USE DRAWING CAGE CODE 32559 SHEET SIZE A REVISION: DRAWING NO: ELM2XXX3XX SCALE: M SHEET # 3 OF 4 CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING REV. DESCRIPTION DATE APPROVED SEE SHEET #1. 0.250 [6.4mm] TYP. 0.500 [12.7mm] TYP. 0.709 [18.0mm] CARBOARD REEL (.020" THICK) 0.650 + XXX* XXX* = ELM SPACER HEIGHT 0.650 [16.5mm] 0.511 [13.0mm] MASKING TAPE TYP. 0.100 [2.5mm] TYP. 0.500 [12.7mm] TYP. LONG LEAD ANODE TYP. 0.058 [1.5mm] MAX. DIRECTION OF FEED LABEL 16.5 [420mm] REF. 14" X 2" REEL 13.5 [345mm] REF. 2.5 [63.5mm] REF. STANDARD PACKAGING TRAY TAPE & REEL 1,000 pcs / reel NOTE: 1. STANDARD PART NUMBERS ARE PACKAGED IN LOOSE PIECES USING PACKAGING TRAYS 2. ADD "T" SUFFIX TO PART NUMBER FOR TAPE AND REEL PACKAGING OPTION (1,000 PCS/REEL) 3. ADD "A" SUFFIX TO PART NUMBER FOR AMMO PACK OPTION (2,000 PCS/BOX) 4. TAPE AND REEL PACKAGING COMPLY TO EIA-468-C AMMO PACK 2,000 pcs / box CUSTOMER USE DRAWING CAGE CODE 32559 SHEET SIZE A REVISION: DRAWING NO: ELM2XXX3XX SCALE: M SHEET # 4 OF 4 CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING
ELM22003RD 价格&库存
很抱歉,暂时无法提供与“ELM22003RD”相匹配的价格&库存,您可以联系我们找货
