REV.
DESCRIPTION
D
E
F
G
H
J
K
L
M
LED Specs and Dimensions Update
Added Tape & Reel Options
Tape & Reel Design Update
LED Offering List Update
Corrected LED Typo
Corrected P/N Typo in BOM
Updated LED Optical Characteristics
Updated per EOL Notice
ECO-1074 Corrected Standard Tolerance
APPROVED
T. Y.
T. Y.
T. Y.
T. Y.
T. Y.
T. Y.
J. C.
A. V.
A. V.
1.00 [25.4mm]
REF.
0.210 [5.3mm]
FLAT EDGE ID
L
Spacer Dia.
2. SHORT LEAD
2
2
1
1
Single
Color
Bi-Color
2
1
0.100 [2.5mm]
LED Flange Dia.
1. LONG LEAD
LED Dia.
DATE
07/22/10
06/06/11
11/21/11
07/27/12
08/09/13
09/19/13
09/12/15
06/29/20
09/22/20
0.031 [0.8mm]
0.020 [0.5mm] SQ.
MIN.
BI-COLOR POLARITY
(1) Cathode (2) Cathode
LED P/N
3BC-F
Green
Red
3BC-Y/G-F
Green
Yellow
+.003
TYP.-.002
0.100 [2.5mm]
Recommended Mounting Holes
CUSTOMER USE DRAWING
STANDARD TOLERANCE
(UNLESS OTHERWISE SPECIFIED)
ABSOLUTE MAXIMUM RATINGS (Ta=25 C)
DECIMALS
ANGULAR
4 THOMAS, IRVINE, CA. 92618
TEL: (949) 951-8808
REVERSE VOLTAGE
EXTRUDED VERTICAL T-1 (3mm)
LED STANDARD PROFILE SPACER ASSY
REVERSE CURRENT
DESIGNED:
OPERATING TEMPERATURE RANGE
FAX: (949) 951-3974
TITLE:
Minh Doan
STORAGE TEMPERATURE
REVISED:
LEAD SOLDERING TEMPERATURE(1/16" FROM BODY)
CHECKED:
V. Chavez
A. Valdez
DATE:
07/27/12
DATE:
09/21/20
DATE:
09/21/20
PART NO:
SHEET
SIZE
SCALE:
REVISION:
ELM2XXX3XX
A
N/A
M
CAGE CODE:
32559
SHEET # 1 OF
CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING
4
REV.
DESCRIPTION
DATE
APPROVED
SEE SHEET #1.
CAGE CODE
32559
SHEET SIZE
A
REVISION:
DRAWING NO:
ELM2XXX3XX
SCALE:
M
SHEET # 2 OF 4
REV.
DESCRIPTION
DATE
APPROVED
SEE SHEET #1.
CAGE CODE
32559
SHEET SIZE
A
REVISION:
DRAWING NO:
ELM2XXX3XX
SCALE:
M
SHEET # 3 OF 4
REV.
DESCRIPTION
DATE
APPROVED
SEE SHEET #1.
0.250 [6.4mm]
TYP.
0.500 [12.7mm]
TYP.
0.709 [18.0mm]
CARBOARD REEL
(.020" THICK)
0.650 + XXX*
XXX* = ELM SPACER HEIGHT
0.650 [16.5mm]
0.511 [13.0mm]
MASKING TAPE
TYP.
0.100 [2.5mm]
TYP.
0.500 [12.7mm]
TYP.
LONG LEAD
ANODE
TYP.
0.058 [1.5mm]
MAX.
DIRECTION OF FEED
LABEL
16.5 [420mm] REF.
14" X 2" REEL
13.5 [345mm] REF.
2.5 [63.5mm] REF.
STANDARD PACKAGING TRAY
TAPE & REEL
1,000 pcs / reel
NOTE:
1. STANDARD PART NUMBERS ARE PACKAGED IN LOOSE PIECES USING PACKAGING TRAYS
2. ADD "T" SUFFIX TO PART NUMBER FOR TAPE AND REEL PACKAGING OPTION (1,000 PCS/REEL)
3. ADD "A" SUFFIX TO PART NUMBER FOR AMMO PACK OPTION (2,000 PCS/BOX)
4. TAPE AND REEL PACKAGING COMPLY TO EIA-468-C
AMMO PACK
2,000 pcs / box
CAGE CODE
32559
SHEET SIZE
A
REVISION:
DRAWING NO:
ELM2XXX3XX
SCALE:
M
SHEET # 4 OF 4
很抱歉,暂时无法提供与“ELM21603HD”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 100+2.03586100+0.25530
- 300+1.99160300+0.24975
- 500+1.94734500+0.24420
- 1500+1.903081500+0.23865
- 2500+1.858832500+0.23310
- 国内价格
- 1+5.54040
- 200+2.21400
- 500+2.13840
- 1000+2.10600
