PART NUMBER
REV.
ITEM
Q'TY
1
1
H-131C-1-XXX
T-1 (3mm) LED Holder, 90° Mount, Var. C/L
2
1
3XX-S
T-1 (3mm) N-Flange Shouldered LED, See Page 2
PART DESCRIPTION
1
DESCRIPTION
E Corrected Page 2
F Updated H131CRDL-XXX Spec, Page 2
G Added H131CSRT-XXX Spec, Page 2
H Added Assembly Specs, Page2
J Engineering Update w/o Changes
DATE
APPROVED
12/14/07
05/01/08
01/27/09
03/11/10
06/20/16
M. C.
M. C.
T. Y.
T. Y.
J. C.
2
0.084 [2.1mm]
0.240 [6.1mm]
0.170 [4.3mm]
Ø.118 [Ø3.0mm]
EXAMPLE:
H131CRD-160*
L
C/L
Cathode I.D.
Mark
0.100 [2.5mm]
Centerline "C/L"
LED Color & Lens Appearance.
Omit 3 when ordering.
0.157 [4.0mm]
Series
* XXX = Centerline "C/L"
0.020 [0.5mm] SQ. TYP.
0.210 [5.3mm]
Holder Face
0.210 [5.3mm]
Ø.032+.003
-.002
0.100 [2.5mm] LED Lead
Recommended Mounting Holes
Available Centerlines
XXX
C/L
L
120 .120 (3.0) .250 (6.4)
140 .140 (3.6) .270 (6.9)
160 .160 (4.1) .290 (7.4)
180 .180 (4.6) .310 (7.9)
STANDARD TOLERANCE
ABSOLUTE MAXIMUM RATINGS (Ta=25° C)
( UNLESS OTHERWISE SPECIFIED )
REVERSE VOLTAGE
.X
.XX
.XXX
REVERSE CURRENT
DECIMALS
± .1
± .02
± .010
ANGULAR
X°
± 1°
4 THOMAS, IRVINE, CA. 92618
TEL: (949) 951-8808
TITLE:
OPERATING TEMPERATURE RANGE
DESIGNED:
STORAGE TEMPERATURE
LEAD SOLDERING TEMPERATURE(1/16" FROM BODY)
D. Green
CHECKED:
M. Chen
DATE:
06/11/03
DATE:
06/11/03
FAX: (949) 951-3974
T-1 (3MM) 90° SINGLE-LEVEL
VAR. C/L LED ASSY
REVISION:
PART NO:
H131CXX-XXX
CAGE CODE : 32559
J
SHEET # 1 OF 2
CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING.
REV.
DATE
DESCRIPTION
APPROVED
SEE SHEET #1
LED Assy. No.
Peak Wave
Length
λp(nm )
Electro-Optical Data
Em itted Color
Lens
Appearance
TYP
STANDARD
TYP
MAX
TYP
View ing
Angle
2 ½
(Deg)
If
(m A)
Iv
(m cd)
Vf
(V)
LED P/N
Data @ 20m A
H131CBWD-XXX
430
BLUE
DIFFUSED
4.5
10
40
3BWD-S
H131CGD-XXX
568
GREEN
DIFFUSED
2.8
25
40
3GD-S
H131CSGD-XXX
568
SUPER GREEN
DIFFUSED
2.8
30
40
3SGD-S
H131CSGT-XXX
568
SUPER GREEN
TINTED
2.8
50
30
3SGT-S
H131CYD-XXX
590
YELLOW
DIFFUSED
2.8
3YD-S
H131CSYD-XXX
590
SUPER YELLOW
DIFFUSED
2.8
30
40
3SYD-S
H131CHD-XXX
625
HE RED
DIFFUSED
2.8
30
40
3HD-S
H131CRD-XXX
700
RED
DIFFUSED
2.8
2
40
3RD-S
H131CSRD-XXX
645
SUPER RED
DIFFUSED
2.4
40
40
3SRD-S
H131CSRT-XXX
645
SUPER RED
TINTED
2.4
60
30
3SRT-S
H131CACL-XXX
610
AMBER
WATER CLEAR
2
1.9
2.2
11.5
30
3ACL-S
H131CBWCL-XXX
430
BLUE
WATER CLEAR
2
3.5
4.0
10
30
3BWCL-S
LOW CURRENT
Data @ 2m A
H131CGCL-XXX
568
GREEN
WATER CLEAR
2
2.1
2.6
4
30
3GCL-S
H131CHCL-XXX
625
HE RED
WATER CLEAR
2
2.0
2.6
4
30
3HCL-S
H131CPGCL-XXX
555
PURE GREEN
WATER CLEAR
2
2.1
2.6
1
30
3PGCL-S
H131CRCL-XXX
655
RED
WATER CLEAR
2
1.9
2.2
1.9
30
3RCL-S
H131CYCL-XXX
590
YELLOW
WATER CLEAR
2
2.0
2.6
4
30
3YCL-S
H131CGDL-XXX
568
GREEN
DIFFUSED
2
2.1
2.6
2
40
3GDL-S
H131CYDL-XXX
590
YELLOW
DIFFUSED
2
2.0
2.6
2
40
3YDL-S
H131CHDL-XXX
625
HE RED
DIFFUSED
2
2.0
2.6
2.5
40
3HDL-S
H131CRDL-XXX
700
RED
DIFFUSED
2
2.1
2.6
0.5
40
3RDL-S
H131CGD5V-XXX
568
GREEN
DIFFUSED
8
5.0
25
40
3GD5V-S
H131CYD5V-XXX
590
YELLOW
DIFFUSED
8
5.0
3YD5V-S
H131CHD5V-XXX
625
HE RED
DIFFUSED
8
5.0
30
40
3HD5V-S
5 VOLT
Data @ 5V
STANDARD TOLERANCE
±10% ALL VALUES
ANGULAR
TEL: (949) 951-8808
TITLE:
DESIGNED:
D. Green
CHECKED:
M. Chen
DATE:
06/11/03
DATE:
06/11/03
FAX: (949) 951-3974
VAR. C/L LED ASSY
REVISION:
PART NO:
H131CXX-XXX
CAGE CODE : 32559
J
SHEET # 2 OF 2
很抱歉,暂时无法提供与“H131CGDL-120”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 100+3.63620100+0.47102
