H131CGDL-160
H131CGDL-160
    BIVAR
    发光二极管/LED 翠绿色 2mcd
H131CGDL-160 数据手册
PART NUMBER REV. ITEM Q'TY 1 1 H-131C-1-XXX T-1 (3mm) LED Holder, 90° Mount, Var. C/L 2 1 3XX-S T-1 (3mm) N-Flange Shouldered LED, See Page 2 PART DESCRIPTION 1 DESCRIPTION E Corrected Page 2 F Updated H131CRDL-XXX Spec, Page 2 G Added H131CSRT-XXX Spec, Page 2 H Added Assembly Specs, Page2 J Engineering Update w/o Changes DATE APPROVED 12/14/07 05/01/08 01/27/09 03/11/10 06/20/16 M. C. M. C. T. Y. T. Y. J. C. 2 0.084 [2.1mm] 0.240 [6.1mm] 0.170 [4.3mm] Ø.118 [Ø3.0mm] EXAMPLE: H131CRD-160* L C/L Cathode I.D. Mark 0.100 [2.5mm] Centerline "C/L" LED Color & Lens Appearance. Omit 3 when ordering. 0.157 [4.0mm] Series * XXX = Centerline "C/L" 0.020 [0.5mm] SQ. TYP. 0.210 [5.3mm] Holder Face 0.210 [5.3mm] Ø.032+.003 -.002 0.100 [2.5mm] LED Lead Recommended Mounting Holes Available Centerlines XXX C/L L 120 .120 (3.0) .250 (6.4) 140 .140 (3.6) .270 (6.9) 160 .160 (4.1) .290 (7.4) 180 .180 (4.6) .310 (7.9) STANDARD TOLERANCE ABSOLUTE MAXIMUM RATINGS (Ta=25° C) ( UNLESS OTHERWISE SPECIFIED ) REVERSE VOLTAGE .X .XX .XXX REVERSE CURRENT DECIMALS ± .1 ± .02 ± .010 ANGULAR X° ± 1° ® 4 THOMAS, IRVINE, CA. 92618 TEL: (949) 951-8808 TITLE: OPERATING TEMPERATURE RANGE DESIGNED: STORAGE TEMPERATURE LEAD SOLDERING TEMPERATURE(1/16" FROM BODY) D. Green CHECKED: M. Chen DATE: 06/11/03 DATE: 06/11/03 FAX: (949) 951-3974 T-1 (3MM) 90° SINGLE-LEVEL VAR. C/L LED ASSY REVISION: PART NO: H131CXX-XXX CAGE CODE : 32559 J SHEET # 1 OF 2 CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING. REV. DATE DESCRIPTION APPROVED SEE SHEET #1 LED Assy. No. Peak Wave Length λp(nm ) Electro-Optical Data Em itted Color Lens Appearance TYP STANDARD TYP MAX TYP View ing Angle 2 ½ (Deg) If (m A) Iv (m cd) Vf (V) LED P/N Data @ 20m A H131CBWD-XXX 430 BLUE DIFFUSED 20 4.0 4.5 10 40 3BWD-S H131CGD-XXX 568 GREEN DIFFUSED 20 2.1 2.8 25 40 3GD-S H131CSGD-XXX 568 SUPER GREEN DIFFUSED 20 2.1 2.8 30 40 3SGD-S H131CSGT-XXX 568 SUPER GREEN TINTED 20 2.1 2.8 50 30 3SGT-S H131CYD-XXX 590 YELLOW DIFFUSED 20 2.0 2.8 20 40 3YD-S H131CSYD-XXX 590 SUPER YELLOW DIFFUSED 20 2.0 2.8 30 40 3SYD-S H131CHD-XXX 625 HE RED DIFFUSED 20 2.0 2.8 30 40 3HD-S H131CRD-XXX 700 RED DIFFUSED 20 2.1 2.8 2 40 3RD-S H131CSRD-XXX 645 SUPER RED DIFFUSED 20 1.7 2.4 40 40 3SRD-S H131CSRT-XXX 645 SUPER RED TINTED 20 1.7 2.4 60 30 3SRT-S H131CACL-XXX 610 AMBER WATER CLEAR 2 1.9 2.2 11.5 30 3ACL-S H131CBWCL-XXX 430 BLUE WATER CLEAR 2 3.5 4.0 10 30 3BWCL-S LOW CURRENT Data @ 2m A H131CGCL-XXX 568 GREEN WATER CLEAR 2 2.1 2.6 4 30 3GCL-S H131CHCL-XXX 625 HE RED WATER CLEAR 2 2.0 2.6 4 30 3HCL-S H131CPGCL-XXX 555 PURE GREEN WATER CLEAR 2 2.1 2.6 1 30 3PGCL-S H131CRCL-XXX 655 RED WATER CLEAR 2 1.9 2.2 1.9 30 3RCL-S H131CYCL-XXX 590 YELLOW WATER CLEAR 2 2.0 2.6 4 30 3YCL-S H131CGDL-XXX 568 GREEN DIFFUSED 2 2.1 2.6 2 40 3GDL-S H131CYDL-XXX 590 YELLOW DIFFUSED 2 2.0 2.6 2 40 3YDL-S H131CHDL-XXX 625 HE RED DIFFUSED 2 2.0 2.6 2.5 40 3HDL-S H131CRDL-XXX 700 RED DIFFUSED 2 2.1 2.6 0.5 40 3RDL-S H131CGD5V-XXX 568 GREEN DIFFUSED 8 - 5.0 25 40 3GD5V-S H131CYD5V-XXX 590 YELLOW DIFFUSED 8 - 5.0 20 40 3YD5V-S H131CHD5V-XXX 625 HE RED DIFFUSED 8 - 5.0 30 40 3HD5V-S 5 VOLT Data @ 5V STANDARD TOLERANCE ® ( UNLESS OTHERWISE SPECIFIED ) ±10% ALL VALUES ANGULAR 4 THOMAS, IRVINE, CA. 92618 TEL: (949) 951-8808 TITLE: DESIGNED: D. Green CHECKED: M. Chen DATE: 06/11/03 DATE: 06/11/03 FAX: (949) 951-3974 T-1 (3MM) 90° SINGLE-LEVEL VAR. C/L LED ASSY REVISION: PART NO: H131CXX-XXX CAGE CODE : 32559 J SHEET # 2 OF 2 CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING.
H131CGDL-160 价格&库存
很抱歉,暂时无法提供与“H131CGDL-160”相匹配的价格&库存,您可以联系我们找货
H131CGDL-160
    • 1+6.09120
    • 200+2.43000
    • 500+2.35440
    • 1000+2.31120
