H130CYD-120
H130CYD-120
    BIVAR
    发光二极管/LED 黄色 20mcd
H130CYD-120 数据手册
PART NUMBER REV. ITEM Q'TY PART DESCRIPTION 1 1 H-130C-1-XXX T-1 (3mm) LED Holder, 90° Mount, Interlocking Var. C/L 2 1 3XX-S T-1 (3mm) Shouldered N-Flanged LED, See Page 2 1 B C D E DESCRIPTION Engineering Update w/o Changes LED Package Change to 3XX-S LEDs Added H130CAD-XXX Engineering Update w/o Changes DATE APPROVED 03/05/04 10/26/07 02/29/08 06/20/16 M. C. M. C. M. C. J. C. 2 0.084 [2.1mm] 0.240 [6.1mm] 0.170 [4.3mm] Ø.118 [Ø3.0mm] L EXAMPLE: H130CRD-160* C/L Cathode I.D. Mark 0.100 [2.5mm] Centerline "C/L" LED Color & Lens Appearance. Omit 3 when ordering. 0.157 [4.0mm] Series * XXX = Centerline "C/L" 0.020 [0.5mm] SQ. TYP. 0.210 [5.3mm] Holder Faces 0.100 [2.5mm] LED Lead 0.210 [5.3mm] Ø.032+.003 -.002 TYP. 0.172 [4.4mm] Holder Pitch Recommended Mounting Holes ABSOLUTE MAXIMUM RATINGS (Ta=25 C) REVERSE VOLTAGE REVERSE CURRENT OPERATING TEMPERATURE RANGE STORAGE TEMPERATURE LEAD SOLDERING TEMPERATURE(1/16" FROM BODY) Available Centerlines XXX C/L L 120 .120 (3.0) .250 (6.4) 140 .140 (3.6) .270 (6.9) 160 .160 (4.1) .290 (7.4) 180 .180 (4.6) .310 (7.9) STANDARD TOLERANCE ® ( UNLESS OTHERWISE SPECIFIED ) DECIMALS .X .XX .XXX ± .1 ± .02 ± .010 DESIGNED: D. Green CHECKED: M. Chen ANGULAR X° ± 1° DATE: 06/11/03 DATE: 06/11/03 4 THOMAS, IRVINE, CA. 92618 TEL: (949) 951-8808 FAX: (949) 951-3974 TITLE: T-1 (3MM) INTERLOCKING 90° SINGLE-LEVEL VAR. C/L LED ASSY REVISION: PART NO: H130CXX-XXX CAGE CODE : 32559 E SHEET # 1 OF 2 CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING. REV. DATE DESCRIPTION APPROVED SEE SHEET #1 LED As s y. No. STANDARD H130CBWD-XXX H130CGD-XXX H130CYD-XXX H130CHD-XXX H130CRD-XXX H130CSRD-XXX H130CAD-XXX LOW CURRENT H130CGDL-XXX H130CYDL-XXX H130CHDL-XXX 5 VOLT H130CGD5V-XXX H130CYD5V-XXX H130CHD5V-XXX Ele ctro-Optical Data Pe ak Wave Le ngth λ p(nm ) Em itte d Color Le ns Appe arance 430 565 585 635 655 660 610 BLUE GREEN YELLOW HE RED RED SUPER RED AMBER DIFFUSED DIFFUSED DIFFUSED DIFFUSED DIFFUSED DIFFUSED DIFFUSED 565 585 635 GREEN YELLOW HE RED DIFFUSED DIFFUSED DIFFUSED 565 585 635 GREEN YELLOW HE RED DIFFUSED DIFFUSED DIFFUSED Vie w ing Angle If Iv Vf 2 ½ (m A) (m cd) (De g) (V) Typ. Typ. M ax. Typ. Data @ 20m A 20 4.0 4.5 20 45 20 2.2 2.6 30 45 20 2.1 2.6 20 45 20 2.0 2.6 30 45 20 1.7 2.0 6 45 20 1.7 2.6 90 45 20 2.2 2.6 30 45 Data @ 2m A 2 1.9 2.2 6 45 2 1.9 2.2 4 45 2 1.8 2.2 6 45 Data @ 5V 10 5.0 30 45 10 5.0 20 45 10 5.0 30 45 LED P/N 3BWD-S 3GD-S 3YD-S 3HD-S 3RD-S 3SRD-S 3AD-S 3GDL-S 3YDL-S 3HDL-S 3GD5V-S 3YD5V-S 3HD5V-S STANDARD TOLERANCE ® ( UNLESS OTHERWISE SPECIFIED ) ±10% ALL VALUES ANGULAR 4 THOMAS, IRVINE, CA. 92618 TEL: (949) 951-8808 DESIGNED: D. Green CHECKED: M. Chen DATE: 06/11/03 DATE: 06/11/03 FAX: (949) 951-3974 TITLE: T-1 (3MM) INTERLOCKING 90° SINGLE-LEVEL VAR. C/L LED ASSY REVISION: PART NO: H130CXX-XXX CAGE CODE : 32559 E SHEET # 2 OF 2 CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING.
H130CYD-120 价格&库存
很抱歉,暂时无法提供与“H130CYD-120”相匹配的价格&库存,您可以联系我们找货
