REV.
ITEM
Q'TY
1
1
5XX-F
T-1¾ (5mm) Flanged LED, See Pages 2 to 4
2
1
ELM 1-XXX
Extruded, Self-Retaining LED Spacer
PART NUMBER
PART DESCRIPTION
G
H
J
K
M
N
P
R
1
2
0.339 [8.6mm]
L
2. SHORT LEAD
Flat Edge
Cathode ID
APPROVED
T. Y.
T. Y.
T. Y.
T. Y.
T. Y.
T. Y.
T. Y.
J. C.
2
2
2
1
1
1
Single
Color
Ø.224 [Ø5.7mm]
DATE
07/22/09
01/19/11
06/06/11
11/15/11
07/26/12
11/09/12
09/20/13
09/12/15
DESCRIPTION
Added P/N Designation Note.
Added ELM12205SRDLT.
Added Tape & Reel Options.
Tape & Reel Design Update.
LED Offering List Update.
Removed LED Duplication From Offering List.
Corrected P/N Typo in BOM.
Updated LED Optical Characteristics.
5V
or
12V
Bi-Color
2
LED Flange Dia.
1
0.100 [2.5mm]
BI-COLOR POLARITY
LED P/N (1) Cathode (2) Cathode
Ø.197 [Ø5.0mm]
5BC-F
5BC-Y/G-F
5BC-R/Y-F
5BC-A/G-F
Ø.200 [Ø5.1mm]
LED Dia.
1. LONG LEAD
Spacer Dia.
0.020 [0.5mm] SQ.
TYP.
ELM1XXX5XX
0.100 [2.5mm]
Recommended Mounting Holes
ABSOLUTE MAXIMUM RATINGS (Ta=25 C)
REVERSE VOLTAGE
REVERSE CURRENT
OPERATING TEMPERATURE RANGE
STANDARD TOLERANCE
LEAD SOLDERING TEMPERATURE(1/16" FROM BODY)
( UNLESS OTHERWISE SPECIFIED )
DECIMALS
.X
.XX
.XXX
± .1
± .02
± .010
DESIGNED:
STORAGE TEMPERATURE
Red
Yellow
Red
Amber
Ø.032+.003
TYP.-.002
5mm LED,
Emitted Color and Lens
Appearance
ELM Spacer Length "L"
-i.e. 0.120" length, use 120
-For metric, use whole
number. i.e. 2MM, 10MM
ELM Series
Green
Green
Yellow
Green
Minh Doan
CHECKED:
T. Yin
ANGULAR
X°
± 1°
4 THOMAS, IRVINE, CA. 92618
TEL: (949) 951-8808
FAX: (949) 951-3974
EXTRUDED VERTICAL T-1¾
(5mm) LED NARROW PROFILE ASSY
REVISION:
PART NO:
TITLE:
DATE:
07/26/12
DATE:
07/26/12
ELM1XXX5XX
CAGE CODE : 32559
R
SHEET # 1 OF 5
CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING.
REV.
ITEM
Q'TY
1
1
5XX-F
2
1
ELM 1-XXX
PART NUMBER
PART DESCRIPTION
G
H
J
K
M
N
P
R
1
2
0.339 [8.6mm]
L
2. SHORT LEAD
Flat Edge
Cathode ID
APPROVED
T. Y.
T. Y.
T. Y.
T. Y.
T. Y.
T. Y.
T. Y.
J. C.
2
2
2
1
1
1
Single
Color
Ø.224 [Ø5.7mm]
DATE
07/22/09
01/19/11
06/06/11
11/15/11
07/26/12
11/09/12
09/20/13
09/12/15
DESCRIPTION
5V
or
12V
Bi-Color
2
LED Flange Dia.
1
0.100 [2.5mm]
BI-COLOR POLARITY
Ø.197 [Ø5.0mm]
5BC-F
5BC-Y/G-F
5BC-R/Y-F
5BC-A/G-F
Ø.200 [Ø5.1mm]
LED Dia.
1. LONG LEAD
Spacer Dia.
0.020 [0.5mm] SQ.
TYP.
ELM1XXX5XX
0.100 [2.5mm]
REVERSE VOLTAGE
REVERSE CURRENT
STANDARD TOLERANCE
DECIMALS
.X
.XX
.XXX
± .1
± .02
± .010
DESIGNED:
STORAGE TEMPERATURE
Red
Yellow
Red
Amber
Ø.032+.003
TYP.-.002
5mm LED,
Appearance
ELM Series
Green
Green
Yellow
Green
Minh Doan
CHECKED:
T. Yin
ANGULAR
X°
± 1°
TEL: (949) 951-8808
FAX: (949) 951-3974
REVISION:
PART NO:
TITLE:
DATE:
07/26/12
DATE:
07/26/12
ELM1XXX5XX
CAGE CODE : 32559
R
SHEET # 1 OF 5
REV.
DATE
DESCRIPTION
APPROVED
SEE SHEET #1.
LED Assy. No.
ELM1XXX5BWC
ELM1XXX5BWD
ELM1XXX5BWT
ELM1XXX5GC
ELM1XXX5GD
ELM1XXX5GT
ELM1XXX5PGC
ELM1XXX5PGD
ELM1XXX5PGT
ELM1XXX5YC
ELM1XXX5YD
ELM1XXX5YT
ELM1XXX5AC
ELM1XXX5AD
ELM1XXX5AT
ELM1XXX5HC
ELM1XXX5HD
ELM1XXX5HT
ELM1XXX5RC
ELM1XXX5RD
ELM1XXX5RT
ELM1XXX5BC‐A/G
ELM1XXX5BC
ELM1XXX5BC‐R/Y
ELM1XXX5BC‐Y/G
Material
GaN/SiC
GaN/SiC
GaN/SiC
GaP/GaP
GaP/GaP
GaP/GaP
GaP/GaP
GaP/GaP
GaP/GaP
GaAsP/GaP
GaAsP/GaP
GaAsP/GaP
GaAsP/GaP
GaAsP/GaP
GaAsP/GaP
GaAsP/GaP
GaAsP/GaP
GaAsP/GaP
GaP/GaP
GaP/GaP
GaP/GaP
GaAsP/GaP
GaP/GaP
GaAsP/GaP
GaP/GaP
GaAsP/GaP
GaAsP/GaP
GaAsP/GaP
GaP/GaP
Chip
Peak
Wave
Length
430
430
430
568
568
568
555
555
555
590
590
590
605
605
605
625
625
625
700
700
700
605
568
625
568
625
590
590
568
Emitted Color
BLUE
BLUE
BLUE
GREEN
GREEN
GREEN
PURE GREEN
PURE GREEN
PURE GREEN
YELLOW
YELLOW
YELLOW
AMBER
AMBER
AMBER
HE RED
HE RED
HE RED
RED
RED
RED
AMBER
GREEN
RED
GREEN
RED
YELLOW
YELLOW
GREEN
Lens
Appearance
WATER CLEAR
DIFFUSED
TINTED
WATER CLEAR
DIFFUSED
TINTED
WATER CLEAR
DIFFUSED
TINTED
WATER CLEAR
DIFFUSED
TINTED
WATER CLEAR
DIFFUSED
TINTED
WATER CLEAR
DIFFUSED
TINTED
WATER CLEAR
DIFFUSED
TINTED
WHITE DIFFUSED
WHITE DIFFUSED
WHITE DIFFUSED
WHITE DIFFUSED
Electro‐Optical Data @ 20mA
Vf
If
Iv
(V)
(mA)
(mcd)
MAX
TYP
MAX
TYP
25
4
4.5
25
25
4
4.5
15
25
4
4.5
30
30
2.1
2.8
40
30
2.1
2.8
25
30
2.1
2.8
40
30
2.2
2.8
10
30
2.2
2.8
10
30
2.2
2.8
10
30
2
2.8
40
30
2
2.8
25
30
2
2.8
40
30
2
2.8
40
30
2
2.8
25
30
2
2.8
40
30
2
2.8
40
30
2
2.8
25
30
2
2.8
40
2.8
2
2.8
2
2.8
2
30
2.0
2.8
6
30
2.1
2.8
6
30
2.0
2.8
6
30
2.1
2.8
8
30
2.0
2.8
6
30
2.0
2.8
5
30
2.0
2.8
5
30
2.1
2.8
8
Viewing
Angle
2 θ ½
(Deg)
45
35
35
45
35
35
45
35
35
45
35
35
45
35
35
45
35
5BWC‐F
5BWD‐F
5BWT‐F
5GC‐F
5GD‐F
5GT‐F
5PGC‐F
5PGD‐F
5PGT‐F
5YC‐F
5YD‐F
5YT‐F
5AC‐F
5AD‐F
5AT‐F
5HC‐F
5HD‐F
5HT‐F
5RC‐F
5RD‐F
5RT‐F
45
5BC‐A/G‐F
45
5BC‐F
45
5BC‐R/Y‐F
45
5BC‐Y/G‐F
LED P/N
STANDARD TOLERANCE
±10% ALL VALUES
ANGULAR
X°
± 5°
TEL: (949) 951-8808
FAX: (949) 951-3974
REVISION:
PART NO:
TITLE:
DESIGNED:
Minh Doan
CHECKED:
T. Yin
DATE:
07/26/12
DATE:
07/26/12
ELM1XXX5XX
CAGE CODE : 32559
R
SHEET # 2 OF 5
REV.
DATE
DESCRIPTION
APPROVED
SEE SHEET #1.
LED Assy. No.
EML1XXX5UBWC
ELM1XXX5SGC
ELM1XXX5SGD
ELM1XXX5SGT
ELM1XXX5SYC
ELM1XXX5SYD
ELM1XXX5SYT
ELM1XXX5SRC
ELM1XXX5SRD
ELM1XXX5SRT
ELM1XXX5UGC
ELM1XXX5SUGC
ELM1XXX5UYC
ELM1XXX5SUYC
ELM1XXX5UUYC
ELM1XXX5UOC
ELM1XXX5UOC
ELM1XXX5URC
ELM1XXX5SURC
ELM1XXX5UWC
Material
InGaN/SiC
GaP/GaP
GaP/GaP
GaP/GaP
GaAsP/GaP
GaAsP/GaP
GaAsP/GaP
GaAlAs/GaAs
GaAlAs/GaAs
GaAlAs/GaAs
AlGaInP
AlGaInP
AlGaInP
AlGaInP
AlGaInP
AlGaInP
AlGaInP
GaAlAs/GaAs
AlGaInP
InGaN/SiC
Chip
Peak
Wave
Length
468
568
568
568
590
590
590
645
645
645
570
570
590
590
590
625
625
645
640
6500K
Emitted
Color
BLUE
GREEN
GREEN
GREEN
YELLOW
YELLOW
YELLOW
SUPER RED
SUPER RED
SUPER RED
GREEN
GREEN
YELLOW
YELLOW
YELLOW
ORANGE
ORANGE
RED
RED
WHITE
Lens
Appearance
WATER CLEAR
WATER CLEAR
DIFFUSED
TINTED
WATER CLEAR
DIFFUSED
TINTED
WATER CLEAR
DIFFUSED
TINTED
WATER CLEAR
WATER CLEAR
WATER CLEAR
WATER CLEAR
WATER CLEAR
WATER CLEAR
WATER CLEAR
WATER CLEAR
WATER CLEAR
WATER CLEAR
Vf
If
Iv
(V)
(mA)
(mcd)
MAX
TYP
MAX
TYP
50
3.2
3.6
8000
30
2.1
2.8
60
30
2.1
2.8
50
30
2.1
2.8
60
30
2.0
2.8
600
30
2.0
2.8
150
30
2.0
2.8
600
30
1.7
2.4
60
30
1.7
2.4
40
30
1.7
2.4
60
30
2.1
2.4
400
30
2.1
2.4
300
30
2.0
2.4
1000
30
2.0
2.4
700
30
2.0
2.4
500
30
1.8
2.4
1400
30
1.8
2.4
1300
30
1.7
2.4
400
30
1.8
2.4
500
100
3.5
4.2
2700
Viewing
Angle
LED P/N
2 θ ½
(Deg)
15
5BWC2.515F
35
5SGC‐F
40
5SGD‐F
35
5SGT‐F
35
5SYC‐F
40
5SYD‐F
35
5SYT‐F
35
5SRC‐F
40
5SRD‐F
35
5SRT‐F
35
5UGC‐F
35
5SUGC‐F
30
5UYC‐F
35
5SUYC‐F
35
5UUYC‐F
35
5UOC‐F
35
5SUOC‐F
30
5URC‐F
35
5SURC‐F
30
5WC2.730F
STANDARD TOLERANCE
±10% ALL VALUES
ANGULAR
X°
± 5°
TEL: (949) 951-8808
FAX: (949) 951-3974
REVISION:
PART NO:
TITLE:
DESIGNED:
Minh Doan
CHECKED:
T. Yin
DATE:
07/26/12
DATE:
07/26/12
ELM1XXX5XX
CAGE CODE : 32559
R
SHEET # 3 OF 5
REV.
DATE
DESCRIPTION
APPROVED
SEE SHEET #1.
Max. Rating
MAX
TYP
MAX
TYP
DIFFUSED
7
3.8
4.2
4
40
5BWDL-F
PURE GREEN
DIFFUSED
7
2.1
2.6
1
40
5PGDL-F
568
GREEN
DIFFUSED
7
2.1
2.6
4
40
5GDL-F
590
YELLOW
DIFFUSED
7
2.0
2.6
4
40
5YDL-F
Em itted
Color
ELM1XXX5BWDL
430
BLUE
ELM1XXX5PGDL
555
ELM1XXX5GDL
ELM1XXX5YDL
LED Assy. No.
Electro-Optical Data @ 2m A
View ing
Angle
2 ½
(Deg)
Peak Wave
Length
λp(nm )
Lens
Appearance
If
(m A)
Iv
(m cd)
Vf
(V)
LED P/N
ELM1XXX5ADL
605
AMBER
DIFFUSED
7
2.0
2.6
4
40
5ADL-F
ELM1XXX5HDL
625
HE RED
DIFFUSED
7
2.0
2.6
5
40
5HDL-F
ELM1XXX5SRDL
645
SUPER RED
DIFFUSED
7
1.7
2.3
6
40
5SRDL-F
LED Assy. No.
5 Volt
ELM1XXX5BWD5V
ELM1XXX5GC5V
ELM1XXX5GD5V
ELM1XXX5GT5V
ELM1XXX5AD5V
ELM1XXX5HD5V
ELM1XXX5RD5V
ELM1XXX5YD5V
12 Volt
ELM1XXX5GC12V
ELM1XXX5GD12V
ELM1XXX5HC12V
ELM1XXX5HD12V
ELM1XXX5RC12V
ELM1XXX5RD12V
ELM1XXX5YC12V
ELM1XXX5YD12V
Peak Wave
Length
λp(nm)
Emitted
Color
Lens
Appearance
BLUE
GREEN
GREEN
GREEN
AMBER
HE RED
RED
YELLOW
430
568
568
568
605
625
700
590
DIFFUSED
WATER CLEAR
DIFFUSED
TINTED
DIFFUSED
DIFFUSED
DIFFUSED
DIFFUSED
GREEN
GREEN
HE RED
HE RED
RED
RED
YELLOW
YELLOW
568
568
625
625
700
700
590
590
WATER CLEAR
DIFFUSED
WATER CLEAR
DIFFUSED
WATER CLEAR
DIFFUSED
WATER CLEAR
DIFFUSED
Vf
If
Iv
(V)
(mA)
(mcd)
MAX
TYP
MAX
TYP
Data @ 5V
5
15
5
40
5
25
5
40
5
25
5
30
5
1.5
5
25
Data @ 12V
12
40
12
25
12
50
12
30
12
2
12
1.5
12
25
12
Viewing
Angle
2 θ½
(Deg)
LED P/N
40
40
40
40
40
40
40
40
5BWD5V-F
5GC5V-F
5GD5V-F
5GT5V-F
5AD5V-F
5HD5V-F
5RD5V-F
5YD5V-F
35
40
35
40
35
40
35
40
5GC12V-F
5GD12V-F
5HC12V-F
5HD12V-F
5RC12V-F
5RD12V-F
5YC12V-F
5YD12V-F
STANDARD TOLERANCE
±10% ALL VALUES
ANGULAR
X°
± 5°
TEL: (949) 951-8808
FAX: (949) 951-3974
TITLE:
DESIGNED:
Minh Doan
CHECKED:
T. Yin
DATE:
07/26/12
DATE:
07/26/12
REVISION:
PART NO:
ELM1XXX5XX
CAGE CODE : 32559
R
SHEET # 4 OF 5
REV.
DATE
DESCRIPTION
APPROVED
SEE SHEET #1.
0.250 [6.4mm]
TYP.
0.500 [12.7mm]
TYP.
0.709 [18.0mm]
CARBOARD REEL
(.020" THICK)
0.650 + XXX*
XXX* = ELM SPACER HEIGHT
0.650 [16.5mm]
0.511 [13.0mm]
MASKING TAPE
Ø.158 [Ø4.0mm]
TYP.
0.100 [2.5mm]
TYP.
0.500 [12.7mm]
TYP.
LONG LEAD
ANODE
TYP.
0.058 [1.5mm]
MAX.
DIRECTION OF FEED
LABEL
16.5 [420mm] REF.
14" X 2" REEL
13.5 [345mm] REF.
2.5 [63.5mm] REF.
STANDARD PACKAGING TRAY
TAPE & REEL
1,000 pcs / reel
AMMO PACK
2,000 pcs / box
STANDARD TOLERANCE
DECIMALS
NOTE:
1. STANDARD PART NUMBERS ARE PACKAGED IN LOOSE PIECES USING PACKAGING TRAYS
2. ADD "T" SUFFIX TO PART NUMBER FOR TAPE AND REEL PACKAGING OPTION (1,000 PCS/REEL)
3. ADD "A" SUFFIX TO PART NUMBER FOR AMMO PACK OPTION (2,000 PCS/BOX)
4. TAPE AND REEL PACKAGING COMPLY TO EIA-468-C
.X
.XX
.XXX
± .1
± .02
± .010
DESIGNED:
Minh Doan
CHECKED:
T. Yin
ANGULAR
X°
± 1°
TEL: (949) 951-8808
FAX: (949) 951-3974
TITLE:
DATE:
07/26/12
DATE:
07/26/12
PART NO:
REVISION:
ELM1XXX5XX
CAGE CODE : 32559
R
SHEET # 5 OF 5
很抱歉,暂时无法提供与“ELM10555AD”相匹配的价格&库存,您可以联系我们找货
