ELM12505AD
ELM12505AD
    BIVAR
    发光二极管/LED 琥珀色 25mcd
ELM12505AD 数据手册
REV. ITEM Q'TY 1 1 5XX-F T-1¾ (5mm) Flanged LED, See Pages 2 to 4 2 1 ELM 1-XXX Extruded, Self-Retaining LED Spacer PART NUMBER PART DESCRIPTION G H J K M N P R 1 2 0.339 [8.6mm] L 2. SHORT LEAD Flat Edge Cathode ID APPROVED T. Y. T. Y. T. Y. T. Y. T. Y. T. Y. T. Y. J. C. 2 2 2 1 1 1 Single Color Ø.224 [Ø5.7mm] DATE 07/22/09 01/19/11 06/06/11 11/15/11 07/26/12 11/09/12 09/20/13 09/12/15 DESCRIPTION Added P/N Designation Note. Added ELM12205SRDLT. Added Tape & Reel Options. Tape & Reel Design Update. LED Offering List Update. Removed LED Duplication From Offering List. Corrected P/N Typo in BOM. Updated LED Optical Characteristics. 5V or 12V Bi-Color 2 LED Flange Dia. 1 0.100 [2.5mm] BI-COLOR POLARITY LED P/N (1) Cathode (2) Cathode Ø.197 [Ø5.0mm] 5BC-F 5BC-Y/G-F 5BC-R/Y-F 5BC-A/G-F Ø.200 [Ø5.1mm] LED Dia. 1. LONG LEAD Spacer Dia. 0.020 [0.5mm] SQ. TYP. ELM1XXX5XX 0.100 [2.5mm] Recommended Mounting Holes ABSOLUTE MAXIMUM RATINGS (Ta=25 C) REVERSE VOLTAGE REVERSE CURRENT OPERATING TEMPERATURE RANGE STANDARD TOLERANCE LEAD SOLDERING TEMPERATURE(1/16" FROM BODY) ® ( UNLESS OTHERWISE SPECIFIED ) DECIMALS .X .XX .XXX ± .1 ± .02 ± .010 DESIGNED: STORAGE TEMPERATURE Red Yellow Red Amber Ø.032+.003 TYP.-.002 5mm LED, Emitted Color and Lens Appearance ELM Spacer Length "L" -i.e. 0.120" length, use 120 -For metric, use whole number. i.e. 2MM, 10MM ELM Series Green Green Yellow Green Minh Doan CHECKED: T. Yin ANGULAR X° ± 1° 4 THOMAS, IRVINE, CA. 92618 TEL: (949) 951-8808 FAX: (949) 951-3974 EXTRUDED VERTICAL T-1¾ (5mm) LED NARROW PROFILE ASSY REVISION: PART NO: TITLE: DATE: 07/26/12 DATE: 07/26/12 ELM1XXX5XX CAGE CODE : 32559 R SHEET # 1 OF 5 CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING. REV. ITEM Q'TY 1 1 5XX-F T-1¾ (5mm) Flanged LED, See Pages 2 to 4 2 1 ELM 1-XXX Extruded, Self-Retaining LED Spacer PART NUMBER PART DESCRIPTION G H J K M N P R 1 2 0.339 [8.6mm] L 2. SHORT LEAD Flat Edge Cathode ID APPROVED T. Y. T. Y. T. Y. T. Y. T. Y. T. Y. T. Y. J. C. 2 2 2 1 1 1 Single Color Ø.224 [Ø5.7mm] DATE 07/22/09 01/19/11 06/06/11 11/15/11 07/26/12 11/09/12 09/20/13 09/12/15 DESCRIPTION Added P/N Designation Note. Added ELM12205SRDLT. Added Tape & Reel Options. Tape & Reel Design Update. LED Offering List Update. Removed LED Duplication From Offering List. Corrected P/N Typo in BOM. Updated LED Optical Characteristics. 5V or 12V Bi-Color 2 LED Flange Dia. 1 0.100 [2.5mm] BI-COLOR POLARITY LED P/N (1) Cathode (2) Cathode Ø.197 [Ø5.0mm] 5BC-F 5BC-Y/G-F 5BC-R/Y-F 5BC-A/G-F Ø.200 [Ø5.1mm] LED Dia. 1. LONG LEAD Spacer Dia. 0.020 [0.5mm] SQ. TYP. ELM1XXX5XX 0.100 [2.5mm] Recommended Mounting Holes ABSOLUTE MAXIMUM RATINGS (Ta=25 C) REVERSE VOLTAGE REVERSE CURRENT OPERATING TEMPERATURE RANGE STANDARD TOLERANCE LEAD SOLDERING TEMPERATURE(1/16" FROM BODY) ® ( UNLESS OTHERWISE SPECIFIED ) DECIMALS .X .XX .XXX ± .1 ± .02 ± .010 DESIGNED: STORAGE TEMPERATURE Red Yellow Red Amber Ø.032+.003 TYP.-.002 5mm LED, Emitted Color and Lens Appearance ELM Spacer Length "L" -i.e. 0.120" length, use 120 -For metric, use whole number. i.e. 2MM, 10MM ELM Series Green Green Yellow Green Minh Doan CHECKED: T. Yin ANGULAR X° ± 1° 4 THOMAS, IRVINE, CA. 92618 TEL: (949) 951-8808 FAX: (949) 951-3974 EXTRUDED VERTICAL T-1¾ (5mm) LED NARROW PROFILE ASSY REVISION: PART NO: TITLE: DATE: 07/26/12 DATE: 07/26/12 ELM1XXX5XX CAGE CODE : 32559 R SHEET # 1 OF 5 CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING. REV. DATE DESCRIPTION APPROVED SEE SHEET #1. LED Assy. No. ELM1XXX5BWC ELM1XXX5BWD ELM1XXX5BWT ELM1XXX5GC ELM1XXX5GD ELM1XXX5GT ELM1XXX5PGC ELM1XXX5PGD ELM1XXX5PGT ELM1XXX5YC ELM1XXX5YD ELM1XXX5YT ELM1XXX5AC ELM1XXX5AD ELM1XXX5AT ELM1XXX5HC ELM1XXX5HD ELM1XXX5HT ELM1XXX5RC ELM1XXX5RD ELM1XXX5RT ELM1XXX5BC‐A/G ELM1XXX5BC ELM1XXX5BC‐R/Y ELM1XXX5BC‐Y/G Material GaN/SiC GaN/SiC GaN/SiC GaP/GaP GaP/GaP GaP/GaP GaP/GaP GaP/GaP GaP/GaP GaAsP/GaP GaAsP/GaP GaAsP/GaP GaAsP/GaP GaAsP/GaP GaAsP/GaP GaAsP/GaP GaAsP/GaP GaAsP/GaP GaP/GaP GaP/GaP GaP/GaP GaAsP/GaP GaP/GaP GaAsP/GaP GaP/GaP GaAsP/GaP GaAsP/GaP GaAsP/GaP GaP/GaP Chip Peak  Wave  Length 430 430 430 568 568 568 555 555 555 590 590 590 605 605 605 625 625 625 700 700 700 605 568 625 568 625 590 590 568 Emitted Color BLUE BLUE BLUE GREEN GREEN GREEN PURE GREEN PURE GREEN PURE GREEN YELLOW YELLOW YELLOW AMBER AMBER AMBER HE RED HE RED HE RED RED RED RED AMBER GREEN RED GREEN RED YELLOW YELLOW GREEN Lens Appearance WATER CLEAR DIFFUSED TINTED WATER CLEAR DIFFUSED TINTED WATER CLEAR DIFFUSED TINTED WATER CLEAR DIFFUSED TINTED WATER CLEAR DIFFUSED TINTED WATER CLEAR DIFFUSED TINTED WATER CLEAR DIFFUSED TINTED WHITE DIFFUSED WHITE DIFFUSED WHITE DIFFUSED WHITE DIFFUSED Electro‐Optical Data @ 20mA Vf If Iv (V) (mA) (mcd) MAX TYP MAX TYP 25 4 4.5 25 25 4 4.5 15 25 4 4.5 30 30 2.1 2.8 40 30 2.1 2.8 25 30 2.1 2.8 40 30 2.2 2.8 10 30 2.2 2.8 10 30 2.2 2.8 10 30 2 2.8 40 30 2 2.8 25 30 2 2.8 40 30 2 2.8 40 30 2 2.8 25 30 2 2.8 40 30 2 2.8 40 30 2 2.8 25 30 2 2.8 40 20 2.1 2.8 2 20 2.1 2.8 2 20 2.1 2.8 2 30 2.0 2.8 6 30 2.1 2.8 6 30 2.0 2.8 6 30 2.1 2.8 8 30 2.0 2.8 6 30 2.0 2.8 5 30 2.0 2.8 5 30 2.1 2.8 8 Viewing  Angle 2 θ ½ (Deg) 20 45 20 35 45 35 35 45 35 35 45 35 35 45 35 35 45 35 35 45 35 5BWC‐F 5BWD‐F 5BWT‐F 5GC‐F 5GD‐F 5GT‐F 5PGC‐F 5PGD‐F 5PGT‐F 5YC‐F 5YD‐F 5YT‐F 5AC‐F 5AD‐F 5AT‐F 5HC‐F 5HD‐F 5HT‐F 5RC‐F 5RD‐F 5RT‐F 45 5BC‐A/G‐F 45 5BC‐F 45 5BC‐R/Y‐F 45 5BC‐Y/G‐F LED P/N ® STANDARD TOLERANCE ( UNLESS OTHERWISE SPECIFIED ) ±10% ALL VALUES ANGULAR X° ± 5° 4 THOMAS, IRVINE, CA. 92618 TEL: (949) 951-8808 FAX: (949) 951-3974 EXTRUDED VERTICAL T-1¾ (5mm) LED NARROW PROFILE ASSY REVISION: PART NO: TITLE: DESIGNED: Minh Doan CHECKED: T. Yin DATE: 07/26/12 DATE: 07/26/12 ELM1XXX5XX CAGE CODE : 32559 R SHEET # 2 OF 5 CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING. REV. DATE DESCRIPTION APPROVED SEE SHEET #1. LED Assy. No. EML1XXX5UBWC ELM1XXX5SGC ELM1XXX5SGD ELM1XXX5SGT ELM1XXX5SYC ELM1XXX5SYD ELM1XXX5SYT ELM1XXX5SRC ELM1XXX5SRD ELM1XXX5SRT ELM1XXX5UGC ELM1XXX5SUGC ELM1XXX5UYC ELM1XXX5SUYC ELM1XXX5UUYC ELM1XXX5UOC ELM1XXX5UOC ELM1XXX5URC ELM1XXX5SURC ELM1XXX5UWC Material InGaN/SiC GaP/GaP GaP/GaP GaP/GaP GaAsP/GaP GaAsP/GaP GaAsP/GaP GaAlAs/GaAs GaAlAs/GaAs GaAlAs/GaAs AlGaInP AlGaInP AlGaInP AlGaInP AlGaInP AlGaInP AlGaInP GaAlAs/GaAs AlGaInP InGaN/SiC Chip Peak  Wave  Length 468 568 568 568 590 590 590 645 645 645 570 570 590 590 590 625 625 645 640 6500K Emitted  Color BLUE GREEN GREEN GREEN YELLOW YELLOW YELLOW SUPER RED SUPER RED SUPER RED GREEN GREEN YELLOW YELLOW YELLOW ORANGE ORANGE RED RED WHITE Lens Appearance WATER CLEAR WATER CLEAR DIFFUSED TINTED WATER CLEAR DIFFUSED TINTED WATER CLEAR DIFFUSED TINTED WATER CLEAR WATER CLEAR WATER CLEAR WATER CLEAR WATER CLEAR WATER CLEAR WATER CLEAR WATER CLEAR WATER CLEAR WATER CLEAR Electro‐Optical Data @ 20mA Vf If Iv (V) (mA) (mcd) MAX TYP MAX TYP 50 3.2 3.6 8000 30 2.1 2.8 60 30 2.1 2.8 50 30 2.1 2.8 60 30 2.0 2.8 600 30 2.0 2.8 150 30 2.0 2.8 600 30 1.7 2.4 60 30 1.7 2.4 40 30 1.7 2.4 60 30 2.1 2.4 400 30 2.1 2.4 300 30 2.0 2.4 1000 30 2.0 2.4 700 30 2.0 2.4 500 30 1.8 2.4 1400 30 1.8 2.4 1300 30 1.7 2.4 400 30 1.8 2.4 500 100 3.5 4.2 2700 Viewing  Angle LED P/N 2 θ ½ (Deg) 15 5BWC2.515F 35 5SGC‐F 40 5SGD‐F 35 5SGT‐F 35 5SYC‐F 40 5SYD‐F 35 5SYT‐F 35 5SRC‐F 40 5SRD‐F 35 5SRT‐F 35 5UGC‐F 35 5SUGC‐F 30 5UYC‐F 35 5SUYC‐F 35 5UUYC‐F 35 5UOC‐F 35 5SUOC‐F 30 5URC‐F 35 5SURC‐F 30 5WC2.730F ® STANDARD TOLERANCE ( UNLESS OTHERWISE SPECIFIED ) ±10% ALL VALUES ANGULAR X° ± 5° 4 THOMAS, IRVINE, CA. 92618 TEL: (949) 951-8808 FAX: (949) 951-3974 EXTRUDED VERTICAL T-1¾ (5mm) LED NARROW PROFILE ASSY REVISION: PART NO: TITLE: DESIGNED: Minh Doan CHECKED: T. Yin DATE: 07/26/12 DATE: 07/26/12 ELM1XXX5XX CAGE CODE : 32559 R SHEET # 3 OF 5 CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING. REV. DATE DESCRIPTION APPROVED SEE SHEET #1. Max. Rating MAX TYP MAX TYP DIFFUSED 7 3.8 4.2 4 40 5BWDL-F PURE GREEN DIFFUSED 7 2.1 2.6 1 40 5PGDL-F 568 GREEN DIFFUSED 7 2.1 2.6 4 40 5GDL-F 590 YELLOW DIFFUSED 7 2.0 2.6 4 40 5YDL-F Em itted Color ELM1XXX5BWDL 430 BLUE ELM1XXX5PGDL 555 ELM1XXX5GDL ELM1XXX5YDL LED Assy. No. Electro-Optical Data @ 2m A View ing Angle 2 ½ (Deg) Peak Wave Length λp(nm ) Lens Appearance If (m A) Iv (m cd) Vf (V) LED P/N ELM1XXX5ADL 605 AMBER DIFFUSED 7 2.0 2.6 4 40 5ADL-F ELM1XXX5HDL 625 HE RED DIFFUSED 7 2.0 2.6 5 40 5HDL-F ELM1XXX5SRDL 645 SUPER RED DIFFUSED 7 1.7 2.3 6 40 5SRDL-F LED Assy. No. 5 Volt ELM1XXX5BWD5V ELM1XXX5GC5V ELM1XXX5GD5V ELM1XXX5GT5V ELM1XXX5AD5V ELM1XXX5HD5V ELM1XXX5RD5V ELM1XXX5YD5V 12 Volt ELM1XXX5GC12V ELM1XXX5GD12V ELM1XXX5HC12V ELM1XXX5HD12V ELM1XXX5RC12V ELM1XXX5RD12V ELM1XXX5YC12V ELM1XXX5YD12V Peak Wave Length λp(nm) Emitted Color Lens Appearance BLUE GREEN GREEN GREEN AMBER HE RED RED YELLOW 430 568 568 568 605 625 700 590 DIFFUSED WATER CLEAR DIFFUSED TINTED DIFFUSED DIFFUSED DIFFUSED DIFFUSED GREEN GREEN HE RED HE RED RED RED YELLOW YELLOW 568 568 625 625 700 700 590 590 WATER CLEAR DIFFUSED WATER CLEAR DIFFUSED WATER CLEAR DIFFUSED WATER CLEAR DIFFUSED Electro-Optical Data Vf If Iv (V) (mA) (mcd) MAX TYP MAX TYP Data @ 5V 5 15 5 40 5 25 5 40 5 25 5 30 5 1.5 5 25 Data @ 12V 12 40 12 25 12 50 12 30 12 2 12 1.5 12 25 12 20 Viewing Angle 2 θ½ (Deg) LED P/N 40 40 40 40 40 40 40 40 5BWD5V-F 5GC5V-F 5GD5V-F 5GT5V-F 5AD5V-F 5HD5V-F 5RD5V-F 5YD5V-F 35 40 35 40 35 40 35 40 5GC12V-F 5GD12V-F 5HC12V-F 5HD12V-F 5RC12V-F 5RD12V-F 5YC12V-F 5YD12V-F ® STANDARD TOLERANCE ( UNLESS OTHERWISE SPECIFIED ) ±10% ALL VALUES ANGULAR X° ± 5° 4 THOMAS, IRVINE, CA. 92618 TEL: (949) 951-8808 FAX: (949) 951-3974 TITLE: DESIGNED: Minh Doan CHECKED: T. Yin DATE: 07/26/12 DATE: 07/26/12 EXTRUDED VERTICAL T-1¾ (5mm) LED NARROW PROFILE ASSY REVISION: PART NO: ELM1XXX5XX CAGE CODE : 32559 R SHEET # 4 OF 5 CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING. REV. DATE DESCRIPTION APPROVED SEE SHEET #1. 0.250 [6.4mm] TYP. 0.500 [12.7mm] TYP. 0.709 [18.0mm] CARBOARD REEL (.020" THICK) 0.650 + XXX* XXX* = ELM SPACER HEIGHT 0.650 [16.5mm] 0.511 [13.0mm] MASKING TAPE Ø.158 [Ø4.0mm] TYP. 0.100 [2.5mm] TYP. 0.500 [12.7mm] TYP. LONG LEAD ANODE TYP. 0.058 [1.5mm] MAX. DIRECTION OF FEED LABEL 16.5 [420mm] REF. 14" X 2" REEL 13.5 [345mm] REF. 2.5 [63.5mm] REF. STANDARD PACKAGING TRAY TAPE & REEL 1,000 pcs / reel AMMO PACK 2,000 pcs / box STANDARD TOLERANCE ® ( UNLESS OTHERWISE SPECIFIED ) DECIMALS NOTE: 1. STANDARD PART NUMBERS ARE PACKAGED IN LOOSE PIECES USING PACKAGING TRAYS 2. ADD "T" SUFFIX TO PART NUMBER FOR TAPE AND REEL PACKAGING OPTION (1,000 PCS/REEL) 3. ADD "A" SUFFIX TO PART NUMBER FOR AMMO PACK OPTION (2,000 PCS/BOX) 4. TAPE AND REEL PACKAGING COMPLY TO EIA-468-C .X .XX .XXX ± .1 ± .02 ± .010 DESIGNED: Minh Doan CHECKED: T. Yin ANGULAR X° ± 1° 4 THOMAS, IRVINE, CA. 92618 TEL: (949) 951-8808 FAX: (949) 951-3974 TITLE: EXTRUDED VERTICAL T-1¾ (5mm) LED NARROW PROFILE ASSY DATE: 07/26/12 DATE: 07/26/12 PART NO: REVISION: ELM1XXX5XX CAGE CODE : 32559 R SHEET # 5 OF 5 CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING.
ELM12505AD 价格&库存
很抱歉,暂时无法提供与“ELM12505AD”相匹配的价格&库存,您可以联系我们找货
