ITEM
Q'TY
1
1
H-101C
T-1 (3mm) LED Holder, 90° Mount
2
1
3SGD-S
T-1 (3mm) N-Flange Shouldered LED
1
REV.
PART DESCRIPTION
PART NUMBER
DESCRIPTION
A Engineering Release
B Added -S to 3SGD in Table
C Engineering Update w/o Changes
DATE
APPROVED
06/22/99
12/19/12
06/20/16
A. V.
T. Y.
J. C.
2
0.091 [2.3mm]
0.250 [6.4mm]
0.170 [4.3mm]
Ø.118 [Ø3.0mm]
Holder Face
0.100 [2.5mm] LED Lead
Ø.032+.003
-.002
TYP.
0.185 [4.7mm]
0.285 [7.2mm]
0.200 [5.1mm]
Cathode I.D.
Mark
0.100 [2.5mm]
Recommended Mounting Holes
0.157 [4.0mm]
0.020 [0.5mm] SQ. TYP.
0.185 [4.7mm]
Chip
LED P/N
3SGD-S
Absolute Max. Ratings
Em itted Color
Peak Wavelength
λp (nm )
SUPER GREEN
568
Lens
Appearance
∆λ
(nm )
Pd
(m W)
If
(m A)
Peak If
(m A)
30
100
30
150
DIFFUSED
ABSOLUTE MAXIMUM RATINGS (Ta=25° C)
REVERSE VOLTAGE
REVERSE CURRENT
OPERATING TEMPERATURE RANGE
STORAGE TEMPERATURE
LEAD SOLDERING TEMPERATURE(1/16" FROM BODY)
Electro-Optical Data @ 20m A
Vf
(V)
Iv
(m cd)
TYP
MAX
TYP
2.2
2.6
55
View ing
Angle
(Deg)
45
STANDARD TOLERANCE
( UNLESS OTHERWISE SPECIFIED )
DECIMALS
.X
.XX
.XXX
± .1
± .02
± .010
DESIGNED:
S. Irving
CHECKED:
A. Vilgiate
ANGULAR
X°
± 1°
4 THOMAS, IRVINE, CA. 92618
TEL: (949) 951-8808
FAX: (949) 951-3974
TITLE:
DATE:
06/22/99
DATE:
06/22/99
T-1 (3MM) 90° SINGLE-LEVEL
LED ASSEMBLY
REVISION:
PART NO:
H101CSGD
CAGE CODE : 32559
C
SHEET # 1 OF 1
CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING.
很抱歉,暂时无法提供与“H101CSGD”相匹配的价格&库存,您可以联系我们找货
