H100CGDL
H100CGDL
    BIVAR
    插件
    发光二极管/LED 翠绿色 插件 6mcd
H100CGDL 数据手册
REV. PART DESCRIPTION ITEM Q'TY PART NUMBER 1 1 H-100C T-1 (3mm) LED Holder, 90° Mount, Interlocking Center 2 1 3XX-S T-1 (3mm) N-Flange Shouldered LED, See Page 2 1 DESCRIPTION A Engineering Update w/o Changes B LED Package Change to 3XX-S LEDs C Engineering Update w/o Changes 2 DATE APPROVED 03/05/04 12/14/07 06/20/16 M. C. M. C. J. C. 0.091 [2.3mm] 0.250 [6.4mm] 0.170 [4.3mm] Ø.118 [Ø3.0mm] 0.285 [7.2mm] 0.200 [5.1mm] Cathode I.D. Mark 0.100 [2.5mm] 0.157 [4.0mm] 0.020 [0.5mm] SQ. TYP. 0.185 [4.7mm] 0.185 [4.7mm] Holder Faces 0.100 [2.5mm] LED Lead Ø.032+.003 -.002 TYP. 0.172 [4.4mm] Holder Pitch Recommended Mounting Holes ABSOLUTE MAXIMUM RATINGS (Ta=25° C) REVERSE VOLTAGE REVERSE CURRENT OPERATING TEMPERATURE RANGE STANDARD TOLERANCE DECIMALS .X .XX .XXX ± .1 ± .02 ± .010 DESIGNED: STORAGE TEMPERATURE LEAD SOLDERING TEMPERATURE(1/16" FROM BODY) ® ( UNLESS OTHERWISE SPECIFIED ) S. Irving CHECKED: A. Vilgiate ANGULAR X° ± 1° DATE: 03/05/04 DATE: 03/05/04 4 THOMAS, IRVINE, CA. 92618 TEL: (949) 951-8808 FAX: (949) 951-3974 TITLE: T-1 (3MM) INTERLOCKING 90° SINGLE-LEVEL LED ASSEMBLY REVISION: PART NO: H100CXX CAGE CODE : 32559 C SHEET # 1 OF 2 CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING. REV. DATE DESCRIPTION APPROVED SEE SHEET #1 LED Assy. No. STANDARD H100CBWD H100CGD H100CYD H100CHD H100CRD H100CSRD LOW CURRENT H100CGDL H100CYDL H100CHDL 5 VOLT H100CGD5V H100CYD5V H100CHD5V Electro-Optical Data Peak Wave Length λ p(nm ) Em itted Color Lens Appearance 430 565 585 635 655 660 BLUE GREEN YELLOW HE RED RED SUPER RED DIFFUSED DIFFUSED DIFFUSED DIFFUSED DIFFUSED DIFFUSED 565 585 635 GREEN YELLOW HE RED DIFFUSED DIFFUSED DIFFUSED 565 585 635 GREEN YELLOW HE RED DIFFUSED DIFFUSED DIFFUSED View ing Angle If Iv Vf 2 ½ (m A) (m cd) (Deg) (V) TYP TYP MAX TYP Data @ 20m A 20 4.0 4.5 20 45 20 2.2 2.6 30 45 20 2.1 2.6 20 45 20 2.0 2.6 30 45 20 1.7 2.0 6 45 20 1.7 2.6 90 45 Data @ 2m A 2 1.9 2.2 6 45 2 1.9 2.2 4 45 2 1.8 2.2 6 45 Data @ 5V 10 5.0 30 45 10 5.0 20 45 10 5.0 30 45 LED P/N 3BWD-S 3GD-S 3YD-S 3HD-S 3RD-S 3SRD-S 3GDL-S 3YDL-S 3HDL-S 3GD5V-S 3YD5V-S 3HD5V-S STANDARD TOLERANCE ® ( UNLESS OTHERWISE SPECIFIED ) ±10% ALL VALUES ANGULAR X° DESIGNED: T. Yin CHECKED: D. Green ± 5° DATE: 03/05/04 DATE: 03/05/04 4 THOMAS, IRVINE, CA. 92618 TEL: (949) 951-8808 FAX: (949) 951-3974 TITLE: T-1 (3MM) INTERLOCKING 90° SINGLE-LEVEL LED ASSEMBLY REVISION: PART NO: H100CXX CAGE CODE : 32559 C SHEET # 2 OF 2 CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING.
H100CGDL 价格&库存
很抱歉,暂时无法提供与“H100CGDL”相匹配的价格&库存,您可以联系我们找货
H100CGDL
  • 1+6.924301+0.89496
  • 5+4.004215+0.51754
  • 25+3.6982125+0.47799
  • 100+3.18238100+0.41132
  • 500+2.96381500+0.38307
  • 1000+2.806441000+0.36273
  • 2000+2.745242000+0.35482
库存:19
H100CGDL
  • 1+6.45021
  • 5+3.73004
  • 25+3.44500
  • 42+2.69573
  • 115+2.54914
库存:19
