REV.
ITEM
Q'TY
1
1
H-101C
T-1 (3mm) LED Holder, 90° Mount
2
1
3XX-S
T-1 (3mm) N-Flange Shouldered LED, See Page 2 & 3
PART DESCRIPTION
PART NUMBER
1
C
D
E
F
G
H
DESCRIPTION
Holder Update, Added LEDs
LED Package Change to 3XX-S LEDs
Updated LED Specs
Added Water Clear LED Specs
Removed H101CUWC0.6K & H101CUBWC0.6K
Engineering Update w/o Changes
DATE
APPROVED
10/04/07
12/14/07
10/08/08
02/05/09
04/24/12
06/20/16
M. C.
M. C.
M. C.
T. Y.
T. Y.
J. C.
2
0.091 [2.3mm]
0.250 [6.4mm]
0.170 [4.3mm]
Ø.118 [Ø3.0mm]
0.285 [7.2mm]
0.200 [5.1mm]
Cathode I.D.
Mark
0.100 [2.5mm]
0.157 [4.0mm]
0.020 [0.5mm] SQ. TYP.
0.185 [4.7mm]
0.185 [4.7mm]
Holder Face
0.100 [2.5mm] LED Lead
Ø.032+.003
-.002
TYP.
Recommended Mounting Holes
ABSOLUTE MAXIMUM RATINGS (Ta=25° C)
REVERSE VOLTAGE
REVERSE CURRENT
OPERATING TEMPERATURE RANGE
STORAGE TEMPERATURE
LEAD SOLDERING TEMPERATURE(1/16" FROM BODY)
STANDARD TOLERANCE
( UNLESS OTHERWISE SPECIFIED )
DECIMALS
.X
.XX
.XXX
± .1
± .02
± .010
DESIGNED:
T. Yin
CHECKED:
D. Green
ANGULAR
X°
± 1°
4 THOMAS, IRVINE, CA. 92618
TEL: (949) 951-8808
FAX: (949) 951-3974
TITLE:
DATE:
03/05/04
DATE:
03/05/04
T-1 (3MM) 90° SINGLE-LEVEL
LED ASSEMBLY
REVISION:
PART NO:
H101CXX
CAGE CODE : 32559
H
SHEET # 1 OF 3
CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING.
REV.
DATE
DESCRIPTION
APPROVED
SEE SHEET #1
LED Assy. No.
STANDARD
H101CBWD
H101CBWC
H101CGD
H101CGC
H101CYD
H101CYC
H101CHD
H101CHC
H101CRD
H101CRC
LOW CURRENT
H101CGDL
H101CYDL
H101CHDL
H101CRDL
5 VOLT
H101CGD5V
H101CYD5V
H101CHD5V
Electro-Optical Data
Peak Wave
Length
λ p(nm )
Em itted Color
Lens
Appearance
430
430
568
568
590
590
625
625
700
700
BLUE
BLUE
GREEN
GREEN
YELLOW
YELLOW
HE RED
HE RED
RED
RED
DIFFUSED
WATER CLEAR
DIFFUSED
WATER CLEAR
DIFFUSED
WATER CLEAR
DIFFUSED
WATER CLEAR
DIFFUSED
WATER CLEAR
568
590
625
700
GREEN
YELLOW
HE RED
RED
DIFFUSED
DIFFUSED
DIFFUSED
DIFFUSED
568
590
625
GREEN
YELLOW
HE RED
DIFFUSED
DIFFUSED
DIFFUSED
View ing
Angle
Vf
If
Iv
2 ½
(V)
(m A)
(m cd) (Deg)
TYP TYP MAX TYP
Data @ 20m A
4.5
10
40
4.5
25
30
2.8
25
40
2.8
40
30
2.8
2.8
40
30
2.8
30
40
2.8
50
30
2.8
2
40
2.8
3
30
Data @ 2m A
2
2.1
2.6
2
40
2
2.0
2.6
2
40
2
2.0
2.6
3
40
2
2.1
2.6
1
40
Data @ 5V
8
5.0
25
40
8
5.0
8
5.0
30
40
LED P/N
3BWD-S
3BWC-S
3GD-S
3GC-S
3YD-S
3YC-S
3HD-S
3HC-S
3RD-S
3RC-S
3GDL-S
3YDL-S
3HDL-S
3RDL-S
3GD5V-S
3YD5V-S
3HD5V-S
STANDARD TOLERANCE
±10% ALL VALUES
ANGULAR
TEL: (949) 951-8808
FAX: (949) 951-3974
TITLE:
DESIGNED:
T. Yin
CHECKED:
D. Green
DATE:
03/05/04
DATE:
03/05/04
LED ASSEMBLY
REVISION:
PART NO:
H101CXX
CAGE CODE : 32559
H
SHEET # 2 OF 3
REV.
DATE
DESCRIPTION
APPROVED
SEE SHEET #1
LED Assy. No.
Peak Wave
Length
λ p(nm )
Electro-Optical Data @ 20m A
Em itted
Color
Lens
Appearance
TYP
TYP
MAX
TYP
View ing
Angle
2 ½
(Deg)
If
(m A)
Iv
(m cd)
Vf
(V)
LED P/N
H101CBWD0.245
470
BLUE
DIFFUSED
4.5
200
40
3BWD0.245-S
H101CUTC
500
TURQUOISE
WATER CLEAR
4.0
800
30
3UTC-S
H101CEGC2.030
525
GREEN
WATER CLEAR
4.5
2500
30
3EGC2.030-S
H101CUGC
570
GREEN
WATER CLEAR
2.4
200
30
3UGC-S
H101CSUGC
570
GREEN
WATER CLEAR
2.4
300
30
3SUGC-S
H101CUYC
590
YELLOW
WATER CLEAR
2.4
300
30
3UYC-S
H101CSUYC
590
YELLOW
WATER CLEAR
2.4
400
30
3SUYC-S
H101CUUYC
590
YELLOW
WATER CLEAR
2.4
600
30
3UUYC-S
H101CUOC
625
ORANGE
WATER CLEAR
2.4
300
30
3UOC-S
H101CSUOC
625
ORANGE
WATER CLEAR
2.4
400
30
3SUOC-S
H101CURC
645
RED
WATER CLEAR
2.4
200
30
3URC-S
H101CSURC
640
RED
WATER CLEAR
2.4
200
30
3SURC-S
H101CSRD
645
RED
DIFFUSED
2.4
40
40
3SRD-S
Iv
(m cd)
LED P/N
3UWC1.530-S
LED Assy. No.
H101CUWC1.530
Chrom aticity
Coordinates
X=.3, Y=.31
Em itted
Color
WHITE
Lens
Appearance
WATER CLEAR
TYP
TYP
MAX
TYP
View ing
Angle
2 ½
(Deg)
3.8
2000
30
If
(m A)
Vf
(V)
STANDARD TOLERANCE
±10% ALL VALUES
ANGULAR
TEL: (949) 951-8808
FAX: (949) 951-3974
TITLE:
DESIGNED:
T. Yin
CHECKED:
D. Green
DATE:
03/05/04
DATE:
03/05/04
LED ASSEMBLY
REVISION:
PART NO:
H101CXX
CAGE CODE : 32559
H
SHEET # 3 OF 3
很抱歉,暂时无法提供与“H101CGDL”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+7.59854
- 5+5.43218
- 25+4.56075
- 38+2.97263
- 104+2.80975
- 国内价格 香港价格
- 1+8.160761+1.05429
- 5+5.834115+0.75371
- 25+4.8982025+0.63280
- 100+4.08475100+0.52771
- 500+3.93606500+0.50850
- 1000+3.892321000+0.50285
- 2000+3.796112000+0.49042
