H101CHDL
H101CHDL
    BIVAR
    插件
    发光二极管/LED 红色 插件 3mcd
H101CHDL 数据手册
REV. ITEM Q'TY 1 1 H-101C T-1 (3mm) LED Holder, 90° Mount 2 1 3XX-S T-1 (3mm) N-Flange Shouldered LED, See Page 2 & 3 PART DESCRIPTION PART NUMBER 1 C D E F G H DESCRIPTION Holder Update, Added LEDs LED Package Change to 3XX-S LEDs Updated LED Specs Added Water Clear LED Specs Removed H101CUWC0.6K & H101CUBWC0.6K Engineering Update w/o Changes DATE APPROVED 10/04/07 12/14/07 10/08/08 02/05/09 04/24/12 06/20/16 M. C. M. C. M. C. T. Y. T. Y. J. C. 2 0.091 [2.3mm] 0.250 [6.4mm] 0.170 [4.3mm] Ø.118 [Ø3.0mm] 0.285 [7.2mm] 0.200 [5.1mm] Cathode I.D. Mark 0.100 [2.5mm] 0.157 [4.0mm] 0.020 [0.5mm] SQ. TYP. 0.185 [4.7mm] 0.185 [4.7mm] Holder Face 0.100 [2.5mm] LED Lead Ø.032+.003 -.002 TYP. Recommended Mounting Holes ABSOLUTE MAXIMUM RATINGS (Ta=25° C) REVERSE VOLTAGE REVERSE CURRENT OPERATING TEMPERATURE RANGE STORAGE TEMPERATURE LEAD SOLDERING TEMPERATURE(1/16" FROM BODY) STANDARD TOLERANCE ® ( UNLESS OTHERWISE SPECIFIED ) DECIMALS .X .XX .XXX ± .1 ± .02 ± .010 DESIGNED: T. Yin CHECKED: D. Green ANGULAR X° ± 1° 4 THOMAS, IRVINE, CA. 92618 TEL: (949) 951-8808 FAX: (949) 951-3974 TITLE: DATE: 03/05/04 DATE: 03/05/04 T-1 (3MM) 90° SINGLE-LEVEL LED ASSEMBLY REVISION: PART NO: H101CXX CAGE CODE : 32559 H SHEET # 1 OF 3 CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING. REV. DATE DESCRIPTION APPROVED SEE SHEET #1 LED Assy. No. STANDARD H101CBWD H101CBWC H101CGD H101CGC H101CYD H101CYC H101CHD H101CHC H101CRD H101CRC LOW CURRENT H101CGDL H101CYDL H101CHDL H101CRDL 5 VOLT H101CGD5V H101CYD5V H101CHD5V Electro-Optical Data Peak Wave Length λ p(nm ) Em itted Color Lens Appearance 430 430 568 568 590 590 625 625 700 700 BLUE BLUE GREEN GREEN YELLOW YELLOW HE RED HE RED RED RED DIFFUSED WATER CLEAR DIFFUSED WATER CLEAR DIFFUSED WATER CLEAR DIFFUSED WATER CLEAR DIFFUSED WATER CLEAR 568 590 625 700 GREEN YELLOW HE RED RED DIFFUSED DIFFUSED DIFFUSED DIFFUSED 568 590 625 GREEN YELLOW HE RED DIFFUSED DIFFUSED DIFFUSED View ing Angle Vf If Iv 2 ½ (V) (m A) (m cd) (Deg) TYP TYP MAX TYP Data @ 20m A 20 4.0 4.5 10 40 20 4.0 4.5 25 30 20 2.1 2.8 25 40 20 2.1 2.8 40 30 20 2.0 2.8 20 40 20 2.0 2.8 40 30 20 2.0 2.8 30 40 20 2.0 2.8 50 30 20 2.1 2.8 2 40 20 2.1 2.8 3 30 Data @ 2m A 2 2.1 2.6 2 40 2 2.0 2.6 2 40 2 2.0 2.6 3 40 2 2.1 2.6 1 40 Data @ 5V 8 5.0 25 40 8 5.0 20 40 8 5.0 30 40 LED P/N 3BWD-S 3BWC-S 3GD-S 3GC-S 3YD-S 3YC-S 3HD-S 3HC-S 3RD-S 3RC-S 3GDL-S 3YDL-S 3HDL-S 3RDL-S 3GD5V-S 3YD5V-S 3HD5V-S STANDARD TOLERANCE ® ( UNLESS OTHERWISE SPECIFIED ) ±10% ALL VALUES ANGULAR 4 THOMAS, IRVINE, CA. 92618 TEL: (949) 951-8808 FAX: (949) 951-3974 TITLE: DESIGNED: T. Yin CHECKED: D. Green DATE: 03/05/04 DATE: 03/05/04 T-1 (3MM) 90° SINGLE-LEVEL LED ASSEMBLY REVISION: PART NO: H101CXX CAGE CODE : 32559 H SHEET # 2 OF 3 CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING. REV. DATE DESCRIPTION APPROVED SEE SHEET #1 LED Assy. No. Peak Wave Length λ p(nm ) Electro-Optical Data @ 20m A Em itted Color Lens Appearance TYP TYP MAX TYP View ing Angle 2 ½ (Deg) If (m A) Iv (m cd) Vf (V) LED P/N H101CBWD0.245 470 BLUE DIFFUSED 20 4.0 4.5 200 40 3BWD0.245-S H101CUTC 500 TURQUOISE WATER CLEAR 20 3.5 4.0 800 30 3UTC-S H101CEGC2.030 525 GREEN WATER CLEAR 20 4.0 4.5 2500 30 3EGC2.030-S H101CUGC 570 GREEN WATER CLEAR 20 2.1 2.4 200 30 3UGC-S H101CSUGC 570 GREEN WATER CLEAR 20 2.1 2.4 300 30 3SUGC-S H101CUYC 590 YELLOW WATER CLEAR 20 2.0 2.4 300 30 3UYC-S H101CSUYC 590 YELLOW WATER CLEAR 20 2.0 2.4 400 30 3SUYC-S H101CUUYC 590 YELLOW WATER CLEAR 20 2.0 2.4 600 30 3UUYC-S H101CUOC 625 ORANGE WATER CLEAR 20 1.8 2.4 300 30 3UOC-S H101CSUOC 625 ORANGE WATER CLEAR 20 1.8 2.4 400 30 3SUOC-S H101CURC 645 RED WATER CLEAR 20 1.7 2.4 200 30 3URC-S H101CSURC 640 RED WATER CLEAR 20 1.8 2.4 200 30 3SURC-S H101CSRD 645 RED DIFFUSED 20 1.7 2.4 40 40 3SRD-S Iv (m cd) LED P/N 3UWC1.530-S Electro-Optical Data @ 20m A LED Assy. No. H101CUWC1.530 Chrom aticity Coordinates X=.3, Y=.31 Em itted Color WHITE Lens Appearance WATER CLEAR TYP TYP MAX TYP View ing Angle 2 ½ (Deg) 20 3.2 3.8 2000 30 If (m A) Vf (V) STANDARD TOLERANCE ® ( UNLESS OTHERWISE SPECIFIED ) ±10% ALL VALUES ANGULAR 4 THOMAS, IRVINE, CA. 92618 TEL: (949) 951-8808 FAX: (949) 951-3974 TITLE: DESIGNED: T. Yin CHECKED: D. Green DATE: 03/05/04 DATE: 03/05/04 T-1 (3MM) 90° SINGLE-LEVEL LED ASSEMBLY REVISION: PART NO: H101CXX CAGE CODE : 32559 H SHEET # 3 OF 3 CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING.
H101CHDL 价格&库存
很抱歉,暂时无法提供与“H101CHDL”相匹配的价格&库存,您可以联系我们找货
