ERM18103BC-3-RY
ERM18103BC-3-RY
    BIVAR
    LED ASSY 0.810" 3MM R/Y WHT DIFF
ERM18103BC-3-RY 数据手册
ITEM Q'TY 1 2 1 1 PART NUMBER REV. PART DESCRIPTION Extruded, Self-Retaining LED Holder, .810" T-1 (3mm) Flanged LED, Bi-Color ERM 1-810 3BC-3-R/Y-F DATE APPROVED 01/05/11 05/25/16 T. Y. J. C. DESCRIPTION A Engineering Release B Engineering Update w/o Changes (2) Common Cathode 2 Flat edge Polarity ID 0.120 [3.1mm] 0.810 [20.6mm] 0.209 [5.3mm] (3) 0.157 [4.0mm] (1) Red Anode (2) Ø0.118 [Ø3.0mm] (3) Yellow Anode (1) 0.030 [0.8mm] 0.049 [1.2mm] 0.020 [0.5mm] SQ TYP. Ø0.032+.003 -.002 TYP. 0.100 [2.5mm] TYP. 1 0.100 [2.5mm] TYP. Recommended Mounting Holes Chip LED Part No. 3BC-3-R/Y-F Absolute Max. Ratings Material Peak Wave Length λp (nm ) Em itted Color GaAsP/GaP 625 RED GaAsP/GaP 590 YELLOW Lens Appearance WHITE DIFFUSED Electro-Optical Data @ 20m A Vf (V) Iv (m cd) ∆λ (nm ) Pd (m W) If (m A) Peak If (m A) TYP MAX TYP 35 80 30 150 2.0 2.8 30 35 80 30 150 2.0 2.8 20 View ing Angle (Deg) 40 STANDARD TOLERANCE ® ( UNLESS OTHERWISE SPECIFIED ) DECIMALS ABSOLUTE MAXIMUM RATINGS (Ta = 25°C) OPERATING TEMPERATURE RANGE -25°C ~ 85°C STORAGE TEMPERATURE -30°C ~ 100°C LEAD SOLDERING TEMPERATURE (1/16" FROM BODY) 260°C for 5 Seconds .X .XX .XXX ± .1 ± .02 ± .010 DESIGNED: R. Paje CHECKED: T. Yin ANGULAR X° ± 1° DATE: 01/05/11 DATE: 01/05/11 4 THOMAS, IRVINE, CA. 92618 TEL: (949) 951-8808 FAX: (949) 951-3974 TITLE: EXTRUDED, SELF-RETAINING LED HOLDER ASSY REVISION: PART NO: ERM18103BC-3-RY CAGE CODE : 32559 B SHEET # 1 OF 1 CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING.
ERM18103BC-3-RY 价格&库存
很抱歉,暂时无法提供与“ERM18103BC-3-RY”相匹配的价格&库存,您可以联系我们找货
ERM18103BC-3-RY
  • 100+3.14938100+0.39405
  • 300+3.06067300+0.38295
  • 500+3.01631500+0.37740
  • 1000+2.971961000+0.37185
  • 2000+2.927602000+0.36630
ERM18103BC-3-RY
    • 1+8.61840
    • 200+3.44520
    • 500+3.32640
    • 1000+3.27240
