ITEM
Q'TY
1
1
922-343
Multi-Functional Single LED Holder
2
1
R7XX
2x7mm Rectangular LED, See Page 2
PART NUMBER
REV.
PART DESCRIPTION
B
C
D
1
2
0.295 [7.5mm]
0.091 [2.3mm]
DESCRIPTION
Engineering Update w/o Changes
Added R7BC-XX LEDs
DATE
APPROVED
03/08/04
09/28/06
07/30/16
M. C.
M. C.
J. C.
0.400 [10.2mm]
0.207 [5.3mm]
0.268 [6.8mm]
0.295 [7.5mm]
0.148 [3.7mm]
0.157 [4.0mm]
0.020 [0.5mm]
0.100 [2.5mm]
SQ. TYP.
2
1
Holder Face
0.185 [4.7mm]
0.100 [2.5mm]
LED Lead
Ø.032+.003
TYP. -.002
Recommended Mounting Holes
ABSOLUTE MAXIMUM RATINGS (Ta=25° C)
REVERSE VOLTAGE
REVERSE CURRENT
OPERATING TEMPERATURE RANGE
STORAGE TEMPERATURE
LEAD SOLDERING TEMPERATURE(1/16" FROM BODY)
2
1
Single Color
Bi-Color 1
2
BI-COLOR POLARITY
LED P/N (1) CATHODE (2) CATHODE
RED
R7BC
GREEN
R7BC-Y/G
GREEN
YELLOW
R7BC-R/Y
YELLOW
RED
STANDARD TOLERANCE
( UNLESS OTHERWISE SPECIFIED )
DECIMALS
.X
.XX
.XXX
± .1
± .02
± .010
DESIGNED:
D. Green
CHECKED:
M. Chen
ANGULAR
X°
± 1°
4 THOMAS, IRVINE, CA. 92618
TEL: (949) 951-8808
FAX: (949) 951-3974
TITLE:
DATE:
10/10/03
DATE:
10/10/03
RECTANGULAR 2X7MM VERT.
90° SINGLE-LEVEL LED ASSY
REVISION:
PART NO:
H921VR7XX
CAGE CODE : 32559
D
SHEET # 1 OF 2
CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING.
REV.
DATE
DESCRIPTION
APPROVED
SEE SHEET #1
LED Assy. No.
H921VR7GD
H921VR7YD
H921VR7RD
H921VR7BC
H921VR7BC-Y/G
H921VR7BC-R/Y
Peak Wave
Length
λ p(nm )
Em itted Color
565
585
655
635
568
585
568
640
585
GREEN
YELLOW
RED
RED
GREEN
YELLOW
GREEN
RED
YELLOW
Lens
Appearance
DIFFUSED
DIFFUSED
DIFFUSED
DIFFUSED
DIFFUSED
DIFFUSED
Abs. Max.
Rating
If
(m A)
30
30
40
30
30
30
30
30
30
Electro-Optical
Data @ 20m A
View ing
Angle
Vf
2 ½
Iv
(V)
(Deg)
(m cd)
TYP
MAX
TYP
2.2
2.6
7
125
2.1
2.6
5
125
1.7
2.0
1
125
2.0
2.6
6
120
2.2
2.6
6
2.1
2.6
5
120
2.2
2.6
6
2.0
2.6
6
120
2.1
2.6
6
LED P/N
R7GD
R7YD
R7RD
R7BC
R7BC-Y/G
R7BC-R/Y
STANDARD TOLERANCE
±10% ALL VALUES
ANGULAR
TEL: (949) 951-8808
DESIGNED:
D. Green
CHECKED:
M. Chen
DATE:
10/10/03
DATE:
10/10/03
FAX: (949) 951-3974
TITLE: RECTANGULAR 2X7MM VERT.
REVISION:
PART NO:
H921VR7XX
CAGE CODE : 32559
D
SHEET # 2 OF 2
很抱歉,暂时无法提供与“H921VR7YD”相匹配的价格&库存,您可以联系我们找货
