ERM18103BC-3
ERM18103BC-3
    BIVAR
    发光二极管/LED 红色,翠绿色 35mcd,35mcd
ERM18103BC-3 数据手册
ITEM Q'TY 1 2 1 1 PART NUMBER REV. PART DESCRIPTION Extruded, Self-Retaining LED Holder, .810" T-1 (3mm) Flanged LED, Bi-Color ERM 1-810 3BC-3-F DESCRIPTION A Engineering Release. B Updated Lead Lengths. C Engineering Update w/o Changes 1.00 [25.4mm] MIN. DATE APPROVED 08/09/07 02/01/08 05/25/16 M. C. M. C. J. C. (2) Common Cathode 0.810 [20.6mm] Flat edge Polarity ID 0.209 [5.3mm] (3) 0.157 [4.0mm] (3) (1) He Red Anode Green Anode (2) (1) 0.030 [0.8mm] 0.100 [2.5mm] TYP. Ø0.118 [Ø3.0mm] 2 Ø0.032+.003 -.002 TYP. 1 0.100 [2.5mm] TYP. Recommended Mounting Holes Chip LED Part No. 3BC-3-F Absolute Max. Ratings Peak Wave Length λp (nm ) Em itted Color GaAsP/GaP 635 HE RED GaP/GaP 568 GREEN Material Lens Appearance WHITE DIFFUSED ∆λ (nm ) Pd (m W) If (m A) Electro-Optical Data @ 20m A Vf (V) Peak If (m A) Iv (m cd) TYP MAX TYP 45 80 30 150 2.0 2.6 35.0 30 80 30 150 2.2 2.6 35.0 View ing Angle (Deg) 40 STANDARD TOLERANCE ® ( UNLESS OTHERWISE SPECIFIED ) DECIMALS ABSOLUTE MAXIMUM RATINGS (Ta = 25°C) OPERATING TEMPERATURE RANGE -25°C ~ 85°C STORAGE TEMPERATURE -30°C ~ 100°C LEAD SOLDERING TEMPERATURE (1/16" FROM BODY) 260°C for 5 Seconds .X .XX .XXX ± .1 ± .02 ± .010 DESIGNED: D. Beckman CHECKED: T. Yin ANGULAR X° ± 1° DATE: 08/09/07 DATE: 08/09/07 4 THOMAS, IRVINE, CA. 92618 TEL: (949) 951-8808 FAX: (949) 951-3974 TITLE: EXTRUDED, SELF-RETAINING LED HOLDER ASSY REVISION: PART NO: ERM18103BC-3 CAGE CODE : 32559 C SHEET # 1 OF 1 CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING.
ERM18103BC-3 价格&库存
很抱歉,暂时无法提供与“ERM18103BC-3”相匹配的价格&库存,您可以联系我们找货
